Old Nov 13, 2012, 07:02 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Best method is to match things to whatever transmitter the module was intended to be installed in.
I would have thought that the default 22.5 msec/300usec would have been close to standard JR. Could be a problem/flaw with the Orange module, since it was reverse engineered.
To be honest - IMO you would have been better off with a DX4e module than the unknown Orange one. Does it have an FCC number for example?
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 13, 2012, 07:44 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Nov 13, 2012, 10:53 PM
mpjf01 is offline
Find More Posts by mpjf01
mpjf01's Avatar
Australia, SA, Adelaide
Joined Aug 2012
Originally Posted by Radio.Active View Post
So is it worthwhile starting a RCG 9X All Models, Eprom Sharing Forum? Or, am I having a senior's moments, lost my Googling skills and it all ready exists somewhere?
There is a link after your post to a topic in the 9x forum that contains templates for gliders. For a beginner with the firmware I think they can be a bit complex so we have extracted a template that we use for a F3J glider and it is available from
https://dl.dropbox.com/u/59957156/F3...0template.eepe
also a writeup explaining what it means
https://dl.dropbox.com/u/59957156/F3...structions.txt
If you think it could be useful you are welcome to use and modify it.
The formatting of the text document is crap - if anyone knows how to fix it........
mpjf01 is offline Find More Posts by mpjf01
Old Nov 13, 2012, 11:07 PM
mdem is offline
Find More Posts by mdem
mdem's Avatar
Australia, VIC, Carrum Downs
Joined Oct 2012
Hello everybody.
I just have a quick question for you all, I have bought a LiFe battery to use in my TGY 9x TX, 'ZIPPY Flightmax 1800mAh 9.9V 5C LiFePo4 TX Pack' from HobbyKing.
But I've read that I need to change the discharge plug that is on the battery to the one that the 8bettery holder is using. That isn’t a problem it’s a simple swap.
My question is how do I charge the Life once I solder the new plug onto the battery?
I've read all the discussions on the HobbyKing thread and tried to YouTube, but I'm still confused as hell. I'm trying to find an adapter that I can use for the plug but I can’t find anything at all and I’m completely at a loss :s
https://www.dropbox.com/sh/3dl4uvpd5...QE7J72oS/1.JPG
This will be the 'Discharge plug' that will be on the battery once I do the swap.
*edit*
Even if somebody can tell me what this Discharge plug is called, I can try and search for a male/female set to make my own adapter. I can't even find the name of the plug the 9x uses.
https://www.dropbox.com/sh/3dl4uvpd5...97iN7q2C/2.jpg
This is the battery that I had bought. It only has a Discharge plug and a Balance plug.
Can anyone help me?
Thanks in advance.
-mdem
mdem is offline Find More Posts by mdem
Old Nov 13, 2012, 11:12 PM
mpjf01 is offline
mpjf01's Avatar
Joined Aug 2012
Change the discharge plug to match the Tx - the Tx socket is 3 pin and you use the left 2 pins looking at the Tx from the back, left pin is neg. The plug you need is a 2s balance plug - HK sell them as 2s balance lead extensions and you just cut off the plug and solder the wires. There's probably somewhere you can buy the balance plug separately.
You will still need to use the balance plug on the battery when charging and you will have to make a socket for the discharge plug on the charger (from the other part of the 2s balance lead extension).
Old Nov 13, 2012, 11:37 PM
mdem is offline
mdem's Avatar
Joined Oct 2012
Hello, So the Turnigy 9X just uses a '2s Balance plug' as its power source plug?
Old Nov 13, 2012, 11:54 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
Yes... but be careful of how you're reading that. It is, in fact, a 2s balance plug (precisely it is a JST brand/knockoff model XH, 3-pin)... but don't just go plugging your battery in and hoping for the best! The plug is right, but the wiring is 99% of the time wrong!!
DONT FRY YOUR RADIO like so many others have just because the plug fits!
For the 9x's power port (which again is the 3-pin socket counterpart to the balance plug) you have power in the middle and ground to either side. That's NOT how most batteries are wired!
- Steven
s_mack is offline Find More Posts by s_mack
Old Nov 14, 2012, 12:01 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
- Steven
So your saying make sure the red/black wires match up with the plug I'm taking from the AAcell holder.
Mine is like this, Ground|___|Power|____|Empty.
I'm looking for some 2s Balance leads but Hobbyking are out of stock, and LHS are charging anywhere from $2-5 each ~.~
Will have to think of something lol
Old Nov 14, 2012, 12:12 AM
s_mack is offline
Registered Loser
Joined Jun 2010
Yeah... the ground can be on either side (confirm with a meter... you'll see the two outside pins are connected internally).
Alternatively, as was recently pointed out to me, if you get this very popular and very suitable LiFE battery, you can simply use the black servo-style connector that's already on there. Had I known that, I wouldn't have bothered messing with the wires! Its already the "correct" way for the 9x. And it does fit well... I tried.
Old Nov 14, 2012, 12:13 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
I just cut the lead of the included AA battery pack and put a servo plug on the end of an extension lead. Did the same on the battery side. obviously one is male the other female.
hendrnk is online now Find More Posts by hendrnk
Old Nov 14, 2012, 12:33 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
I wanted to buy this, but at the time it was not in stock, so I just thought I'd get the Zippy pack.
Hello, I just wanted to make sure I understand you correctly.
I draw a simple diagram to show you what I think you mean, is this correct?
https://www.dropbox.com/s/bkg80a6k13e2jtv/3.JPG
Would this kind of setup be ok the plugs are sturdy enough to handle the power going through it?
Old Nov 14, 2012, 12:41 AM
Joined Apr 2012
Yes that's the way I did it. The Tx uses much less power than running your Rx, and 4 servos etc so no need to worry about that.
Old Nov 14, 2012, 12:43 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
Oh great thank you so much, that saves me so much money. I already have a charge lead with a servo plug on it, and plenty of extra extra extension wires I can cut up when my LiFe battery finally arrives.
-mdem
Old Nov 14, 2012, 12:59 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Mdem, you may want to check out this recent thread for charging non-Nixx Tx batteries.
'How do I Charge that?'
KC is offline Find More Posts by KC
Old Nov 14, 2012, 01:38 AM
mpjf01 is offline
mpjf01's Avatar
Joined Aug 2012
This is the item I was referring to. http://www.hobbyking.com/hobbyking/s...idProduct=9735
Currently on BK but they come in every week or so. Or you can PM me and I'll send you one. You cut it in half, connect the socket to the charge lead on your charger (not the balance lead) and the plug to the battery. Ignore the colour of the wires in the lead. Connect the negative battery terminal to the left wire on the plug as it sits in the radio and connect the positive wire to the centre wire on the plug. Cut off the 3rd (right hand wire) on the plug making sure that what's left can't short on anything. Then make sure that you observe the same polarity when you connect the socket to your charger charging leads. The battery you have is a 3s so you can't connect its balance lead to the Tx as it has 4 wires in it even if you wanted to (and you don't).
The plug is the correct plug for the radio socket and you can't get it in the wrong way round.
You will have to disconnect the battery plug from the radio socket every time you charge it because the built in charge socket on the 9x isn't connected to anything. And of course you also need to connect the battery's balance lead to the charger. This plugging and unplugging increases the risk of error and is why it is wise to use the correct plug.
Mini-HowTo The iMax/Eurgle/Turnigy 9x Facts/How-to Thread! Amazon Radios 197 Feb 02, 2014 07:06 PM
Idea A new FlySky/EURGLE/Imax/Turnigy battery tweak ppan Radios 1 Jul 24, 2012 02:31 AM
Wanted Dead/broken Turnigy 9x - Flysky FS-TH9X - Eurgle crucial Aircraft - General - Radio Equipment (FS/W) 5 Oct 23, 2011 08:40 AM
Discussion Anyone have a bad Turnigy Imax or Eurgle 9x Kev Radios 0 Sep 18, 2009 05:47 PM
Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? JRexA Radios 30 May 11, 2009 04:25 PM
