United States, NC, Asheville
Joined Jan 2009
I was happy to receive my 'green' version yesterday. I was a bit worried about what the condition of the parts might be as I opened it up, but luckily all the parts came out fine.
The problem was the packing....I mean the parts were just sitting inside surrounded by cardboard, but no cushion anywhere. The foam parts were allowed to just rattle around inside the main box. I couldn't believe they weren't bent or gouged out. I have the 'kit' version and just got 2 Don's wicked 4800kv motors/64mm EDO fan unit combos to install. I also have my micro air retract set to install. I am real impressed so far with the foam parts. Everything seems strong, well engineered with a nice painted finish. I have to finish up a couple of other projects first, but hope to get working on this plane soon. I am real interested in your work on the stab incidence DJ. I will also be looking to try and fix this...I agree, it's just not right to have to fly around with the controls displaced to compensate for a design issue. Keep up the good work guys! Ken |
Joined Jan 2009
Ken, welcome to the crew
....look forward to seeing your retract installation....Horizontal wing incidence .... what im looking at doing is..instead of 3mm of up elevator im going to put a wedge in to make the whole horizontal stab rise at te 1.5mm...that should give it the lift it needs plus it will look the way a real A-10 is...DJ |
Larger LG Wire
Thanks DJ for the kind words.
How will you get the larger wire to stay in place? Assuming that you will drill out the current mount??? ...use different mounts??? I would love to use the shock absorbing kind of LG...I noticed a set at HK for $16 that I thought about monkeying around with...only thing is that they are white, would have to paint 'em. Russ |
CSI,
Most the foamies don't take much damage cause the foam is light and don't bend/dent under their own weight (usually). Airfield(FMS) does a better job of taping things down than say Dynam does though. Air retracts? cool, I'd love to see that. We have to belly land on our grass field for stuff this small.
Joined Jan 2009
Swps, wish i cud answer ur ? but my nacelles are all buttoned up and sealed now...DJ |
Shock Absorbing LG link
Forgot to include link with last note:
HK landing gear: http://hobbyking.com/hobbyking/store...idProduct=4681 Russ |
The legs have a little rotational slop in them & the weak point is in the thin plastic base that the aluminum legs attach to. The mains on both my planes have broken there. But with some added epoxy at the plastic base and a few adjustments they're a cool addition for anyone wanting a scale looking LG with suspension! |
Magic Carpet Man
You were reading my mind...I have a T-28D that I was considering these LG for later in addition to the A-10!
Thanks, Russ Quote:
Joined Jan 2009
Ken, im using two of the edo 4800kv motors and fans in my 4s setup...it will be interesting to see how they compare..too bad we are not closer so we could do a side by side comparisom...
rug dang man thats a 15% price increase...dont inflation suck !!! haha... DJ |
Keep us posted on your A-10 build w/ the edo 4800kv motors and fans on 4s, should be a Rocket! |
I will keep things posted as I go with the build. I went with the Don's wicked 4800 motors so I could have the option of using 3 s or 4s lipos. All my other jets are on 4s only, so am hoping these higher KV motors will work on 3s as a pair. At least I have plenty of 4s packs as needed!
I got the micro air retracts last year from HC. I have 2 sets of them that have just been patiently waiting for a plane. They have felt pretty lonely sitting in the package all this time.................. Ken |
| Thread Tools | |
| Discussion Nitroplanes Brushless A-10 uneven motor light off help | JettaManDan | Foamy EDFs | 2 | Aug 07, 2010 08:50 AM |
| Help! NitroPlanes A-10 Thunderbolt Brushless LiPo Battery / EDF Problem | ISNJH | Electric Plane Talk | 13 | May 12, 2010 07:56 PM |
| Discussion NitroPlanes A-10 Brushless EDF Initial Thoughts | JettaManDan | Foamy EDFs | 1 | Apr 28, 2010 07:41 AM |
| Video Nitroplanes OV-10 with Flycam one | chevronflyer | Electric Plane Talk | 3 | Apr 12, 2010 08:03 AM |
| Discussion Another A-10 conversion and Nitroplanes Warthog | mal818 | Foamy EDFs | 8 | Sep 14, 2009 01:08 AM |
