Old Jun 30, 2010, 01:15 PM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
Originally Posted by jzuniga View Post
Ok this may sound like some dumb questions but...
1) What would an equivalent "app" be? I have an iphone and all I found was an app called "vibration" that takes X, Y, Z readings? there is some kind of "sec/div" value also given? would this work?
2) Are the "vibration" values in your diagram, the average of the X, Y, Z readings? I see in the photo of your droid it too looks like it's giving these readings, like an oscilloscope?
Thanks for your help...;-)
Z
I am not familiar with Apple market of applications.
To answer your question about data readings: the software provides four columns of data per reading: Time, X, Y, Z. In fact you can ignore time altogether. You are not interested in absolute measurements of the vibration values either, see below why. All you need is two columns out of four with vibration data along axis X and Z.
If you take a closer look at the picture with the phone you'll see that I mounted phone at 45 degrees. This angle "sort of compensates" weight factor of the phone when measurements are done along axis X and Z. You do not need to measure axis Y, because this is movement along the motor shaft.
Now that you have two columns of data, you sum them up as vectors to get resulting force using this formula:
Result force vector = SQRT(X*X + Z*Z)
This will give you one column of data. To get one number from the series of data that can be compared with another series of the data you calculate standard deviation of the series. Standard deviation is volatility or vibration level in engineering terms.
Vibration = StdDev(result force vector)
Now when you have this number you can compare it with number from another measurement.
I hope this explanation helps.
_Sergey_ is offline Find More Posts by _Sergey_
Old Jun 30, 2010, 03:01 PM
Naval Warfare is offline
Find More Posts by Naval Warfare
Screw the wind, let's fly!
Naval Warfare's Avatar
United States, GA, Sautee Nacoochee
Joined Feb 2008
See what ya started?
Naval Warfare is offline Find More Posts by Naval Warfare
Old Jul 01, 2010, 12:13 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Calculations example
There were questions about calculations so I created an example. Please see attached picture.
Old Jul 01, 2010, 01:07 PM
jzuniga is offline
Find More Posts by jzuniga
United States, WA, Gig Harbor
Thanks Sergey!
Z
jzuniga is offline Find More Posts by jzuniga
Old Jul 01, 2010, 01:16 PM
PANTHERFLYR is offline
Find More Posts by PANTHERFLYR
Retired C-5 Flight Engineer
PANTHERFLYR's Avatar
United States, CA, Fairfield
Joined May 2005
Awesome! Funny thing.....I fly C-5's for a living and we have this type of "program" on the jet for our engine vibration reporting. We basically run through this type of procedure if we get an engine vib indication...pretty cool!!
PANTHERFLYR is offline Find More Posts by PANTHERFLYR
Old Jul 21, 2010, 12:05 AM
Fubar69 is offline
Find More Posts by Fubar69
Fubar69's Avatar
Gold Coast, Australia
Joined Sep 2004
Thank you so much for this tech info!
I just bought a Freewing F16. I have a couple of friends who own Freewing SU34's. I mentioned to them I wanted to balance my fan and one said he wouldnt waste his time for the minimal gains it would achieve.
This is going to be fun!
Fubar69 is offline Find More Posts by Fubar69
Old Jul 21, 2010, 12:46 AM
Fubar69 is offline
Fubar69's Avatar
Joined Sep 2004
I have to ask this out of curiosity.
Although a little more tedious, if you went more granular on the initial check of the motor to impeller vibration, say every 20 or even 10 degree's instead of 45, logic would say that you would get a better result by getting it closer to the spot where vibrations are lowest correct?
Yes I know it would be harder and more exacting but I wonder if the increase in efficiency would be worth the trouble?
Old Jul 21, 2010, 07:16 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
This should be a sticky...
Questions
- In step 2 it looks like there's a normal static balance of the rotor, am I right to conclude that the area of least vibration on the motor is where we're supposed to align the balanced rotor?
- I have an HTC Touch Pro 2 running WM 6.5 and it has accelerometers do you know of any sensor apps for this phone?
- Any vid of your 380? Would love to hear the sounds of the fans
TIA
erh7771 is online now Find More Posts by erh7771
Old Jul 21, 2010, 11:08 AM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
You are correct about precision. There are also ways how to achieve more exact angle without it being too tedious. To increase precision one extra step is needed. After lowest vibration angle A(min) is identified in step 1 follow step 1a:
Step 1a:
a) Position fan at the angle A(min)-30 degrees
b) Take measurement
c) Rotate fan by +10 degrees
d) Repeat steps b-c 7 times
The result should look like a U-shaped curve with the bottom point is the minimum point of vibration with accuracy of 10 degrees with just extra seven measurements.
Theoretically step 1a can be repeated with new A(min) and +- 10 degrees spread to narrow down the minimum point to a three degree angle. But it may not be practical. First it is much harder to manually rotate fan by three degrees. Secondly there is a measurement error that can be larger than the result making single measurement impractical. There are ways to include this error as a factor in the calculation but this is going to be very tedious job with dozens of extra measurements and may require some sort of automation, where computer or phone controls the throttle, not human.
I hope this is helpful.
Old Jul 21, 2010, 11:36 AM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
TIA
Here are two videos. First one is the maiden flight with unbalanced motors. Check take off and cruise sound starting at 0:55. Second is after engines are balanced. Don't mind the landing on both videos, it's a coincidence.
Unbalanced fans:
A380 Maiden Flight (3 min 33 sec)
Balanced fans:
Airbus A-380 RC Jet (1 min 38 sec)
Old Jul 21, 2010, 11:58 AM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Mostly correct with exception there is no fan balancing. In fact, if the fan is statically balanced the dynamic balancing won't work. The fan must be disbalanced from the beginning, otherwise it is impossible to find motor's heaviest point. Then heaviest point on the fan aligned agaist heaviest point on the motor.
I am not sure. Check this application if it works on your phone: http://www.lucanatech.com/sensor_insider
Old Jul 21, 2010, 02:51 PM
shhhhh! is offline
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Sergey....would this vibration meter work for balancing a fan unit? looks like it is wired for the y-axis?
http://www.dimensionengineering.com/...tion_meter.htm
-Dave
shhhhh! is offline Find More Posts by shhhhh!
Old Jul 21, 2010, 02:53 PM
Joined Nov 2005
On the second vid the wheels rolling on the asphalt were louder than all 4 EDFs!!!
I wanted a Sprint Evo anyway....sounds like an excuse to buy one if I can't find any sensor software for windows mobile.
Further questions
- The Excel spread sheet, did that come with your software or did you do the calculations and the spider chart yourself?
If you did them yourself are you willing to sell the sheet? 5 bucks?
-"f) Rotate fan to approximately 45 degrees. Direction is not important as far as you rotate in the same direction each run."
Am I rotating the EDF fan shroud 45 degrees from a marked top and then doing another test or am I rotating the EDF rotor 45 degrees then doing another test?
TIA for any input and again thx,
Also, thx for the windows mobile sensor app...helps me wait a lil bit till google comes out with droid 2.x somethin at the end of the year
Old Jul 21, 2010, 03:03 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
-Dave
I think it would. The only problem is how to collect vibration data for analysis? I think it's possible to come up with a method to measure vibration at various RPM levels, enter numbers manually and go from there?
Old Jul 21, 2010, 03:07 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Haha! I did it myself and it's free. Enjoy!
For Sale Don's Wicked 4800 mounted in a dynamically balanced 64mm EDO Type I EDF Unit. jhamm Aircraft - Electric - Jets (FS/W) 1 Jun 06, 2010 08:03 AM
Question How to modify foam to fit larger EDF unit? Silverstreak328 Foamy EDFs 8 Feb 09, 2010 11:31 AM
Discussion How to balance an EDF impeller ? i3dm Electric Ducted Fan Jet Talk 7 Sep 16, 2009 06:07 AM
Discussion Looking to dynamically balance fans. Sniper.308 Electric Ducted Fan Jet Talk 4 Nov 18, 2008 02:12 AM
Discussion How to make a pitch gauge with a rubberband and a cell phone ? mguw Electric Heli Talk 0 Jul 28, 2008 08:58 AM
