Old Jun 28, 2010, 11:10 PM
Dale3701 is offline
Find More Posts by Dale3701
Joined Aug 2008
Originally Posted by reacher10 View Post
I had my wiring wrong and with crucials help was able to correct it. Although mine powered up but I was just not able to flash it. I ended up buying a USB programmer and with the wiring correct it flashed.
I'm not an expert on AVR programming but where is your programmer getting it's power from? As far as I know all the serial programmers that have been used for this need 5V+ from the radio.
Well some further digging and I found no less than 4 different schematics for basic AVR interfaces! Hopefully this will keep others from pulling their hair out.
parallel port pin outs from different schematics, all use 18-25 for GND
Code:
MISO 11  10  10  11
MOSI 3   7   9    2
Reset 4   9   7    16
SCK   2   6   8    1
I have identified these as AVRSP, STK200, BSD and DAPA compatible basic unbuffered interfaces. A single page with concise info on the various interfaces.
So I can get on with using the radio... I ordered a completed device from sparkfun. While I'm waiting for it, I may still try to figure out what is going wrong, or if I need to use one of the other interface designs. I'll post what I find if I do.
Dale3701 is offline Find More Posts by Dale3701
Old Jun 29, 2010, 12:23 AM
Telemachus is offline
Find More Posts by Telemachus
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Good luck. I tried about 5 of them, and had no luck.
Not sure why. I could flash another AVR I had with no problem, but not the atmega64.
Telemachus is offline Find More Posts by Telemachus
Old Jun 29, 2010, 06:50 AM
reacher10 is online now
Find More Posts by reacher10
reacher10's Avatar
United States, NY, Shirley
Joined Oct 2008
After a fresh calibration
Sticks moved to full throw
-23400........-19650
-100........105
-24100........20300
-10875........-10625
Numbers with sticks centered
50
0
-100
-75
Now checking the dead spot with a fresh model and no programing.
Still have dead spot except for throttle...throttle is fine.
Looking at the numbers and seeing that the throttle is ok makes sence.
I'll deal with it for now untill a new version comes out dealing the trim/curve probs and the switch reversing fuction.
I orded this programmer from sparkfun and it didn't work with several programs including ponyprog.
http://www.sparkfun.com/commerce/pro...products_id=14
I then bit the bullet and bought this one and it worked perfect. Ignor the price, he does that when it's out of stock in the US. I got mine in 3 days but no telling how long from china...prolly be 10-14 days.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
reacher10 is online now Find More Posts by reacher10
Old Jun 29, 2010, 08:56 AM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
My experience with PIC microcontrollers is much more robust than Atmels... and my serial port PIC programmer has always done the task.
Parallel and serial port AVR programmers seem to be riddled with problems, mostly from the lack of software support would be my guess.
The Pocket AVR Programmer from sparkfun is cheap, and works well (I am surprised you would buy a serial version when the USB is essentially the same price...)
Old Jun 29, 2010, 10:34 AM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
-100........105
-24100........20300
50
0
-100
-75
I'd love to hear what the software guys say about why your numbers would be like that. Why would yours be so far off and what about the software would make it do that on yours but not someone elses.
It definitely sounds like your problem is much different than what I was describing.
crucial is offline Find More Posts by crucial
Old Jun 29, 2010, 11:35 AM
reacher10's Avatar
Joined Oct 2008
I actually spoke to a tech at Sparkfun and explained what I was doing and he sugessted the serial so I just went with it.
Yeah..not sure whats up with the numbers but they seem to whacked!
Old Jun 29, 2010, 11:38 AM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Well, I would send them back.
I had a few dead spots on my radio, but after calibrating a few times, seemed to work fine.
I haven't tried any custom throttle curves. My time with Thus has been entertaining, but I need to fly a heli, so I think I am going back to Turnigy V2.
Has anyone tried the trainer function? Will it work with stock firmware?
Old Jun 30, 2010, 02:29 AM
Promix is offline
Find More Posts by Promix
TH9X Firmware: Thus NG
Joined Mar 2010
Time to play
New FW revision is out http://code.google.com/p/th9x/
Promix is offline Find More Posts by Promix
Old Jun 30, 2010, 02:35 AM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Lots of issues fixed, although who knows what issues 7,13,19,21,22,24 are??
Old Jun 30, 2010, 02:43 AM
Promix is offline
Joined Mar 2010
Look at ISSUES folder at this site http://code.google.com/p/th9x/
then set to show all issues
EDIT: issue 19 and 21 are in german, so this is the translation
19 - No trim to mixers with curves
21 - Reversed switch function with " ! " ( !RUD ) inop
Old Jun 30, 2010, 06:39 AM
reacher10's Avatar
Joined Oct 2008
Issue 25...true dual rates with out having to use a mix. Haven't flashed it yet so lets see what we can see.
Old Jun 30, 2010, 09:30 AM
jonlowe is offline
Find More Posts by jonlowe
Northern Alabama, USA
Joined Apr 2003
Just flashed Thus's new firmware. MAJOR improvements!
1. Expo and DR now on one screen. When you get to the EXPO/DR screen, select a %, and hit the menu button. Screen changes to a one where you can set hi and low rates, hi and low expo, and select a switch. I have Issue/Enhancement 17 in so that when you select the flight mode switch to assign rates/exp to, you could have three rates/expo.
2. Trim now works with curves (you can use a curve with throttle and the idle trim works). I'm still hoping he changes the built in curve for throttle from a expo curve to a 9 point curve. I have an Issue 18 in for that.
These changes alone make the upgrade worthwhile. I haven't play around enough to see the other improvements.
Jon
jonlowe is offline Find More Posts by jonlowe
Old Jun 30, 2010, 11:44 AM
joan is offline
Find More Posts by joan
Johannes
Switzerland, Vaud, Lausanne
Joined May 2010
hey guys, how many of you have successfully flashed a Turnigy v2 Tx with thus software?
Were there any issues with that?
- Johannes
joan is offline Find More Posts by joan
Old Jun 30, 2010, 12:29 PM
Promix is offline
Joined Mar 2010
Originally Posted by joan View Post
hey guys, how many of you have successfully flashed a Turnigy v2?
- Johannes
done.... and kicked !
read this
btw: this is a custom FW threat covering THUS
Old Jun 30, 2010, 12:41 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Originally Posted by crucial View Post
I'll start with my current question.
I am trying to setup the subtrim to center my servo and from what I can tell you set this up in the TRIM 4/7 menu. You set the trim value (with the trim button) to center the servo, then press right to set the base trim value. I noticed that after doing this you lose some travel in the stick movement at either end. On my elevator this reduction is 1/3 of my overall stick movement.
Is this normal behavior?
This is also affecting my delta mix. When I mix the elevator to the aileron it is changing the trim of the other channel to match the setting of the first. Unless I am setting this all up wrong.
I am using pre-programmed delta/elevon set-up. I have no problem with sub-trim changes.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Mini-HowTo The iMax/Eurgle/Turnigy 9x Facts/How-to Thread! Amazon Radios 197 Feb 02, 2014 07:06 PM
Idea A new FlySky/EURGLE/Imax/Turnigy battery tweak ppan Radios 1 Jul 24, 2012 02:31 AM
Wanted Dead/broken Turnigy 9x - Flysky FS-TH9X - Eurgle crucial Aircraft - General - Radio Equipment (FS/W) 5 Oct 23, 2011 08:40 AM
Discussion Anyone have a bad Turnigy Imax or Eurgle 9x Kev Radios 0 Sep 18, 2009 05:47 PM
Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? JRexA Radios 30 May 11, 2009 04:25 PM
