This thread is privately moderated by wim5150, who may elect to delete unwanted replies.
Old Jun 29, 2010, 08:07 PM
wim5150 is offline
Find More Posts by wim5150
illinois
Joined Jun 2001
Necromancer
Next is a balsa model originally designed Cox .049, published in one of the RC mags some time ago. I'd only flown a couple of trainers up to this point but had to have this sleek fast looking model. Finished the build one summer evening and couldn't wait another day to toss it out. Dove to the field, quick range check & pre-flight, started it up and let it go. Flew right off the board. Did a couple of circuits with a few rolls and a loop or two it was perfect. Unfortunately I failed to notice the sun had set behind the tree line, sky above still light enough to see the plane but it was way dark in front of the trees. Decided I'd better try to land before it was too late. With the TeeDee .049 wide open and fuel tank still 1/2 full, I lined up and needless to say lost site against the dark trees. Before I realized it the plane came screaming past about 6 inches from my nose and slid into the grass about 10 feet away! The Necromancer and I went home unharmed and quite pleased.
This is a re-build for e-power. No more TeeDee's!
26.5" span 29" long 274 sq. in. balsa covered with Solite with vinyl trim. 400XT motor re-wired Delta to increase Kv and speed. 3S 1000 & 1300 mah and 2 servos.
wim5150 is offline Find More Posts by wim5150
Cool Old plans built wooden wing "Necromancer" elfwreck Flying Wings 4 Mar 26, 2008 08:04 PM
