Old Sep 14, 2010, 02:03 PM
Hink64 is offline
Find More Posts by Hink64
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
You are halfway to a Hellcat - nice application (heck of a lot easier than the contraption I doing) - how does it handle on the ground?
Hink64 is offline Find More Posts by Hink64
Old Sep 14, 2010, 02:46 PM
robusp is offline
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
when I first tried it with T28 wheels, prop was too close to the ground. With 60mm it will land on very short grass.There is no problem at all on blacktop. I should of mounted them closer to the leading edge of the wing. And I had to put slight bend in the wire to set them farther forward.
I added some fluorescent yellow to the top and sides of fuselage. I flew 4 times today including early morning and it was great. I don't know if this plane can take a place of my T28, but it is fun and doesn't take much room in the car.
Rob
robusp is offline Find More Posts by robusp
Old Oct 29, 2010, 10:09 AM
TX79 is offline
Find More Posts by TX79
United States, NY, Cohoes
Joined Oct 2010
F4F Wildcat is an awesome plane!
TX79 is offline Find More Posts by TX79
Old Dec 09, 2010, 09:21 PM
Energy is offline
Find More Posts by Energy
Canada
Energy's Avatar
Joined May 2009
I love this plane! I may have to buy one after i do some playing around with my new radian. Only thing a don't like about it is the little foam dimples on the wings and fuse. Looks kind of cheap. I may have to sand those off.
Energy is offline Find More Posts by Energy
Old Dec 09, 2010, 09:29 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Man, only 35 replies?
Not much of a plane?
~EDIT~
Here is the real thread.
microflitedude is offline Find More Posts by microflitedude
Old Oct 29, 2015, 07:52 PM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Originally Posted by greenseaships View Post
I suppose this means no Hellcat for a long time...
Good job!
Lots of good Hellcats out there to chose from.
That was a labor of love.
Wamp is offline Find More Posts by Wamp
Old Oct 29, 2015, 07:54 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Originally Posted by A1TANGO View Post
Hi Guy's,
Got my self one this last monday.
Today will bring it to the club and do some wathering and detail's on it while my mentor buddy scale master will be around flying his Wildcat ...
Not shure my will fly off today for maiden. It will go if my detail's are done and if weather wind permitted later in the evening with my mentor on the control.
My powerplant, stock motor, E-Flight ESC 30A, E-Flight 1800mah lipo's,
and a 3 blader prop's to bleed the air around ...
Congrats, and good luck. Welcome to the thread.
Old Oct 29, 2015, 07:56 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Fly it like you stole it.
I did not have luck removing dimples. Next spakel.
May be some one has a goodprocedure.
Old Oct 29, 2015, 07:57 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Originally Posted by robusp View Post
I didn't put retracts on it, but main gear from Trojan and home made trailing steerable wheel.
I like how it flies, but I have a problem seeing it early morning or late in the day when sun is lower.
Have to come up with some contrast markings.
Maybe I am just not used to dark planes. All others are white with the exception of orange white Extra 300.
Rob
Striking! Ground looper?
Old Oct 29, 2015, 07:59 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
No problem with wings. I mounted the wheel bases real close to the root of the wing. Wheels can handle the lighter plane.
I made the tail wheel out of 1/16 wire. Fed it through bottom of fuselage (there is a piece of antenna tubing) and in to the rudder between the screws.
Rob
Great!
Old Dec 16, 2015, 06:47 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Made note:
Grayson Hobby (Georgia) has one BNF Wildcat @ $179.00 left.
Duke it out guys. I'm out :-(
Discussion Parkzones New Warbird F4F Wildcat ChuckTseeker Electric Warbirds 841 Jul 23, 2010 06:57 AM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
F4F Wildcat Foam Parkflier Pic J Morgan Foamies (Kits) 58 Jun 28, 2003 11:13 AM
