Northern Alabama, USA
Joined Apr 2003
I'm here!
I originally posted these questions in the Turnigy thread, but I think they may have gotten lost in the noise in the other thread. Hope someone can help me. 1. I'm trying to use a custom curve for throttle using CV3. I can get the curve to work, but I lose throttle trim. How do I fix this? 2. I want to set up dual elevator servos and dual aileron servos. I can mix elevator to channel 5 and aileron to channel 6, but it appears that if I want dual rates, I have to set them up in mixes in both the original channel, and the mixed channel. Is there any simple way to set up the slave channel to follow whatever happens in the master channel? 3. I want a dual rate to kick in for elevator in the last few degrees of stick movement for down elevator. I can set up a curve mix to do it using CV4 mixing elevator to elevator, but I lose elevator trim. It seems anytime I set up to use a curve mix, I lose trim. How do I fix this? 4. Throttle trim (no curve) appears to work on both low and high throttle. How can I get it to only work on low throttle? Jon |
Riverside, CA
Joined Jul 2006
Jon, weren't you trying to us a parallel programmer? Did you finally get it to work? (I could be mistaken).
Now that my feet are a little more wet, I am beginning to understand the potential. The throttle proportional timer is simply brilliant! I figured out configuration of the sticks and subtrim, now trying to tackle mixing. Manual doesn help much. I want to mix Aileron to Elevator and vice versa for elevon mixing. Can anyone offer a quick tutorial? |
So under elevator add a mix and designate it aileron. Just make that simple change and then exit to the main screen and you can see the channels that are activated with the elevator stick. From there go back into mixing and start playing with numbers and other stuff. You will prolly need need 2 mixes under elevator and visa versa. Can't stay but start messing with it. |
Check and see if your servos move all the way to the end of your stick travel...I'm seeing probs with this. |
Joined Apr 2003
Thanks. Jon |
So if you remove the curve you have your trims again? Jon I'll make a quick video so you can see how I have it setup...no sense posting it...boring. |
Promix, could you please ask josef and johannes if they could look into the dead spot at the end of the sticks? And possibly setting up the trims as they are in the original FW.
The dead spot is really a huge bug. I can still fly but it makes the sticks very sensitive. Other then these two area's the FW is great. Thanks |
Joined Apr 2003
Thanks. Jon |
It shows that the trim is moving on the side bar but there is no responce at the servos, numbers on the screen or the horizontal bar. I removed the curve and it trims the servos. I was just looking at the side bar and didn't notice the prob because I don't really trim the throttle with the trim button. OK...so 2 bugs. 1. Sticks have major dead spots at the ends. 2. Servos do not respond to trim if a custom curve is applied. EDIT: Adding found bugs 3. Reversing setting for the switches does not work as it should (ELE!..etc.). No effect. This is great that we have this thread but it sucks that we don't have author's who wrote the FW. Promix it looks like you're our man! |
Joined Apr 2003
| Thread Tools | |
| Mini-HowTo The iMax/Eurgle/Turnigy 9x Facts/How-to Thread! | Amazon | Radios | 195 | Sep 29, 2012 04:30 PM |
| Idea A new FlySky/EURGLE/Imax/Turnigy battery tweak | ppan | Radios | 1 | Jul 24, 2012 02:31 AM |
| Wanted Dead/broken Turnigy 9x - Flysky FS-TH9X - Eurgle | crucial | Aircraft - General - Radio Equipment (FS/W) | 5 | Oct 23, 2011 08:40 AM |
| Discussion Anyone have a bad Turnigy Imax or Eurgle 9x | Kev | Radios | 0 | Sep 18, 2009 05:47 PM |
| Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? | JRexA | Radios | 30 | May 11, 2009 04:25 PM |
