Perth, Australia
Joined Nov 2010
ER9x w FrSky DIY - no servo control - Help
Mike, i connected the signal wire (the yellow one on the DIY it) to the very top on the pins. I followed rcmodelreviews video on youtube. so from the top down (of the module pins) its yellow, black, red. Will get a photo tonight. Just thinking about what you said - might not be getting ppm signal. Without the ppm signal it would still bind with receivers as you push the button to go into bind mode, and as long as the module is getting voltage it should bind. I was thinking as the receiver is binding it should be wired all good, but will desolder it, and check out the soldering on the diode (from factory), and possibly re-do these. Showmaster - i am not using the 2way module - just the simple V8 series. 2 way would just be too much headache for me currently as i am just getting into it. for me dont want to get too fancy, just want to fly, lol. (or attempt to) Also what is the this free scope program?? Will take a look around Also you say TX switch not off - on the ERsky firmware i used the simple 4 ch template and from what i can see no switches are assigned. should there be a particular one i should look out for? Also would it be possible to put a voltmeter on the ppm line (should it fluctuate as i move the sticks around?). well of course it possible, lol but will be of any use... A massive thanks to guys helping me out. |
Poole, England
Joined Mar 2008
Can you remove the DIY module and put the original module, that came with the radio, back in? Complete 'outside the box' thought, I wonder if the diode in the PPM line is in the wrong way round, that would stop it working! Mike. |
Perth, Australia
Joined Nov 2010
so if the diode is the wrong way around would i still see 5v on the ppm line (any other way of seeing if it is the wrong way around) I can almost imagine some little chinese guy at the place soldering them on, and then just thinking to him self, i screw this guy up, diode backwards! giggling to himself as he does it. I will read up on the basics of the schotzky diode see what it does. I did put the old one back it (but i have cut the antenna so hold them real close) and same thing. Binds but no servo movement. but i did not remove the DIY module. So i think check the diode, them if not remove diy completely and old one back in. |
Canada, BC, Central Okanagan H
Joined Jun 2010
The "power" it gets from PIN 17 (the pad used to turn the EL backlight on/off) isn't for running the backlight - its simply there to "trigger" (for lack of a better word) the turning on/shutting off of the main backlight circuit. The main power is coming from elsewhere. Without some fancy circuitry, there's no way for you to use a simple backlight like the HK one with the Pin 17 on/off functionality. Sorry.- Steven |
Joined Aug 2006
If I'm reading this right, you were supplied a Schottky diode to add yourself? The Schottky Diode band (Cathode) should point/connect to the TX PPM out. The non band end should point/connect to the DIY input at the circuit board. If it's external and you connect it to the yellow wire, then the non band to the yellow wire, the band end/cathode to the tx PPM out. On the 9x the band to the top pin on the module board. I'm not sure without cutting the trace going to pin 1 on the 9X module pins and adding a 1K resistor in series with the trace, that the 9X can drive the DIY and original module at the same time. Removing the connection to the DIY, yellow wire, is a good idea if you want to try the original 9X module. If still no servo movement then it's hopefully it's programming. I never tried the 4 ch setup provided so I'll try that as well. Work fast if you're not going to resolder the antenna to the module. I'm not sure how long it will run that way? Try loading one of the posted mixes here. I think they will all supply normal stick movement as a test. I think anyone with first hand experiance with using the scope program would be a super help by posting the info needed to get it going. Seems like a lot of new users could use it to trouble shoot an install. I'm fortunate enough to have been given a nice scope by a ham friend so I lucked out at the start and never tried the PC scope programs. It pays to ask around I guess. As for the diode and voltage reading as an educated guess. If correct, the 9X side (Band/Cathode)will be 5 volts from the 9X. The non band side to the DIY/Yellow will be 3.3 volts from the DIY. Because of the diode action the 9X stays at it's level and the DIY stays at it's level. Of course these signals are going from 0 to the 5 or 3.3 level so your meter may average it out to something else. Try AC and DC meter mode to see it it helps. OK, I'll try these things myself to see if they have and validity in trouble shooting. Anyone please join in with corrections or more additions to help get things working. |
Joined Aug 2006
I'll try some way to verify a PPM signal without using a scope first chance. Just a thought, I know that the PPM signal sounds like a growl and varies in it's sound when the sticks are moved. Using the PC scope idea that uses the sound card 20-20000 Hz pass band, maybe using a computer powered speaker or headset with let's say a .1Ufd cap in the hot audio input would let you listen to the pulses changes( connect the shield to the 9x Ground). I know if I used to put my 72MHz TX on top of my TV here in the us (analog channels) I could watch and hear my PPM signals when they were AM. I mention this in case the meter can't help. I just can't get time to do it tonight/today or I would, but I will just to have the knowledge it can be done. Maybe someone else will try it and report back if it works as a simple tester? Getting it all to work with the original module as mentioned will sure be a big help in what's going on as well. Maybe a new thread on just simple test equipment and computer programs is in order. I have no idea on how to start one, or if it has any merit? Just thinking. |
| Thread Tools | |
| Mini-HowTo The iMax/Eurgle/Turnigy 9x Facts/How-to Thread! | Amazon | Radios | 195 | Sep 29, 2012 04:30 PM |
| Idea A new FlySky/EURGLE/Imax/Turnigy battery tweak | ppan | Radios | 1 | Jul 24, 2012 02:31 AM |
| Wanted Dead/broken Turnigy 9x - Flysky FS-TH9X - Eurgle | crucial | Aircraft - General - Radio Equipment (FS/W) | 5 | Oct 23, 2011 08:40 AM |
| Discussion Anyone have a bad Turnigy Imax or Eurgle 9x | Kev | Radios | 0 | Sep 18, 2009 05:47 PM |
| Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? | JRexA | Radios | 30 | May 11, 2009 04:25 PM |
