Old Jul 06, 2012, 05:25 PM
carbonexpress is offline
Find More Posts by carbonexpress
FLYGIRLJAMIES'S DAD
United States, CA, Palo Cedro
Joined Jun 2006
mine did not come with a Y harness for the esc's, what control wires are you talking about? the servos all had leads long enough to reach the receiver on my kit.
Kevin
carbonexpress is offline Find More Posts by carbonexpress
Old Jul 07, 2012, 04:18 AM
tdearth is offline
Find More Posts by tdearth
USA, IN, Nineveh
Joined Apr 2002
Hi Kevin,
I am talking about the control rods that go from servo to control horn.
Tim
tdearth is offline Find More Posts by tdearth
Old Jul 07, 2012, 05:15 AM
tdearth is offline
USA, IN, Nineveh
Joined Apr 2002
I have another question.
They have left the red wire attached to both of the throttle ESC
connections. Shouldn't one of these red wires be disconnected?
Tim
Old Jul 07, 2012, 07:43 AM
FLYGIRLJAMIES'S DAD
Joined Jun 2006
mine was a very late kit I am assuming, as mine came with all the linkages installed. I did not remove one of the red wires from the bec either, did not even think about it when I was doing all of the setup.
Kevin
Old Jul 07, 2012, 08:39 AM
tdearth is offline
USA, IN, Nineveh
Joined Apr 2002
Thanks Kevin,
I assume that the ESCs worked all right then even with both of
the red wires on.
Tim
Old Jul 07, 2012, 09:04 AM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Originally Posted by tdearth View Post
Thanks Kevin,
the red wires on.
Tim
Mine's a PNP. There's no mention of cutting any wires. I left it the way it came and have been flying it like that since the beginning. No problems.
xviper is online now Find More Posts by xviper
Old Jul 07, 2012, 10:27 PM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
Finally read all the pages and just ordered the green Dynam A-10 ARF using a new discount code of 11% ...."NP11" at NitroPlanes.
jer291113 is offline Find More Posts by jer291113
Old Jul 08, 2012, 09:45 AM
Heli and E-Plane
Joined Nov 2010
This is my first edf plane and have two basic questions.
1. How can you tell if the fan is out of balance?
2. If so, how do you balance it ?
Sorry for such basic questions...but thanks for your advice!
Old Jul 08, 2012, 01:55 PM
Canada
Joined Jul 2009
I found with mine that right out of the box, the fans were not clearing the shroud very well, so I had to go in with a Dremel and grind off just enough in those places where they touched. If one or both fans are not balanced, you can sometimes feel it as a vibration when you spin it up or you can hear odd harmonics. If you really want to be sure, then you have to take the fans out and check them on a prop balancer. But then, you won't know if the motors are balanced. To balance the whole assembly becomes a fairly complicated trial and error exercise. These are not terribly high rpm fans, so if they run pretty good at max throttle, just leave them. Besides making clearance for the fans, I did nothing else to them.
Old Jul 08, 2012, 03:12 PM
Heli and E-Plane
Joined Nov 2010
Thanks Xviper for your reply!
Yes I did read here about the fan touching but it seemed to be normal and it should work itself out, but I will check to be sure.
I had read about balancing the whole assembly and it seemed very tedious to say the least. I always check all my servos and motors (wattmeter) before doing any assembly of my aircraft.
Thanks again for your assistance.
Old Jul 11, 2012, 01:11 PM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
WOW, these go "out of stock" faster than I can decide to buy one !!
And, then they stay out for a long while
old_dude is offline Find More Posts by old_dude
Old Jul 11, 2012, 02:36 PM
Heli and E-Plane
Joined Nov 2010
They still have a few different ones in stock, which one did you want?
Old Jul 11, 2012, 02:54 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
This is the latest coupon code good till end of today
http://www.nitroplanescoupons.com/co...escoupons.html
I'm trying to get a pic of my A10. I'ts now been passed to the 5th pilot and it's been through hell and back. Pilot #4 decided to run 4S with it. Its still a stock setup with added vent holes.
Melnic is offline Find More Posts by Melnic
Old Jul 11, 2012, 09:04 PM
old_dude is offline
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
I have already got all the equipment. I just need the airframe ..... which is sold out. Don't really like the green camo but it seems to be the only color avail in kit form.
Old Jul 12, 2012, 07:56 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I do like the green camo but had to put "invasion stripes" on the bottom to see it well. I just used white colored tape and thought I would paint the stripes on if I liked it that way. I think it's been two years, that tape is working so to heck with painting it
Russ
RGS2010 is offline Find More Posts by RGS2010
Discussion Nitroplanes Brushless A-10 uneven motor light off help JettaManDan Foamy EDFs 2 Aug 07, 2010 08:50 AM
Help! NitroPlanes A-10 Thunderbolt Brushless LiPo Battery / EDF Problem ISNJH Electric Plane Talk 13 May 12, 2010 07:56 PM
Discussion NitroPlanes A-10 Brushless EDF Initial Thoughts JettaManDan Foamy EDFs 1 Apr 28, 2010 07:41 AM
Video Nitroplanes OV-10 with Flycam one chevronflyer Electric Plane Talk 3 Apr 12, 2010 08:03 AM
Discussion Another A-10 conversion and Nitroplanes Warthog mal818 Foamy EDFs 8 Sep 14, 2009 01:08 AM
