Old Mar 21, 2011, 08:21 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Originally Posted by Burma View Post
I am waiting on the DX6i DMSX and the 120 SR BNF to get here and anticipation is high.(I'm stoked!) what i need to know is other then trim, what programming needs to be done to get things right, if any? I think I have enough experience to fly with the swash plate on the advanced balls and will change them out before first flight also zip tie the motor to the frame and look real hard at the skid peg that goes through the frame that is supposed to be harmful to the servo gears in a hard landing. But does the Trans need programming?
No, all the default settings will work, except I think You need to change the "gyro" to 0 and 100% if you want to use the receivers built in dual rates.... I never use the dual rates on my 120sr, but I do on my MSR....
dacaur is offline Find More Posts by dacaur
Old Mar 21, 2011, 08:25 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Chanel 5 controls the internal dual rates and i learned that by defualt if you dont regulate chan 5 its set to low.. so it must be set to as dacaur sais 0 and 100% (for example) or it will be on low rates (as i discovered by the hard way)
JLT_GTI is offline Find More Posts by JLT_GTI
Old Mar 22, 2011, 06:19 AM
JHawk19 is offline
Find More Posts by JHawk19
Buy, Mod, Fly, Sell, Repeat
JHawk19's Avatar
United States, SC
Joined Apr 2008
Originally Posted by JLT_GTI View Post
I have to take-off my 120 "fast" , applying power fast because if i try a soft slow take off it wants to tip over front and to the left.. its that normal?
Try wider, lower landing skids. Two example photos are below.
I have a couple of minor "soft crashes" , no damage at all.. but one of them (in tall soft grass) was while i was doing forward flight.. the helicopter began loosing altitude.. i gave it more power and it just went faster into the grass..
Always, try to chop the throttle before hitting the ground or any object for that matter to reduce potential damage.
Also while trying some hovers.. it still has this TBE , it sometimes remains hovering but doing those circling movement .. tought using controls to counter it.. it can be reduced to practically zero..
Try tightening the blades slightly. The blades shouldn't fall/move when the 120SR is picked up. If you tap them, they should move though. This could reduce the TBE.
JHawk19 is offline Find More Posts by JHawk19
Old Mar 22, 2011, 07:00 AM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
I did a low budget landing gear as seen in previous page .. even so it really has an almost violent tendency to tip over frontly when trying to do a soft take off.. like if it was at full forward stick.. but its not.. and once it gets airbone all that dissapears
Well... we discussed this before.. i saw a video wich recomended tightening them a bit to avoid TBE, i did it at first and still had it..then some guys here said they had floppy blades and they didnt had BTE, i loosened them a bit and same results..
And i cant see any damage in the head or blades
Old Mar 22, 2011, 12:49 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Well well ...
In a quite nice strike of luck.. today while i was at the LHS looking for fiberglass (wich nobody has in like 300km away) look what i found :
Yeap.. the very same fuselage i was thinking in buying some time to adapt to the Blade 120SR.. i will not adapt it now.. first i want to get the hand on this bird.. but so far things look promising:
Lenght is really similar.. i think that to adapt this i will have to use the method of loosing the tail boom and embeb directly the tail motor in the fuselaje right?
This fuse only looks like a couple cm longer anyway.. its almost a perfect fit..
For those who were asking how much this fuse weights:
Looks fine right?
Also weighted the 120SR with the low budget training gear without battery:
More usefull if i knew how the 120SR weights empty without batt.. i weighted the 120 without both gears (training and standard) and it came at 87g .. that means that both gears are 30g wich is more than the Huey fuselage weights
Also the Huey fuseleage comes with a couple leds with cables included... dont know if they blink by themselves or controled by the Lama A300 board.. but could be usefull for later
Old Mar 22, 2011, 01:17 PM
JHawk19 is offline
JHawk19's Avatar
United States, SC
Joined Apr 2008
Good luck. It'll take some work, but I'm sure you can get it to fit. You'll need some modified landing gear too.
Old Mar 22, 2011, 04:14 PM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
You better hire Scotty to get WARP power to lift that heavy canopy.
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old Mar 22, 2011, 04:42 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Ron
Have you even readed my post?
Old Mar 22, 2011, 04:57 PM
A Rdnek is offline
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
Well no, I cannot say that I have "read all" of your posts. But I can see that, that canopy weighs 25% of the total weight of the helicopter. That is TOO much. That will require a LOT of head speed to pick it up and even more to do much flying. That equals a LOT of heat. Your main and tail motors are not going to do that for any length of time. Unless you have found the magic bullet that allows you to make great amounts of power without generating excess heat.
Before you go much further with this project, try this. Find the difference between the weight of the stock canopy and your new one. Add that much weight to the sides of your stock canopy and give it a test flight.
Good Luck, I wish you the best of success.
Ron
Old Mar 22, 2011, 05:22 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I tried one of those same ESky fuselages on my Quark, which is close to the same size as the 120SR, but weighs more and has a brushless motor. It definitley effected performance and handling. Aside from the weight, it alters the CoG and air flow over the body.
Balr14 is offline Find More Posts by Balr14
Old Mar 22, 2011, 05:59 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Well.. the fuse weights 23g , and now the heli is flying with a 30g (minus the weight of the standard plastic gear) training gear and it does ok and actually it takes about the same throttle % to hover.. (arround 40-50%)
Obviously the fuselage will have definitilt an effect (and not for the better) on the flying performance .. but this bird is allready have been moded with other similar fuselages and appears to fly fine:
Old Mar 22, 2011, 06:10 PM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
Strange batteries
Hey Guys,
Is that "normal", that the stock batteries just picket from the fridge (not frozen just about cooled down to 5-10 Celsius) and try flying and usual they can keep about 1 min flying...or less...
BUT after just plug to the charger and after fully charged and keep rest for few min, they give me normal +5mins flying!
I have three stock batteries, all do the same...
I have two Tenergy 15C 550mAh batts, they are normal, took out from the fridge and the give me 7mins flying...without issues....
B.
bulesz is offline Find More Posts by bulesz
Old Mar 22, 2011, 06:15 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Originally Posted by bulesz View Post
Hey Guys,
Lipo batteries really hate cold.. in cold weather they perform a lot less than usuall .. many people even make "blankies" and pockets to isolate the small lipos in microplanes when flying in cold weather
Old Mar 22, 2011, 07:26 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Hey Guys,
B.
Why are you keeping them in the fridge? Lipos shouldnt NOT be kept in the fridge.
Like JLT_GTI said, lipos dont do well in cold temps.
The cold increases internal resistance, and basicaly lowers the C rating of the battery. So a 500mah 12C battery becomes a 500mah 5 or 6C battery, which is unable to supply enough power to fly the heli for long, the voltage drops and LVC kicks in.... The tenergys have a higher C rating, so even with the higher internal resistance from being cold they can still supply enough power, but its still not good for them....
Old Mar 23, 2011, 06:22 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
because need to storage them in dry and cool place, like here at #5th in the list:
http://www.rctoys.com/pr/2007/09/25/...o-care-lipoly/
Discussion E-flite Blade SR 120 Thread. sonicjet Micro Helis 21190 Sep 17, 2016 07:50 PM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
