Jul 03, 2010, 07:05 AM
Goshen, Indiana, United States
Joined Jan 2003
Usually when you go multi blades you go a little smaller any how ... so 325 probably would be about right or worth trying .
The only other thing you could do to make sure the head is beefy enough is to buy a 500 size (8mm ) and then make a bushing down to 6 mm shaft size !!!!!
If you go the 450 size I would suggest ,,DON"T get the lighting heli one or the heli artist .... get the copter X or aerodyne one as the others are really made cheap (cheap metal and construction )
Good luck
Larry
