Old Jun 25, 2010, 09:24 PM
cadzilla is offline
Find More Posts by cadzilla
Gravity always laughs last
cadzilla's Avatar
USA, PA, Milford
Joined Feb 2008
Control a servo with a PC
I know this is being done, I'm looking for a simple solution. My goal is to break in a new gas engine and automate the run in process. I can do other things in the shop while the engine is being run. Ideal would be having more than 1 servo so I can shutdown the ignition from the program.
Overwhelmed by what's available I could use some direction on a solution.
Thanks;
RichK
AKA cadzilla,LowTek,spartaju
cadzilla is offline Find More Posts by cadzilla
Old Jun 25, 2010, 10:02 PM
adamdb is offline
Find More Posts by adamdb
United States, CO, Denver
Do a google search for "serial servo control"
adamdb is offline Find More Posts by adamdb
Old Jun 26, 2010, 06:31 AM
cadzilla is offline
cadzilla's Avatar
USA, PA, Milford
Joined Feb 2008
WOW!! Why didn't I think of that. Been there done that; could spend anywhere from $15-$1500. That's why I'm here asking the question; looking for someone's experience; knowledge; sort through all that's available.
Old Jun 26, 2010, 10:03 AM
rcastro is offline
Find More Posts by rcastro
Santiago, Chile
Joined Feb 2008
I'd go for Arduino. It's an easy-to-use microcontroller that can take care of your servo while interfacing with USB.
I've made some pretty cool R/C applications for scale helicopters using this. You can even interface it with any onboard Rx.
Check this out for your particular need: http://www.arduino.cc/playground/Lea...leServoExample
If you go further with this platform, you will be able to easily add temperature sensors for automatic shutdown when too hot or who knows what you may come up with.
Best of all: there's a big enough open-source community out there for you to get help.
Best of luck,
Rod.
rcastro is offline Find More Posts by rcastro
Old Jun 26, 2010, 10:36 AM
cadzilla is offline
cadzilla's Avatar
USA, PA, Milford
Joined Feb 2008
I've made some pretty cool R/C applications for scale helicopters using this. You can even interface it with any onboard Rx. [snip]
Rod.
Looks pretty good. Basic board is about $30 USD. Looks like C code; are there any free compilers available? Is Ardino Programming Language an add-on library?
Old Jun 26, 2010, 11:23 AM
Turbotronic is offline
Find More Posts by Turbotronic
Joined Jun 2010
The $30 board seems real good, you could do a lot with it. A real cheap and dirty would be 2 x 555's and a R2R resistor network driven from a parallel port. One 555 runs in re-trigger mode at 50Hz triggering a second 555 for 1 - 2ms pulses, the period is controlled by the 8 bit D2A ladder from the pc port.
Andre
Turbotronic is offline Find More Posts by Turbotronic
Old Jun 26, 2010, 11:51 AM
cadzilla is offline
cadzilla's Avatar
USA, PA, Milford
Joined Feb 2008
Andre
You lost me after cheap and dirty. I used to know what your talking about but will swear under oath that electrons are how we pick politicians
No ones mentioned Pololu RC Servo Controllers yet [ found them all by myself ]. But I don't understand if it's you download code into it or have interactive control. I don't know if the Arduino requires that too. The goal is automate engine break in not revive dead brain cells.
Old Jun 26, 2010, 12:11 PM
freak is online now
Find More Posts by freak
"Sky Pilot"
Australia, SA, Tea Tree Gully
Joined Aug 2002
Years ago when I was teaching Electronics and Computing to secondary school boys I found the Mini SSC1 and used it successfully to build a robot using six servos. It was a mobile platform with an articulated arm and hand for picking things up. It was controlled using DOS BASIC back then.
I did a quick search and it appears that now there is the Mini SSC2. It's available here: Scott Edwards Electronics
There are many resources available and it appears to be programmable from many different languages.
Cheers,
Eric
freak is online now Find More Posts by freak
Old Jun 26, 2010, 01:56 PM
rcastro is offline
Santiago, Chile
Joined Feb 2008
It is simplified C code. Easy to learn, full of tutorials and code you can download (and not necessarily understand).
The board comes with a FREE and complete development environment (editor+monitor+compiler).
It's an open source hardware and software platform. To compile and program the chip you need nothing else than plugging it in to your USB port, and hit the "play" button.
Old Jun 26, 2010, 02:03 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
just wondering if a soundcard would be able to generate the signal?
cmulder is offline Find More Posts by cmulder
Old Jun 26, 2010, 03:19 PM
Joined Jun 2010
Good point, probably easy to do.
Old Jun 26, 2010, 04:25 PM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
True, but at 44100hz you will only get 44 servo steps.
I second the Arduino approach. Get the Duemilanove version with built in USB to serial converter. The Arduino code to control a servo literally takes less then 10 minutes to write.
http://www.sparkfun.com/commerce/pro...roducts_id=666
jab is offline Find More Posts by jab
Old Jun 26, 2010, 08:41 PM
deswong is offline
Find More Posts by deswong
Brisbane, QLD, Australia
Joined Sep 2007
I've used a picaxe to do something similar.
Was a cheaper option for me than building a 556 circuit, and more versatile.
deswong is offline Find More Posts by deswong
Old Jun 27, 2010, 04:25 AM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
Google is your best option... if you enter the search string as suggested you'll find lots of options from ready built USB units to DIY projects such as the 8ch SSC here . I've built this unit and it work fine with the free software provided on that site, but if you really want fine control then you will need to spend $40 or more on a decent package like this one and then another 50 for some descent software such as this
Malc C is offline Find More Posts by Malc C
Old Jun 27, 2010, 04:26 AM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
Easiest (probably the cheapest also) way IMO:
Get a Serial Servo Controller from Parallax or Pulolu. Depending on what you need the servo to do, either use the free software provided by Parallax / Pulolu or buy RoboRealm (or use the free, older version that lurks the forums here). Hook it up and you're done. I've used this set up to control a 4 motor (thruster) underwater robot, works like a champ. No need for Arduino, way more processor than you need for this task.
gobigkahuna is offline Find More Posts by gobigkahuna
Discussion control a helicopter with PC unleashed Aerial Photography 4 Oct 07, 2009 09:49 AM
Discussion Seagull PC-9 loss of control Glennsdelta Glow to Electric Conversions 0 Sep 08, 2009 06:27 AM
New Product "MINI-FLASH" - The Original PC-programmable LED Flasher/Sequencer with R/C Control Tomapowa Night Flying 3 Dec 09, 2008 07:20 PM
Discussion Where can i get the cable to use with my control to use with the pc simulator? londonandlawson Beginner Training Area (Aircraft-Electric) 5 Aug 03, 2006 08:56 PM
One Big GWS Servo New with Control Horns 25.00 Shipped gbagley Aircraft - Electric - Airplanes (FS/W) 0 Dec 23, 2001 07:05 PM
