Old Jun 30, 2010, 02:52 PM
polar8 is offline
Find More Posts by polar8
Joined Nov 2007
Cheap RC car platform to be used for FPV testing?
I'd like to get the car equivalent of a cheap ARF plane to test my FPV setup on. Plus, it would be cool to drive around with a head-tracked camera.
Does anyone know of an inexpensive RTR car that will accept a standard receiver (I'll be using a futaba 7c in this case).
Thanks!
polar8 is offline Find More Posts by polar8
Old Jun 30, 2010, 10:45 PM
polar8 is offline
Joined Nov 2007
No ideas?
Old Jun 30, 2010, 10:49 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
the traxxas slash is a great platform for testing
done lots of ground testing and was well worth it
turn it into front wheel drive and it goes even better
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jun 30, 2010, 11:45 PM
polar8 is offline
Joined Nov 2007
I just thought of something. Is it possible to do reverse on an Air radio?
Old Jun 30, 2010, 11:55 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
setup throttle on elevator and steering on aileron channel
drive with right stick
make sure no trims or subtrims are set, and you might wanna increase the travel limit on those channels
Moe
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Jul 01, 2010, 07:01 AM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
If you do that with a Traxxas vehicle, be sure to re-calibrate the ESC once you add your new radio. You should be set them. I drive with the right stick as well.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Jul 01, 2010, 08:51 AM
David22 is offline
Joined Apr 2008
Put a dead band in the throtle stick in the center
so when positioned in the cetre it is neutral and stops the car/truck
forward it forward back is reverse
aileron control is turning left and right
try to keep all your controls and switches as they would be on your plane
I run stock esc but remove the red wire, and then plug in a separate rx battery pack to power the esc.
I run my slash on 4000mah or so 3 cells lipo all the time.
Old Jul 01, 2010, 09:44 AM
HariEdo is offline
Find More Posts by HariEdo
Central Connecticut
Joined Jan 2010
Moe
That works, but personally I would put throttle on throttle (no center spring), steering on rudder. Mode 2 has these on the same stick. I'd set the throttle curve to have a deadband under the middle, and use expo to taste on the rudder. Then I'd use the aileron/elevator for a pan/tilt for my camera because I don't really like head tracking units. This makes it work a lot more like many two-stick video games, where one stick moves the body and the other stick aims the camera independently.
HariEdo is offline Find More Posts by HariEdo
Old Jul 01, 2010, 12:49 PM
liam2317 is offline
Find More Posts by liam2317
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
It might be a bit small for what you are looking for (1/18 scale) but the Pro-Pulse is super cheap and preforms quite well considering. You can get them on eBay for about $50 and if you stick a 2s lipo in it they really move!
This is a video of a completely stock setup:
Pro Pulse T-100 (1 min 8 sec)
liam2317 is offline Find More Posts by liam2317
Old Jul 02, 2010, 03:26 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
liam2317 servo and speed is proportional? looks good enought
you know the web of the manufacturer of this car?
wallaguest1 is offline Find More Posts by wallaguest1
Old Jul 02, 2010, 01:56 PM
liam2317 is offline
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
Sorry, but what do you mean by proportional? As far as I can tell it's just a standard servo (with a servo saver!) and forward/reverse brushed speed control. I actually have never used the stock radio that comes with it, I just put a Spektrum Rx in it as soon as I got it.
The manufacturer is Megatech. I believe they don't actually produce this car anymore (it's been replaced with the very similar "MegaPro") but you can still buy replacement parts on their website here, or on ebay which is probably much cheaper. The instruction manual is available as well, here is a link to it.
Old Jul 02, 2010, 02:02 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
you can get any rc car and fpv it. Me and my friend made a 360 pan and tilt out of legos with a couple of servos. It was very fun
sim_io is offline Find More Posts by sim_io
Discussion Some advice for HD cams which can be used for FPV AnnihilaT FPV Talk 18 Aug 02, 2010 02:43 PM
Question Can a car battery charger be used as a 12V power supply? sonny1 Batteries and Chargers 21 Nov 23, 2009 06:27 PM
FAQ The Cularis will be my new FPV platform: What will be the best camera location? Itzik Ronen FPV Talk 24 Jun 19, 2009 12:24 AM
Discussion Cheap FPV Car for Kids Domoson FPV Talk 8 Dec 28, 2007 05:13 PM
