Old Jun 25, 2010, 10:15 PM
Lamborghini12345 is offline
Find More Posts by Lamborghini12345
Slope Drifting?
Lamborghini12345's Avatar
New Zealand
Joined May 2007
What makes a plane Fly Slow??
Well I set up my Fenix with a motor on top, small GWS with about 80g of thrust, AUW of 117g and it flies OK but quite fast. I want to take it down with me to Indoor at Palmerston North in the School Holidays but it will need to be controllable and slow if thats going to happen. I also tried it with a IPS "A" on it and it did fly Slow but would drop out the sky uncontrollably with no throttle.
SO I am wondering what makes a plane fly Slow and how can I make mine fly Slow? I figure its down to Thrust, Weight, Wing Loading?
HELP
Lamborghini12345 is offline Find More Posts by Lamborghini12345
Old Jun 25, 2010, 10:53 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Wing loading, which is a factor of weight and lifting surface area, is what determines flight speed... at least that is what I understand.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jun 25, 2010, 11:08 PM
Slope Drifting?
New Zealand
Joined May 2007
Would extending the wing area work then?
Old Jun 25, 2010, 11:39 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Wing loading is one factor, more winger area allows more lift at slower speeds, thus slow flight..
Another thing to consider is prop pitch speed.. not as important as wing loading, but can make a difference. A prop with a high pitch speed may generate more plane speed, like 6th gear in a sportscar.. high top end speed.. A lower pitch speed is more like a granny first gear in an old pick up, lots of thrust but it "winds out" and cannot accelerate a plane beyond a certain point unless a dive is invoked..
So a really good slow flier has a combination of both things, a high torque / low pitch speed prop, and large wing area to help lower the wing loading.
Hence on the micro planes, a diet to loose weight can really help things out, and even the Parkzone micro planes can come in under an ounce, some fly extremely slow like the Vapor..
~Kev
darksiede is offline Find More Posts by darksiede
Old Jun 26, 2010, 12:26 AM
Slope Drifting?
New Zealand
Joined May 2007
So the GWS EDP-50 DD is probably a high pitch speed with the 3020 prop, I guess the IPS was better because it had more thrust and reduction via gearbox for Slow speed plus high thrust. I think I will use my EPPiper then and keep this thing as a Glider....
Old Jun 26, 2010, 08:47 AM
Joined Nov 2007
Which fenix do you have? The smaller ones are naturally going to be zippy.
Kev
Old Jun 26, 2010, 10:17 AM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
I wonder if AOA can come into play. My DH-6 in my blog is a 13" 3ch peanut. In addition to a light wing loading, I added a lot of incidence in the wings (as per the plans + some). The thing crawls along. Could this be due to a mix of induced drag due to the biplane configuration, wing loading, and incidence?
Also, I left the bottom of the wings uncovered to produce a sort of "parchute" effect. Would this be considered parasitic or induced drag? In other words, do you think that it produces lift or just parasitic drag?
Great discussion!
PC49
PiperCub49 is offline Find More Posts by PiperCub49
Old Jun 26, 2010, 11:04 AM
Joined Nov 2007
We had a discussion on this a while back.
What is the name of lift that a foamy generates?
Old Jun 26, 2010, 11:17 AM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Will you please explain how dynamic lift relates here? I don't see how it answers my question(s)...
Old Jun 26, 2010, 12:33 PM
Joined Nov 2007
I didn't say it answered any of your questions. I just said we had a discussion on the topic of lift. And the thread I posted talks about purposely induced drag to create lift.
I just realized that you are in it.
Edit: I meant how drag is related to lift.
Old Jun 26, 2010, 12:41 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
isnt parasitic drag caused by items not contributing to lift, like a non lifting fuselage or airflow into an open ended fuselage?
i think if you want the biggest reasons for slow flight, its wing loading AND airfoil. many gliders have wing loading very close to planes like the parkzone sukhoi and yet the top speed is MUCH greater than it because they have a higher lift/drag ratio and the slippery airframe to accomplish it. and on the same note, when that glider changes its airfoil by dropping the flaps, it can slow to a crawl for landing (the lift/drag ratio changes dramatically when that happens as well)
so, you can go slower with a better airfoil at the same wing loading if you sacrifice the performance of having less drag.
derk is offline Find More Posts by derk
Old Jun 26, 2010, 01:20 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Derk and BIM, thank you both. And Derk, you are right about parasitic drag. BIM- sorry for the confusion.
Old Jun 26, 2010, 05:39 PM
TjW is offline
TjW
Find More Posts by TjW
TjW
USA, CA, Riverside
Joined Mar 2006
i think if you want the biggest reasons for slow flight, its wing loading AND airfoil. many gliders have wing loading very close to planes like the parkzone sukhoi and yet the top speed is MUCH greater than it because they have a lower lift/drag ratio and the slippery airframe to accomplish it. and on the same note, when that glider changes its airfoil by dropping the flaps, it can slow to a crawl for landing (the lift/drag ratio changes dramatically when that happens as well)
so, you can go slower with a better airfoil at the same wing loading if you sacrifice performance of less drag.
Probably a slip of the fingers, but a sailplane with a slippery airframe would have a HIGH L/D ratio. Lots of lift divided by not much drag.
Adding camber with flaps adds lift, but also adds drag. So pulling on flaps decreases the L/D ratio, which is why you can use flaps for glidepath control.
TjW is offline Find More Posts by TjW
Old Jun 26, 2010, 08:02 PM
Slope Drifting?
New Zealand
Joined May 2007
Thanks for all the help guys, I decided to revamp my EPPiper and its charging now, Had a test in the backyard and its Slow and floppy. I wasnt wanting to buy new gear(Well wanted but I just bought new receivers=Broke)so its using the original IPS "A" motor which is gutless but it works! Weighs in at 184g so a wing loading of 4.154oz/sq.ft and about 110g of thrust on the 9070, I might try a 1047 or 9075 but I would need to buy one all my 1047's are bent.
Old Jun 26, 2010, 08:10 PM
derk is offline
derk's Avatar
Joined Dec 2003
oh yeah, i had drag stuck in my head so i got it backwards
Discussion What slow stable plane for kids to learn on? mark17022 Beginner Training Area (Aircraft-Electric) 17 Apr 01, 2010 04:28 PM
Discussion Easiest Slow Plane To Fly callmemario Electric Plane Talk 15 Sep 10, 2009 04:39 PM
Discussion What makes a plane(gider) fly slow, steady and not sink? (much..) GreenAce92 Sailplane Talk 8 Mar 16, 2009 02:10 AM
What makes a plane a 3d plane and not just a aerobatic? soholingo Sport Planes 2 Mar 12, 2002 09:38 PM
who makes slow fly pusher props? mrittinger Electric Plane Talk 4 Jun 09, 2001 08:05 AM
