Old Jul 13, 2012, 08:39 PM
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
I received my green camo A-10 this evening and she is a beauty!!!
I noticed that the two esc's were the black 40A 2S-6S esc's which I was happy to see.
I couldn't get the esc's through the rear fuse hole so I unhooked the motors and fed the wires through from the cockpit opening.
I did power up the edf's and wow they are powerful! I'm using the nano-tech 2200mAh 3S 35-70C batteries.
I haven't glued the edf assembly on yet and was wondering if there is a way to use screws to mount it instead of epoxy glue? Would this be a good or bad idea?
I don't remember seeing anything about this in the thread.
Thank for your advice...
jer291113 is offline Find More Posts by jer291113
Old Jul 14, 2012, 06:17 PM
Heli and E-Plane
Joined Nov 2010
Need some advice!
My nacelles are glued together, what would be the easiest way to separate them without causing too much damage? Also two of the black plastic clips on the sides came off as soon as I removed the screws, they were glued on with hot glue to the painted recessed surface.
Old Jul 16, 2012, 02:35 PM
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I used silicone rubber glue...it has held for two years now and if I ever need to go back and take it out (used it on nacelles too for same reason) it is easy to cut through it. It damps vibration for the edf as a bonus!
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Jul 16, 2012, 02:42 PM
Heli and E-Plane
Joined Nov 2010
Russ
Thanks Russ for your reply, I was starting to think this thread was dead...
What type of silicone rubber glue did you use that doesn't eat the foam?
Thanks again...
Old Jul 16, 2012, 03:56 PM
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Just the regular stuff you can find at any auto parts or home depot or anywhere else. The most common is the blue packaging DAP brand I think it is. 100% silicone rubber won't harm foam (I've used on EPS and EPO foam no problems).
But check a small piece first just to be safe!
Old Jul 16, 2012, 07:25 PM
Heli and E-Plane
Joined Nov 2010
Okay! Thanks Russ appreciate the info.
Old Jul 22, 2012, 08:06 PM
gilford, new hampshire, usa
Joined Nov 2003
I would use lo temp hot glue. If you need to get back in there just soak it with a swab saturated with rubbing alcohol and it releases its bond and can be neatly peeled off.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Jul 22, 2012, 08:46 PM
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Unless you are in Florida or Texas
Hot glue melts in our temps.
Old Jul 22, 2012, 10:34 PM
bimmerland's Avatar
Joined Nov 2011
You can also use that black stick rubber that auto guys use to seal cracks. I think 3M makes it. I used it to seal the nacelles...
bimmerland is offline Find More Posts by bimmerland
Old Aug 03, 2012, 02:44 PM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
RIP. My A10 bit the dust. I'm still trying to find out what happened but the person I loaned it to did not have it long before it was demolished. Don't know how many flights it had amonst the 5 of us that flew (100? 200?) it but it had more than my $$ worth of flights. Buddy #2 who it was first passed to, got his own A10 and left the wheels on it, so I may still get more videos of one flying some day.
Melnic is offline Find More Posts by Melnic
Old Aug 03, 2012, 05:28 PM
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Melnic,
May she rest in pieces.
Old Aug 04, 2012, 02:52 PM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
He was flying it on 4S and pulled a too much elevator. The wing snapped. Wing was stock.
I got pics from him. He can't find the other wing that fell off during the break.
Old Aug 04, 2012, 09:22 PM
bimmerland's Avatar
Joined Nov 2011
Should have crashproofed it...
Old Aug 07, 2012, 11:21 AM
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
No such thing!
Old Aug 07, 2012, 01:37 PM
Canada
Joined Jul 2009
Had he "crashproofed" it by Killerplanes, it probably would not have sustained that kind of damage. Sure, it would still get some kind of damage but it likely would have been flyable right afterwards.
TOP TEN CRASHES - Crashproof RC planes! (2 min 4 sec)
I haven't crashproofed mine but this plane is so cheap, I would just buy another one.
xviper is online now Find More Posts by xviper
Discussion Nitroplanes Brushless A-10 uneven motor light off help JettaManDan Foamy EDFs 2 Aug 07, 2010 08:50 AM
Help! NitroPlanes A-10 Thunderbolt Brushless LiPo Battery / EDF Problem ISNJH Electric Plane Talk 13 May 12, 2010 07:56 PM
Discussion NitroPlanes A-10 Brushless EDF Initial Thoughts JettaManDan Foamy EDFs 1 Apr 28, 2010 07:41 AM
Video Nitroplanes OV-10 with Flycam one chevronflyer Electric Plane Talk 3 Apr 12, 2010 08:03 AM
Discussion Another A-10 conversion and Nitroplanes Warthog mal818 Foamy EDFs 8 Sep 14, 2009 01:08 AM
