Old Jun 29, 2010, 03:23 AM
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by jj604 View Post
Actually that's what I wsa suggesting in my first set of improvements number 3. "Each of LV alarm, 6x cell voltages and the current would flash in turn for say 3 secs and while flashing you use the Bind or Power button to increment or decrement the value".
The reason I put it there was it could be done without any physical change to the unit by adding another switch. Just needs a firmware change.
Yep and if they are willing to make a firmware change, then they could also create a pc program communicating with the USB port so you can do all settings/offset changes explained above in item 2 via this program
jaccies is offline Find More Posts by jaccies
Old Jun 29, 2010, 03:25 AM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
It needs at least two cells "live" to run and if you put the variable signal on another pin you have a common ground problem.
You can't feed the signal into the current sense input as that is 3.3V digital logic not analog.
If only one battery is used to power the BEC and motor (the entire aircraft), wouldn't the -ve all go back to the battery? i.e. a common ground?
As for the input voltage, the RSSI voltage will need to be adjusted (amplified or reduced) so that it falls between 3.3 to 4.2 volts.
Maybe I'm naive, but I don't see why this is an impossible thing.
BB
borneobear is online now Find More Posts by borneobear
Old Jun 29, 2010, 03:26 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Absolutely, that's a good solution. However that's only useful as a secondary method. Setting alarms etc needs to be able to be done at the field and most folks don't cart around a PC with them when flying.
jj604 is offline Find More Posts by jj604
Old Jun 29, 2010, 03:29 AM
Joined Dec 2008
right but at the field you need to change only the lipo capacity for the 20% alarm when using different lipo's at the field, the rest you do once athome
Old Jun 29, 2010, 03:32 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
See if I can explain without a picture.
The Quanum ANALOG cell voltage measurement occurs by a voltage between 3 and 5V across each pair of pins.The device logic requires a voltage between pins 1-2 and 2-3 for it to work. Any more (3S-6S) are optional but there has to be a voltage across every pin from 1 up to the last one. If you connect a separate 0-5V analog signal between two pins. the -ve has to go to a pin that alreday has a cell +ve attached.That cell then has it's +ve connected through to its negative via the Rx ground. It's easier to understand if you sketch it out.
Originally Posted by borneobear View Post
If you use only one battery to power the entire aircraft, would the ground all go back to the battery -ve? i.e. a common ground?
BB
Old Jun 29, 2010, 03:42 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
Thanks, I've added the idea as #2 in Post 5.
right but at the field you need to change only the lipo capacity for the 20% alarm when using different lipo's at the filed, the rest you do once athome
Old Jun 29, 2010, 03:43 AM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Yes I get it now.
Pins 1-2 & 3 must be connected to the battery.
RSSI input comes in from say pin 3 to 4.
But its not actually the RSSI input. Its an indirect connection via a rail-to-rail I/O OpAmp. So the supply is coming from the battery cell leads, but adjusted (indirectly) in relation to the RSSI value via the OpAmp.
Is this workable?
BB
Old Jun 29, 2010, 04:09 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
Suggest you ask this on the electronics thread where there are folks who know a lot more about this than I do.
Here's a very crude picture that may help. Feel free to use it.
The black wires show the short caused by the common ground.
John
Yes I get it now.
Is this workable?
BB
Old Jun 29, 2010, 09:57 AM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Its a very nice diagram by any standards John. Thanks.
The system should definitely not be wired like that. High chance of seeing expensive smoke.
BB
Old Jun 30, 2010, 04:01 AM
Joined Dec 2008
3) The current sensor is an Allegro ACS755xCB-100. This is a 100Amp rated Hall effect sensor - data sheet here http://www.allegromicro.com/en/Produ...5/0755-100.pdf
oops the hall sensor is a Discontinued Product!!!!!
Old Jun 30, 2010, 06:13 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
Just means they have replaced it with a newer model last month with improved specs. A month ago it was the bee's knees. Maybe Quanum got a cheap job lot when it was discontinued!
Old Jul 03, 2010, 04:50 PM
gr8
Finland
Joined Nov 2006
Hi
Thx for very good info about this system!
I still have few questions:
What is the minimum cell voltage and alarm threshold? Can this system be used with A123 cells?
and what is mAh alarm range? I assume it is 0-9999mAh
gr8 is offline Find More Posts by gr8
Old Jul 03, 2010, 05:30 PM
ancora imparo
jj604's Avatar
Joined Jul 2005
I didn't try it below 3.2V and yes it works with A123's. You get the default beeper at 3.2V (measured at 3.24V on mine) which you can't turn off though and would drive you nuts.
Well you can - with a pair of sidecutters and by opening the case . But be careful with the two tiny switches - they fall apart if you look at them when the case is open.
I'll have a look at it again today and check the lowest voltage and max mAh for you.
Regards, John
Originally Posted by gr8 View Post
Hi
Old Jul 04, 2010, 07:32 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
Voltage range
It turns out to be a bit tricky to measure all 6 cell voltages over a wide range since the first two cells (Pins 1-2 and 2-3) draw significantly more current than all the others. The Tx gets its power from the voltage across pins 1 and 3 obviously. So a simple variable supply and resistor network won't work.
I tested it originally with charged and discharged LiPos and a discharged A123 and found the voltage accuracy across all 6 fine.
I have edited Post 5 to add some info on what happens when you vary the voltage across the supply (ie Pins 1,2,3).
In short it keeps working accurately for cell voltages from 2.0 - 5.0 Volts. You can't change the beep from 3.2 volts though.
John
Old Jul 13, 2010, 09:54 AM
Joined May 2009
HI!
If you want pro telemetry systems which monitors current, voltage and consumed amps look this.
Jeti Duplex 2.4 GHz system
http://www.jetimodel.com/index.php?p...d=0&category=4
http://www.jetimodel.com/index.php?page=product&id=22
"MUI sensors allow setting of acoustical signals in order to announce violation of set parameters. Such alarms may be set for measuremets of maximum current and minimum voltage as well as for a maximum of consumed battery capacity. The sound signal is generated by a siren integrated in the transmitter module. For better differentiation are the particular alarms distinguished by Morse alphabetic letters. The acoustical alarm generation in case of parameter violation is working even if the JETIBOX is not connected. With the JETIBOX in place the LCD display shows which parameter has been violated. In case of violation of several parameters the alerts alter consecutively as well as the indications on the LCD display."
bigbear_fin is offline Find More Posts by bigbear_fin
Cool Picked this up at the post office last night. The Quanum 2.4ghz lipo telemetry unit cryhavoc38 Batteries and Chargers 282 Dec 11, 2012 08:26 PM
Discussion Quanum battery voltage telemetry - and 'voltage under load' question ... JJJNYC Batteries and Chargers 40 Dec 15, 2010 08:45 PM
Question Quanum 2.4ghz Telemetry DjBac Batteries and Chargers 21 Nov 29, 2010 02:43 PM
Alert $70 BUCKS! Quanum 2.4Ghz voltage telemetry (1km Range) jet-ster Foamy EDFs 42 May 27, 2010 11:54 PM
Discussion quanum 2.4 ghz telemetry sellman Electric Plane Talk 3 Mar 29, 2010 11:00 AM
