What charger did you use?
Did you take voltage readings of each cell before and after the charge? Did you take voltage readings of each cell before and after the flight? Did you balance charge? Is your ESC set for the correct number of cells? With that one cell at 2 volts, I would think that battery is cooked or not properly charged. Some links that may be helpful: http://www.batteryuniversity.com/ http://www.ampaviators.com/2007/04/2...tery-chargers/ http://www.rchobbies.org/lithium_bat...eakthrough.htm |
Wow, thanks everyone for the replys! To answer some questions:
I used my Hyperion charger, been using it for 2 years and it's been rock solid. I did balance charge on 5S, 4900 mah but I never checked the individual voltage of the cells while charging. I bought the plane, motor, esc and batteries ready to fly so I have no idea where the low voltage cutoff on the castle is set at. (someone have a link how to do this? Previous owner seemed like a real stand up guy, I'm sure he didn't know if it had a bad cell. Oh also, a friend of mine who's really good with electronics said he could cut that one cell out and make it a 4 cell pack. Plane has plenty of power with the 5 cell, 4 should still fly it fine. What do you think? |
Great info, thanks! I tried to balance charge it after the flight but my charger won't let me, says "voltage too low". If I don't balance charge it the other cells will overcharge right? Pack doesn't seem puffed btw. Plane came with a 14-8 prop, I bought a couple spare props, 13-8 and 13-6. Would this be less "amp hungry"? Plane has plenty of power as is. Sorry for all the newb electric questions! |
If your charger can lipo charge without balancing you may be able to get it charging up until the cell reaches 3.0 and then switch to balance charge.
You can also try to charge only that one cell until it reaches a level close to the others. 70min charge is that all crazy when the average is 60min. It may jsut of been taking longer cause it was trying to bring back the cell. So to answer if its something you could of prevented, sure it is but its done now. The question you need to be asking is do you still want to fly your plane with a possibly less then ok pack. |
Latest blog entry: Get Help by posting your SPM File
if you have a 14-8 then a 13x10 would be almost equivalent and so anything with less pitch will draw less amps. IF you have a watt meter you would be able to tell exactly whats going on and you could make the perfect prop selection for your power system. Depending on the plane and the type of flying you want to do a certain amount of watts per pound are required, you want to follow these recommendation for succefull flights. |
I can unplug the balance lead and it'll charge the pack but I was afraid of overcharging the other cells. Maybe I could monitor the pack and make sure the other cells don't exceed 4.2 volts. I bought a Sr. Telemaster with this motor/esc/batteries. Going to be taking aerial video over the ocean and beach so I transferred everything into an old beat up Sr. Falcon (didn't want to risk the Telemaster) Plane is a high wing trainer and weighs 7 1/2 lbs. Has virtually unlimited vertical with this sytem. (69 inch wingspan) |
| Thread Tools | |
| Discussion My First Balsa ARF Crashes on First Flight | krexken | Crash Discussion | 4 | Jun 01, 2010 03:06 PM |
| Discussion My first flight on new 450se v2 - a few quick questions | Sl0flyer | Mini Helis | 2 | Apr 15, 2010 05:48 PM |
| For Sale 2x 5s 3300 25C , 2x 5s 4200 25C Fusion-Pack | Fusion-Pack | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Dec 08, 2009 10:33 AM |
| my first flight on my first molded glider | danny_isr | Sailplane Talk | 3 | Apr 13, 2004 08:25 PM |
