Old Jul 01, 2010, 10:53 AM
Telemachus is offline
Find More Posts by Telemachus
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
As you saying the switches need to be in the up position or the down? Mine is a V2.and flashes fine... But I always leave the switches up/back
Telemachus is offline Find More Posts by Telemachus
Old Jul 01, 2010, 11:07 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I think a better way to describe it would be if they are pushed towards the front or towards the back.
crucial is offline Find More Posts by crucial
Old Jul 01, 2010, 01:49 PM
joan is offline
Find More Posts by joan
Johannes
Switzerland, Vaud, Lausanne
Joined May 2010
@telemachus: can you flash it regardless of the thr and ail switch position? For my th9x, MISO/MOSI have high potential if the switches are in the position that would give `switch error` at startup that is the 'up position'!
joan is offline Find More Posts by joan
Old Jul 01, 2010, 04:47 PM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
I have only tried it with the switches in standard position, and will probably continue to do so.
Old Jul 01, 2010, 04:57 PM
joan is offline
Johannes
Joined May 2010
well, you could simply try if your programmer connects to your Tx with avrdude. If it doesn't work avrdude states a wrong signature...
but thats interesting, your v2 is different from mine... I wonder whose Tx is the weird one, I guess mine is a monday morning Tx
Old Jul 01, 2010, 10:23 PM
reacher10 is offline
Find More Posts by reacher10
reacher10's Avatar
United States, NY, Shirley
Joined Oct 2008
I programed & flew 3 models today. I have slight servo movement when I switch between high and low rates, not all surfaces just some, elevator was one of em. I used the new dual rate menu.
Because it was windy I couldn't tell the effect on the trim. Tomorrow morning if the wind is down I'll see if there is any effect on the models.
But there really shouldn't be any servo movement at all.
Overall though the lastest release is a big improvement, I'm happy. Ya gotta love the price of this thing and what you're able to do with it now.
I don't fly helicopters so I really have no idea how hard it would be to program one.
Thus...You Rock!
reacher10 is offline Find More Posts by reacher10
Old Jul 01, 2010, 10:28 PM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
How much trim and subtrim do you have on the affected channels? If you have a lot of subtrim, it sounds like it gets reduced by the dual rate just like stick movement does.
If you have your subtrims zeroed do you see any movement with dual rates? If not, then it's a software error not holding the trimmed neutral position, and is instead acting like your radio has mechanical trims.
F-111 John is offline Find More Posts by F-111 John
Old Jul 02, 2010, 06:36 AM
reacher10's Avatar
Joined Oct 2008
I don't think there really is subtrim. When I trim the surfaces to nuetral for the first flight the I have to use the trim buttons. Then I go to the trim menu and set those trims as the base.
It's at this point that I notice the trim change between high and low rates. If I go to like max trim it doesn't change trim when rates are changed but this is a radical trim change and the surfaces are maxed in one direction so the model is way to far out of trim to fly.
Once the plane is flying I then trim it for flight. So I end up with two sets of numbers, trim and base. The only way to trim the servos is with the trim buttons. They are not two different types of trim as they should be.
Again...subtrims are to center your servos and trims are to adjust servos for flight. I don't think this is being addressed correctly.
On the main screen with numbers instead of bars the trim change on one model for goes from
Rudder..... -11.6 to -7.3
Aileron....... 2.2 to 4.3
Elevator......2.0 to 2.2
I'll set up trims before dual rates and visa versa (not sure how I did it yesterday) and see if there is any difference. I'll also set trims to zero and see if there is a change.
Old Jul 02, 2010, 06:45 AM
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
I think you have the right idea, that the trims are not being addressed correctly by the software.
I agree that subtrim is used when setting up the model on the ground to center the surfaces, and trim is used in flight. Then often after landing a trimmed aircraft, you take out the flight trim and put in more subtrim, so the model is now trimmed for flying with the trims zeroed. This is because there is usually less travel available in flight trim than there is in subtrim, so during flight you want the most trim possible available, so normal flight should be with zero flight trim.
However, the neutral position of the servo should be calculated by the stick being in center position and then trim and subtrim added (or subtracted) to that value. When the stick is fully deflected, the servo should go to endpoint position. When dual rates are used, the center position of the servo shouldn't change, but the endpoint position is reduced by the dual rate percentage.
You should experiment with both the subtrim settings and the front panel trim button settings to find out which one (or both) causes the center of your servo to change, then the software developers can fix how they handle dual rates.
This is the advantage of electronic flight trims over mechanical trims. With mechanical trims, you are actually rotating the joystick pots slightly, and there is no way for the radio to distingush between stick movement and trim movement, so trim will change with dual rates. With electronic flight trim, the servo center shouldn't be affected by dual rates.
Old Jul 02, 2010, 10:02 AM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
This is exactly the same problem I was explaining earlier which caused problem when mixing channels and reducing travel at the end of the stick movement.
Old Jul 02, 2010, 10:28 AM
reacher10's Avatar
Joined Oct 2008
OK, as soon as I add any difference in dual rate it throws the trim off.
So the trims really need to be written completely different in the software.
Old Jul 02, 2010, 12:13 PM
jonlowe is offline
Find More Posts by jonlowe
Northern Alabama, USA
Joined Apr 2003
reacher10,
Please write this up as an issue at the firmware site, here:
http://code.google.com/p/th9x/issues/list
Jon
jonlowe is offline Find More Posts by jonlowe
Old Jul 02, 2010, 02:58 PM
Promix is offline
Find More Posts by Promix
TH9X Firmware: Thus NG
Joined Mar 2010
Can anybody else confirm issue 27 ?
Promix is offline Find More Posts by Promix
Old Jul 02, 2010, 03:30 PM
jonlowe is offline
Joined Apr 2003
Yes, just confirmed it on my system. Seems to only do it on channel 4. Definite bug.
Jon
Old Jul 02, 2010, 06:01 PM
reacher10's Avatar
Joined Oct 2008
It's on CH 4 & Ch 5 on my radio. Servos are jittery in one direction.
Mini-HowTo The iMax/Eurgle/Turnigy 9x Facts/How-to Thread! Amazon Radios 197 Feb 02, 2014 07:06 PM
Idea A new FlySky/EURGLE/Imax/Turnigy battery tweak ppan Radios 1 Jul 24, 2012 02:31 AM
Wanted Dead/broken Turnigy 9x - Flysky FS-TH9X - Eurgle crucial Aircraft - General - Radio Equipment (FS/W) 5 Oct 23, 2011 08:40 AM
Discussion Anyone have a bad Turnigy Imax or Eurgle 9x Kev Radios 0 Sep 18, 2009 05:47 PM
Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? JRexA Radios 30 May 11, 2009 04:25 PM
