Old Aug 13, 2011, 06:14 AM
alexcmag is offline
Find More Posts by alexcmag
alexcmag's Avatar
Sao Paulo, Brasil
Joined Aug 2004
Originally Posted by scott page View Post
It's official. My Futaba 7C has been replaced by er9X.
You're not alone on that battle.
One of my friends bought a Futaba 12ZH a time ago (a ~$2800 box). The unit was used for less than 3 months when stopped working. Probably it was due to an error when writing model configuration to memory (the infamous "backup error"). The local distributor asked around $1000 to fix.
He saw several friends flying ER9x and loved it. So, he decided to bought one, plus backlight and FrSky telemetry combo.
Since he has now soldering skills, currently his radio is on my bench for this, tomorrow I will return it and he will finally able to flight again.
BTW, he has a 72MHz Futaba also, the FlySky V2 module from 9x will be modified and installed on it :P
Of course the V2 module+RX are not as reliable as Futaba FASST, but from my tests they showed pretty close (I guess 6830m range-test is enough).
Actually they far more reliable than DSM2, so many colleagues that used DSM2 also migrated to ER9x
alexcmag is offline Find More Posts by alexcmag
Old Aug 13, 2011, 06:30 AM
rogueqd is offline
Find More Posts by rogueqd
Quads, 4 times the fun.
Australia, NSW, Brookvale
Joined Apr 2011
Originally Posted by DTROWBRIDGE View Post
I just got ER9X flashed to my radio... I am having a problem using the radio with AFPD simulator (it will not see the radio) . I have instaled the FrSky DIY module (non-telemetry). I seem to remember reading somewhere that I should not have to do the resistor mod with the FrSky module. Is there something in the FW that I need to turn on or off for this to work or do I need to do the resistor mod?
The resistor mod, while done on the radio, is actually a fix for a problem with the stock module, so it is unnecessary if you have done the FrSky DIY mod. I have the same setup but with the stock firmware (waiting for my smartie board to arrive). Try just plugging in the sim cable without turning the radio on. The LCD should turn on but the red FrSky LED will remain off. That should work with the simulator. If you turn the radio's power switch on the FrSky LED will light up and it will no longer send a signal to the simulator.
Hope that helps.
rogueqd is offline Find More Posts by rogueqd
Old Aug 13, 2011, 06:44 AM
DTROWBRIDGE is offline
Find More Posts by DTROWBRIDGE
Joined May 2011
Hope that helps.
I have plugged the cable in without turning the radio on. The LCD lights up and the FrSky LED does not come on. AFPD will see the cable (the Ikaurus USB cable that it came with) but it says transmitter not found.
Dave
DTROWBRIDGE is offline Find More Posts by DTROWBRIDGE
Old Aug 13, 2011, 07:25 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
Dave
http://er9x.googlecode.com/svn/trunk/doc/PPMinFix.pdf
Here is a tutorial for the resistor mod.
There is lots of information on the er9x code page.
http://code.google.com/p/er9x/
crucial is offline Find More Posts by crucial
Old Aug 13, 2011, 07:37 AM
Joined May 2011
Thanks, I will try the resistor mod and see what happens.
Dave
Old Aug 13, 2011, 08:37 AM
Orphee is offline
Find More Posts by Orphee
Joined Jan 2011
Hi,
Someone discovered the Turnigy 9x with original Rx has failsafe function :
http://www.youtube.com/watch?v=9h633AcRnLw
You just need to rebind Tx & Rx after failsafe setting/activation... (with Turnigy original FW)
http://www.modelisme.com/forum/aero-...ml#post1789554
But er9x does not have failsafe menu, does it ?
Orphee is offline Find More Posts by Orphee
Old Aug 13, 2011, 09:04 AM
JEANALTAYR is offline
Find More Posts by JEANALTAYR
France
Joined Jan 2011
HY on the next french post they said that failsafe is associated with FM Tx & Rx no in 2.4 ghz
jmi
JEANALTAYR is offline Find More Posts by JEANALTAYR
Old Aug 13, 2011, 09:14 AM
gohsthb is offline
Find More Posts by gohsthb
Naperville, IL
Joined Mar 2009
Originally Posted by rwiltshire View Post
I bought a 9x and am having trouble getting the flaps switch to move my flaps down.
I have the flaps on ch.6 but when i flip the switch nothing
as you can tell im new at this stuff
any help would be great
First have you upgraded to Er9x? If not go ask in this forum: http://www.rcgroups.com/forums/showthread.php?t=1035575
If you have, try reading the manual. And checking the examples posted here:
gohsthb is offline Find More Posts by gohsthb
Old Aug 13, 2011, 11:04 AM
Orphee is offline
Joined Jan 2011
jmi
After that post about FM, roro33 confirm it works on his Turnigy 9x in 2.4 Ghz and gives the video as a proof.
Old Aug 13, 2011, 11:59 AM
chewbaccah is offline
Find More Posts by chewbaccah
Combat: You're doing it wrong.
chewbaccah's Avatar
United States, UT, Layton
Joined Sep 2009
I would like to see the video that proves it.... The video above just shows the motors turning off, which is not failsafe. The ESC turns the motor off when the signal is lost. Failsafe would also require the flight surfaces to return to a preset "nominal" position.
chewbaccah is offline Find More Posts by chewbaccah
Old Aug 13, 2011, 12:07 PM
Orphee is offline
Joined Jan 2011
I would like to test it myself but I can't restore my Turnigy.hex backup...
EEPROM ERROR at start... I did not save eeprom from Turnigy FW...
Old Aug 13, 2011, 02:08 PM
preston91 is offline
Find More Posts by preston91
Joined Jul 2011
Originally Posted by con244 View Post
Hi All
I too am having a problem with ER9x and a simulator. I use Clearview and cannot seem to get it to calibrate the new tx. I have used Clearview with my Hitec Optic 6 Sport with no problems but although the sim sees the transmitter the mapping is crazy and it will not calibrate (every axis is scrambled and jittery). Has anyone been able to get ER9x working with Clearview? I can't find any details on the resistor mod mention above. I have searched under "resistor mod" with little success. Will this help me with my problem?
Thanks in Advance
Con
here's a link to a video on the resistor mode you need to do. I had to do it to use clearview
Hobby King Turnigy 9X Trainer Function and Simulator Modification Fix Resolution DIY (10 min 21 sec)
preston91 is offline Find More Posts by preston91
Old Aug 13, 2011, 02:18 PM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
I had problems with 9x and aerofly until today.. it was all over the place.. so, just created a normal 4 channel model, and the trick is to reduce the number of channels output for that model.. Reduced it to 4 channel PPM output on the model settings menu and now works fine.. I think I could put it up to 6 channels without problems..
Joćo
jhsa is offline Find More Posts by jhsa
Old Aug 13, 2011, 04:25 PM
jpparisy is offline
Find More Posts by jpparisy
jpparisy's Avatar
France, Ile-de-France, Plaisir
Joined Sep 2010
Fail-safe or not fail-safe?
Here is what I found, using an oscilloscope, when the signal is lost:
With the Turnigy 9X8Cv2 receiver, on channels 4 and 5 the pulse is maintained at its previous value (HOLD mode), signal disappears (0 volts) from other channels (1, 2, 3, 6, 7, 8).
With HobbyKing HK-TR6A V2 receiver, channels 4 and 5 stay in HOLD mode, signal disappears from other channels (1, 2, 3, 6).
With HobbyKing HK-GT2R receiver, with the CH2 fail-safe disabled, signal disappears from the three channels.
So, if an ESC is used on channel 3, it will cut off in case of signal's loss.
If you use an external fail-safe, like this one, it will never work on channels 4 or 5.
Note that I found only the FlySky 3-channel receiver has an integrated fail-safe feature, not enabled by default. And if you enable it, it will be lost to the next re-bind (this is the only way to disable fail-safe).
jpparisy is offline Find More Posts by jpparisy
Old Aug 13, 2011, 05:15 PM
Mike Blandford is offline
Find More Posts by Mike Blandford
Poole, England
Joined Mar 2008
Originally Posted by showmaster View Post
I couldn't be happier.
I had good test flights yesterday with the FrSky hub. I had displays of battery voltage, battery temperature, RPM, Rx RSSI and Tx RSSI. I added the A1 voltage to the hub display screen. I'm still working on what to display, what should be configurable, and whether anything needs an alarm. If anything does need an alarm, how do we set it, and where do we store the alarm value, preferably without changing the EEPROM structure.
Mike.
Mike Blandford is offline Find More Posts by Mike Blandford
Mini-HowTo The iMax/Eurgle/Turnigy 9x Facts/How-to Thread! Amazon Radios 197 Feb 02, 2014 07:06 PM
Idea A new FlySky/EURGLE/Imax/Turnigy battery tweak ppan Radios 1 Jul 24, 2012 02:31 AM
Wanted Dead/broken Turnigy 9x - Flysky FS-TH9X - Eurgle crucial Aircraft - General - Radio Equipment (FS/W) 5 Oct 23, 2011 08:40 AM
Discussion Anyone have a bad Turnigy Imax or Eurgle 9x Kev Radios 0 Sep 18, 2009 05:47 PM
Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? JRexA Radios 30 May 11, 2009 04:25 PM
