How to dynamically balance EDF unit with a cell phone
Introduction We all heard this – loud whining sound of unbalanced EDF unit. There even were cases when pilots were banned from RC clubs for loud noise their EDF jets are making. The first advice people are usually getting is to balance a fan. There are magnetic balancers on the market that can do that job. But even if fan is perfectly balanced it still makes noise and vibration is all but gone. Reason for that is unbalanced rotor of the motor. One can choose a difficult path of balancing motor’s rotor but there is easier way to achieve smooth, quiet, vibration free running of EDF unit. This article will describe step by step process on how to dynamically balance an EDF unit at your home. Before we dive into details a little theoretical explanation will help understand the nature of vibrations in EDF unit and what’s need to be done to eliminate it. Theory To achieve our goal we need to look at EDF unit as a one unit of motor and impeller together. This picture shows typical distribution of centrifugal forces in EDF unit. Sum of two forces is not equal to zero and this is what causes vibration. To stop vibration we need to make one force cancel other force. Here are two steps to do it. Step 1: Align force vectors along one line, i.e. find fan’s position where heaviest point on the fan corresponds to the lightest point on the motor’s rotor. Step 2: Add weight to the lighter side to equalize forces, i.e. make fan’s heaviest point as heavy as motor’s rotor heaviest point. The sum of two forces will be zero or in other words two forces cancel each other resulting in no vibration unit run. Practical implementation To prove this idea works I needed something that can measure vibration level and give me a number so that I can compare levels in my experiment. The easiest solution I could find under my hand is a smart phone. Latest smart phones like iPhone and Android have accelerometers in them. This is a perfect tool to measure vibration level. There are several programs available on the market that will collect accelerometer data and produce output file. I purchased Sensor Insider Pro for my HTC Incredible running Android operating system for less than two dollars. This program will export collected data along all three axis to csv formatted file I can use in Excel for analysis. This is all I need. So here is my setup: 1. Cell phone attached to the EDF unit with two rubber bands Step 1 This is what we need to do to complete step one of the dynamic balancing. a) Mark motor’s rotor with a sharpieAll this should take about 10 minutes or so. There is no need to be precise at this point, few degrees more or less is not that important. Let’s export collected data to Excel, make a few calculations and build a spider chart to look at the result. By looking at the temperature diagram and spider chart we can say that minimal vibration level is 1.18 at the angle between our original motor and fan mark of 315 degrees. So what this information means to us? It means that at 315 degrees centrifugal forces of the impeller partially cancel centrifugal force of the motor’s rotor. And at approximately 315 degree angle two forces align along one line. The remaining vibration level of 1.18 is the difference in weight between the motor and the fan. Step one is complete! Step 2 In step one we found relative angle between fan and a motor where centrifugal forces align. In step two we find absolute location of that point where we need to apply more weight to make one force compensate another. How do we do that? You already know the answer – magnetic balancer! But we don’t have to use precise and expensive balancers. If you have one – great! The one I have has too large shaft diameter and I made another balancer out of a drill bit and a couple of magnets placed between vise jaws. Now, place a fan rotor in the balancer, spin it a little and wait till it calms. With Sharpie marker place a small dot on top-most point of the fan. Repeat this step five times. By the end you’ll see an area of dots close to each other. Just round this area with Sharpie – this is where we are going to place extra weight. I used white masking tape cut in ¼ inch squares. Based on construction of your fan and RPM you may need to use stickier tape or use different methods to add weight, like drops of CA glue or some other way. My fan is GWS-style where I can place tape pieces on top of the fan’s hub for measuring and when done move tape pieces inside the hub at the same location. Put fan back on the motor aligning mark we made in step one at 315 degrees, the angle of minimal vibration. a) Stick one square of masking tape to the area we rounded as lightest point of the fanAfter a few pieces of extra weight you will quickly see a dramatic difference in sound of your EDF. At this point data recording is optional but I’ll do it anyway to measure the result. At the point when next weight addition increases vibration unstick last tape piece, cut it in half and glue back one half. You can get as precise as you wish at this point. Let’s export collected data to Excel and take a look at what we’ve got. We can see that we hit vibration minimum when sticker number six was placed on the fan. By experimenting with smaller tape pieces between weights five a seven it is easy to find absolute minimum. In this experiment I just removed weight seven and left weight six unchanged. The result So what is the measurable result of our balance exercise? The result is amazing 91% reduction in vibrations of EDF unit! This is accomplished without expensive dynamic balancers, no tedious (and some times ineffective) fan balancing, no motor’s balancing. We got tremendous improvements with simple and relatively inaccurate steps. This result also shows how horribly unbalanced my EDF unit was. Subjectively I can say every time I rev up my four engine A-380 I can’t stop smiling and enjoy how she sounds. If earlier I was worried there will be complaints how loud this plane is now I am having hard time telling by ear what RPM’s my engines are working at when plane is in the air and have to rely on throttle stick position. And realistic jet sound during a takeoff is music to my ears. I also noticed significant increase in power of engines. The plane can climb at angles it could never climb before and stays level at 50% throttle, vs. about 75% when it was unbalanced. I wish I had thrust measurements when unbalanced to compare results. Conclusion It takes about 40 minutes to an hour to balance one EDF unit. One can go quick and “good enough” way to get 90% improvement or can be as precise and detailed to get that last percentage point. There can be variations to this method, such as instead of using accelerometers it is possible to use microphone or simply rely on your feelings. There is no need to know absolute vibration levels. Step one goal is to find that minimum vibration angle which is relative to other angles. And step two can be done without any measurements at all. You will know when you get that perfect weight by the smile on your face. ![]() I would like to thank my friend Dale who gave me initial EDF balancing idea from which it all started. Thanks buddy! -------------------------------------------------------- Alternative balancing method What if… you cannot rotate the fan? It may be glued to the shaft or impractical to unmount, the fan itself is statically balanced or you are allergic to a screw driver and magnetic balancer gives you a headache? Can EDF unit still be dynamically balanced? Unless laws of physics prove opposite the answer is YES! Here is how… Theory Let’s take a look at the EDF system and centrifugal forces when unit is working. Unbalanced fan produces force that is applied to the center of rotation (shaft) and directed toward its heaviest point (blue arrow). Unbalanced motor creates its own force which applied to the same center and directed toward its own heaviest point (green arrow). The resulting force of EDF system is sum of these two vectors (red arrow). In previous method fan unit is rotated to compensate one force with another. But what if… we create our own force to compensate? Take a look at the image below. By creating new counter force in our EDF system we effectively compensate existing force responsible for vibration. All we need is add counter weight at the right location. The steps remain the same. In Step 1 we find that location and in Step 2 we add necessary weight to compensate unwanted force. Before we start practical implementation there is one important point that deserves its own discussion. Where, or more precisely how far from the center of the shaft counter weight should be located? This may seem obvious but wrong place can result in unexpected consequences. The problem is the force created by rotating mass is proportional to the radius of rotation. Another words, one gram added to the blade tip creates stronger force than one gram added to the hub. This results in one level of vibration at low RPM and completely different vibration at higher RPM. For outrunner motors correct distance from the center of the shaft is where magnets are glued to the rotor. For inrunner motors answer can be more complicated, or instead much simplier, and probably should be discussed separately. Practical implementation First of all we need to find place on the Fan unit where counter force needs to be applied. We need couple of small squares of sticky tape. How many exactly can be determined experimentally. The counter weight should be small enough to not create too much stress and heavy enough to make measurable difference in balance. Step 1 a) Mark fan’s hub with a sharpie every 45 degrees. Make one of the marks different – it will be a starting point b) Stick counterweight to the starting point c) Start sensor’s data recording d) Gradually increase motor’s RPM to the max and back during approximately 10 seconds interval e) Stop recording and save result file f) Un-stick counterweight and move to the next point g) Repeat steps c-d-e-f until you reach angle of 315 degrees, which will be the last measurement point. The result should look very similar to the spider chart produced by Step 1 in previous method. There will be a minimum vibration point where weight needs to be applied to compensate vibration. Step 2 a) Stick counterweight to the minimum vibration point of the fan b) Add one more piece of tape c) Start sensor’s recording d) Gradually increase motor’s RPM to the max and back during approximately 10 second interval e) Stop recording and save result file f) Repeat steps b-c-d-e few times The data analysis is exactly the same as described in previous article. This method is less labor-intensive and much quicker than previous one. No screw drivers, no fan balancers, just phone and masking tape. |
This is a great idea, although I think it is working for a different reason than the one you explained.
[EDIT Ignore the following. you already knew this...] Your explaination is for static balance whereas you need to worry about dynamic balancing. However, your balancing method may well be getting your system reasonably well dynamically balanced , just like when you have your car tyres balanced (i.e. the guy spins the wheel which measures the vibration forces and calculates where two weights need to be placed - one on the inside of the wheel and one on the outside).See http://en.wikipedia.org/wiki/Tire_balance. You may be able to get it even better! [/EDIT] Well done. |
Some possible app for the iphone
Showcase: Vibration Turns Your iPhone into a Spectrum Analyzer http://www.macresearch.org/showcase-...ctrum-analyzer Turn your iPhone or iPod touch into a vibration spectrum analyzer http://www.macworld.com/appguide/app.html?id=67886 |
United States, WA, Gig Harbor
Z |
| Thread Tools | |
| For Sale Don's Wicked 4800 mounted in a dynamically balanced 64mm EDO Type I EDF Unit. | jhamm | Aircraft - Electric - Jets (FS/W) | 1 | Jun 06, 2010 07:03 AM |
| Question How to modify foam to fit larger EDF unit? | Silverstreak328 | Foamy EDFs | 8 | Feb 09, 2010 10:31 AM |
| Discussion How to balance an EDF impeller ? | i3dm | Electric Ducted Fan Jet Talk | 7 | Sep 16, 2009 05:07 AM |
| Discussion Looking to dynamically balance fans. | Sniper.308 | Electric Ducted Fan Jet Talk | 4 | Nov 18, 2008 01:12 AM |
| Discussion How to make a pitch gauge with a rubberband and a cell phone ? | mguw | Electric Heli Talk | 0 | Jul 28, 2008 07:58 AM |
