Old Jun 30, 2010, 10:48 PM
Jason_WI is offline
Find More Posts by Jason_WI
Cox Engine Hoarder
Jason_WI's Avatar
Neenah, Wisconsin, United States
Joined Jun 2004
Help!
Carb ID
I aquired a carb in an engine lot I bought. It has a outlet OD of 15mm and ID of 9.5mm. The outlet barrel length is 10mm. Inlet ID is 12.5mm at the top and is tapered. Barrel end to end length is 39.5mm. Width from needle valve end to throttle lever is 65.3mm with the needle valve turned all the way in.
There are no numbers or marks on it anywhere. Any help is appreciated.
Jason
Jason_WI is offline Find More Posts by Jason_WI
Old Jun 30, 2010, 10:51 PM
proptop is offline
Find More Posts by proptop
Airplane Gearhead
Central N.Y.
Joined Jan 2005
A bit difficult to tell for sure...the pics are a little dark...but it looks to me like a Magnum carb.
From the dimensions, I would guess perhaps from a .91 or larger?
proptop is offline Find More Posts by proptop
Old Jun 30, 2010, 10:54 PM
Jason_WI is offline
Cox Engine Hoarder
Jason_WI's Avatar
Joined Jun 2004
Sorry about the bad pics. My other good cameras are not with me so all I had was my iPhone camera.
Jason
Old Jun 30, 2010, 10:57 PM
proptop is offline
Airplane Gearhead
Central N.Y.
Joined Jan 2005
That's ok...they're good enough to give visual clues...looks a lot like a Magnum carb...
.91 or 1.08, or maybe their 1.20 size 2 strokes.
Discussion Control line carb to RC carb JollyPopper200 Engines 15 Jan 18, 2010 10:05 PM
Poll THE REAL ID ACT (national id card) booger Life, The Universe, and Politics 26 Feb 08, 2008 08:25 AM
OS 61 SF - Broken Carb (#7L) - Can I replace it with a different carb? oxygen728 Engines 6 Aug 30, 2005 04:00 PM
Want to Trade OS 7D Carb for OS 7M Carb coloradoz Aircraft - Fuel - Airplanes (FS/W) 0 Jan 02, 2004 12:16 PM
