Old Jun 18, 2003, 05:26 PM
PilotMike is offline
Find More Posts by PilotMike
United States, NJ, Plainsboro Township
Joined Apr 2003
Breaking in GWS EDF-50's?
Should the small gws edf-50's be broken in before flight? If so, what's the best method?
PilotMike is offline Find More Posts by PilotMike
Old Jun 18, 2003, 05:58 PM
hyperknight is offline
Find More Posts by hyperknight
hyperknight's Avatar
Irvine, CA
Joined Apr 2003
The concensus is NO. Just plug it in and run it.
hk
hyperknight is offline Find More Posts by hyperknight
Old Jun 18, 2003, 08:35 PM
DR. JOY is offline
Find More Posts by DR. JOY
Stay thirsty my friends.
DR. JOY's Avatar
United States, SC, Greenville
Joined Feb 2003
I concur.
DR. JOY is offline Find More Posts by DR. JOY
Old Jun 19, 2003, 12:43 PM
Joined Apr 2003
Thanks for the help guys! My edf 50's are already in place in two A-10 nacelles, raring to go!
Old Jun 19, 2003, 10:04 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
those little motors don't last very long anyway, the only time they should be spinning is in the air
Robbie d is offline Find More Posts by Robbie d
Old Jun 19, 2003, 10:38 PM
cyberfly is offline
Find More Posts by cyberfly
cyberfly's Avatar
Joined May 2002
Yeah, when you discover the motor has problem the next is your Air plane
cyberfly is offline Find More Posts by cyberfly
Old Jun 19, 2003, 11:29 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
Lube the front and rear bushings with slick 50 in the pump can. You'll need to use a exacto blade and bore a hole in the motor hood to do the rear bushing, only a small hole is needed. The reason that I had with mine burning up is that the front bushing scored from the rpm heat produced by the shaft. This in turn caused the motor to seize up and burn up. The new motor I bought I slick 50'ed the heck out of it and after every session I oil it before I put it away. I have about a hour and change on it with the 5 blade prop. The other thing I noticed is does't get as hot as the old on did, its real warm but not hot. Good luck with it.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Jun 19, 2003, 11:36 PM
Joined Apr 2003
While on the subject of replacing short-lived edf-50's, who has them at the best price? Also, does it matter much whether you get the 2020's instead of the 2030's?
Old Jun 20, 2003, 10:56 AM
David A Ramsey is offline
Find More Posts by David A Ramsey
New Jersey, USA
Joined May 2003
Best price on GWS EDF-50
PiolotMike:
balsaproducts.com has been advertising closeout prices on EDF-50 (2020x3) @ $9.00 and EDF 75 (3043x6) @ $11.00. I just checked their site and while there still showing the EDF-50 @ $9.00, Their out of stock with a note to "notify me when available" Not sure what their up too? I purchased 2 of each while I had the chance.
As to 2020x3, or 2030x3, I've tried both, plus 2030x5. For my application in my Learjet23, currently posted in "Jets" I found the 2020x3 gives best performance and flight time on 7 cell, 720mAh, Sanyo Nimhs. 7 to 8 min. @ 1/2 power.
So far I have 63 min. logged on a pair of EDF-50s and still running. I did initially run them in parallel on 3V alkaline for break in till battery ran down. Not sure if it helped, but I felt better. Lubricating makes sense.
David A Ramsey is offline Find More Posts by David A Ramsey
Old Jun 21, 2003, 02:08 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I use Marvel Mystery oil. I break in the mtrs. w/110mah 2.4v>
no load, till batt. is dead. I donot use the edf's, but in the IPS-A
gear drives w/carbon brushes, the power is better, and mtrs. last longer. I use up to 8 cells on the carbon brush mtrs after break-in. Not using full power except for launching and some of the manuvers, mostly 75% power.
Since doing the breakin & oiling, they last much longer. Infact my Guillows hellcat, initialy wore out 3 mtrs, fast. Present mtr has over 30 flights, still going strong.
Steve
St. Martin is offline Find More Posts by St. Martin
Old Jun 21, 2003, 04:42 PM
New Jersey, USA
Joined May 2003
Oilite bushing always seem a bit happier with a bit more oil.
David
Sold GWS EDF 50's dumbthumbs Aircraft - Electric - Helis (FS/W) 1 Jun 04, 2005 10:48 AM
FS - two GWS EDF-50's plus ICS-400 Esc (new) joegib Aircraft - Electric - Airplanes (FS/W) 2 Oct 03, 2002 07:48 AM
Qualcomm's Won't work in the GWS,EDF-50 mtflyr Electric Ducted Fan Jet Talk 5 Jun 14, 2002 10:15 AM
WTB GWS EDF 50's kepople Aircraft - Electric - Airplanes (FS/W) 1 May 08, 2002 03:35 PM
Department store glider W/2 GWS EDF-50's flies... rlinscheid Electric Plane Talk 16 Jan 19, 2002 06:56 AM
