Old Jan 11, 2012, 10:27 AM
impostor is offline
Find More Posts by impostor
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
great looking bird there Sammy!
impostor is offline Find More Posts by impostor
Old Jan 11, 2012, 02:18 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Slammin...Sammy!
RGS2010 is offline Find More Posts by RGS2010
Old Jan 24, 2012, 09:58 PM
Killerplanes is offline
Find More Posts by Killerplanes
Joined Aug 2010
bri23520- yes, our shipping prices are frequently pretty random. We were warned about USPS software, but didn't believe the horror stories we heard. Now I believe. If you want something, drop me an email at killerplanes@gmail.com and we'll make it happen-
Killerplanes is offline Find More Posts by Killerplanes
Site Sponsor
Old Jan 24, 2012, 10:12 PM
Joined Aug 2010
Sammy70- The Crashproofing kit for the Dynam A-10 weighs about 140g with the glue- the A-10 in our yootoob vid has it installed, so you can see it flying. The plane has lasted through LOADS (20 plus) of "minor" crashes (under 20MPH) and well over a dozen major ones, like the 70+MPH direct hit on a steel guy wire- still going strong over a year later!
Site Sponsor
Old Jan 27, 2012, 02:46 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
guys, there's a new 10% coupon out good till Sat night
Nitroplanes Coupon Codes
Melnic is offline Find More Posts by Melnic
Old Feb 02, 2012, 02:04 PM
Rogerdee is offline
Find More Posts by Rogerdee
Kapiti,NZ
Joined May 2006
Going for the crask kiit
Have been in touch with Steve and ordered a crash proof kit.
Will fit it to my second A10 as the first one is a bit battered.
Roger
Rogerdee is offline Find More Posts by Rogerdee
Old Feb 02, 2012, 02:12 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Just gotta love this plane!
On final...
Russ
Old Feb 03, 2012, 01:21 PM
nez_fer is offline
Find More Posts by nez_fer
Joined Oct 2011
4s on stock ESC?
Originally Posted by Isabeu View Post
So, I tested 4S on my stock ESC's and it worked great, HOLY the amount of power difference! I had to borrow a couple 2S batteries and run in parallel to test it out, but it's pretty well confirmed at this point. Check your ESC's to make sure they read the higher stats and you should be good to rock 4S off the bat.
He stated a couple of 2s batteries setup in parrallel. He must have mean in series. I just checked my stock ESCs. They are the black DETRUM 40amp 2-6s lipo. 4s is running these 64mm now, but in my home built F22.
nez_fer is offline Find More Posts by nez_fer
Old Feb 03, 2012, 10:45 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
My buddy Kieth flying my A10
Nitroplanes Dynam A10 flight by Kieth (4 min 7 sec)
Old Feb 04, 2012, 07:35 PM
RugFlyer is offline
Find More Posts by RugFlyer
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
Originally Posted by Sammy70 View Post
We had some super nice weather last weekend (for Jan. in Ohio that is) and I managed to get the A-10 done in time.
Running stock fans (after MUCH balancing), stock motors, real 40a escs (not the stock yellow 30a units with the "40a" sticker on them), 4s 2650mah lipo which all combines for about 60a combined and about 1000w. Also, no landing gear.
Added some red highlights to help with orienation and finished it all off with a few coats of DULL coat and it looks tons better in my opinion. Had to get a pilot in the office as well.
Having flown the old GWS A-10 a ton I'm familar with the amount of "UP" elevator these A-10s need for normal flight.
Well, I dialed in about 3mm of UP but 4-5mm would have been better as....... She ALMOST bit the ground just after the hand launch If it weren't for being on high rates and 1000w on tap I think she would have hit the ground. As it was she leveled off literally about 3" off the deck and flew out fine. About 4 clicks of elev. trim and she was tracking great. Cruise nicely and WOT is in the 60-70mph range easy.
Sadly my cameraman was absent due to sickness, but I did snap a couple "before" shots on the ground...
Long live the Hog...
Nice Job Sammy!
I like your added red highlight accents, looks familiar. http://www.rcgroups.com/forums/showp...&postcount=401
RugFlyer is offline Find More Posts by RugFlyer
Old Feb 04, 2012, 07:48 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by RugFlyer View Post
Nice Job Sammy!
Thanks RugFlyer.
I had the same red accents on my old GWS A-10 so I just had to duplicate it on this new one...
Sammy70 is offline Find More Posts by Sammy70
Old Feb 06, 2012, 12:04 PM
XSSSIVE is offline
Find More Posts by XSSSIVE
XSSSIVE's Avatar
United States, NV, Reno
Joined Dec 2011
There's a new one at Nitroplanes: 10% off everything. I just order the A-10 ARF with 4 batteries.
This will be my first to fly of the EDF's. I have the F-18 and F-15, but haven't flown them. I think the the A-10 will be a good step towards the faster EDF's.
XSSSIVE is offline Find More Posts by XSSSIVE
Old Feb 06, 2012, 03:15 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I thought it was Sat night, but it was reall Sun night the end of the superbowl.
Looks like the 10% is still working today though! Maybe they forgot to take it down?
There's also one on an A10, it's the Gray one only though. Tried it on the Green one before I tried the one that was supposed to be expired.
Old Feb 09, 2012, 11:21 PM
XSSSIVE is offline
XSSSIVE's Avatar
Joined Dec 2011
Engine problem
I received my Dynam A-10 today from Nitroplanes. Before assembly I checked the engines. Only one will run. The right engine that won't run is also beeping. See video: http://youtu.be/UyE_FrlHuk4
Suggestions?
Old Feb 10, 2012, 01:30 AM
kingsnake11 is offline
Find More Posts by kingsnake11
kingsnake11's Avatar
Langley, British Columbia
Joined Oct 2009
Suggestions?
Hi XSSSIVE
had the same problem. Finally had some good weather last weekend and finally was able to maiden my A-10. Before taking it to the field I did a power test and had the same problem you describe. What I did was switch the wire attachements from the esc to the dud motor ( mine non working and beeping engine was the left one). Ok, even though the wires are colour coded with heat shrink, what I found was that the colour coding wasn't correct. Switiching the connections finally resulted in the engine working properly.
ks
kingsnake11 is offline Find More Posts by kingsnake11
Discussion Nitroplanes Brushless A-10 uneven motor light off help JettaManDan Foamy EDFs 2 Aug 07, 2010 08:50 AM
Help! NitroPlanes A-10 Thunderbolt Brushless LiPo Battery / EDF Problem ISNJH Electric Plane Talk 13 May 12, 2010 07:56 PM
Discussion NitroPlanes A-10 Brushless EDF Initial Thoughts JettaManDan Foamy EDFs 1 Apr 28, 2010 07:41 AM
Video Nitroplanes OV-10 with Flycam one chevronflyer Electric Plane Talk 3 Apr 12, 2010 08:03 AM
Discussion Another A-10 conversion and Nitroplanes Warthog mal818 Foamy EDFs 8 Sep 14, 2009 01:08 AM
