Old Jun 29, 2010, 07:32 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Build Log
7" Micro Skipper Airboat
Well here it is. It is a 175x65mm airboat made with 3mm (grey) and 2mm (white) depron foam. The little thing uses an AR6400, Vapor 6mm motor, an Aero Ace prop, and any compatible battery. Now I just have to finish it and run it in the pool.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jun 29, 2010, 07:41 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Thats a cool little rig!
If you dont already have a servo, this one weighs a whopping 0.28 of an ounce.
http://www3.towerhobbies.com/cgi-bin...&I=LXNCV6&P=ML
scorpion1 is offline Find More Posts by scorpion1
Old Jun 29, 2010, 07:44 PM
Joined Nov 2007
Right now, I am fine tuning it by messing with the cg. Once I get good performance on my near dead 120mah, I will be happy.
Old Jun 29, 2010, 09:51 PM
Joined Nov 2007
scorpion1, I did not see your reply. The ar6400 has two on-board servos.
Here is the video. It is a bit underpowered with the 6mm, but a 7mm should get it going.
http://www.rcgroups.com/forums/showt...1#post15433525
Old Jun 30, 2010, 09:23 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Why such a small prop? A 6mm motor can handle bigger than an AA prop direct drive, can't it?
wparsons is offline Find More Posts by wparsons
Old Jun 30, 2010, 09:38 AM
Joined Nov 2007
An AA prop is a 6mm class prop. Anything bigger and the motor starts getting too hot.
Old Jun 30, 2010, 10:36 AM
Joined Nov 2007
I swapped the 6mm for a bigger Air Hogs Jetscream 7mm. I have a little turning issues, but I'm sure it won't be hard to fix it. Also I have another video. As you can see, every time I hit the water jets (near the middle), the boats goes on its bow and spins out, why? I am going to put little ails on the side to help with cornering. What would subsurface fins do? I do not know much about the physics of airboats.
Kev
Video:
http://www.rcgroups.com/forums/showp...01&postcount=4
Old Jun 30, 2010, 11:29 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I looks like it doesn't draw much water at all, and the light weight will make it really easy to spin. A water rudder might help, but I wouldn't expect miracles. Flat bottom airboats tend to slide and spin really easily.
Old Jun 30, 2010, 11:49 AM
Joined Nov 2007
The thing weighs 13.32 grams. What about two rails to the bottom?
Old Jun 30, 2010, 03:36 PM
Joined Nov 2007
The Micro Skipper...
Old Jun 30, 2010, 04:08 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I would put a thin one around the CG right in the center, and add a water rudder. The front fin will act as a pivot and the water rudder will keep it from skidding too much.
Mini-Review Hobby king Micro Power system w/ Gearbox GPS-7 Terry Rigden Scratchbuilt Indoor and Micro Models 6 Mar 26, 2010 04:04 PM
Sold !!! 7 3.7V 1 Cell lipos for MCX, Ultra Micro Suhkoi, Ultra Micro P-51, ECT. !!!! 801Funk801 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Dec 21, 2009 06:22 PM
Sold !!! 7 3.7V 1 Cell lipos for MCX, Ultra Micro Suhkoi, Ultra Micro P-51, ECT. !!!! 801Funk801 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 20, 2009 04:39 PM
Sold NIP Futaba trainer cable micro to micro $7.50sh/pd conus Trade 4 2 micro plane wheels HyperHelis Aircraft - General - Radio Equipment (FS/W) 2 Dec 11, 2007 11:50 PM
