Old Nov 04, 2012, 03:36 PM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
HAHAHA...I saw the bacon cokies and then Nightowl's quote of mine and didn't think to look back to the prior page.
Silly me
cityevader is online now Find More Posts by cityevader
Old Nov 04, 2012, 03:38 PM
kpeevyhouse is offline
Find More Posts by kpeevyhouse
Sane til the lift starts!
kpeevyhouse's Avatar
Laguna Beach, CA
Joined Jun 2008
Silly wabbit
kpeevyhouse is offline Find More Posts by kpeevyhouse
Old Nov 04, 2012, 03:43 PM
cityevader's Avatar
Joined Mar 2012
Hey!!
Where did all the posts go that were just before that last one I made?!
It's like we're onto a new page or something...spooky.
Old Nov 04, 2012, 04:37 PM
Lil Stinkpot is offline
Find More Posts by Lil Stinkpot
Egads! It's a GIRL!
Lil Stinkpot's Avatar
Joined Jul 2011
Awwww! A friend was sweet enough to fix my Spektrum Tx for me. I got to fly the Radian today. I forgot how addictive it is! No lift here? Power over to there! This is just for sport flying, mind. I know how it goes, if I want to solely thermal.
The Radian didn't want to act right, and the ESC won't do like the mockingbird and sing, so I need to re-re-bind and see what's up. It was acting funny and the prop wouldn't stop.
Still-- Fun!
Lil Stinkpot is offline Find More Posts by Lil Stinkpot
Old Nov 04, 2012, 05:39 PM
Egads! It's a GIRL!
Joined Jul 2011
:crap: Radian question:
Something isn't right. The motor has no power (no guts, no glory, it won't pull the plane to altitude -- no power), and the brake won't work. I took it off --- is the motor housing supposed to move? Independent of the prop (meaning I can turn the housing one way, and the prop another way)?
For those troubleshooters out there, the battery is brand new and F-R-E-S-H.
Old Nov 04, 2012, 05:45 PM
Egads! It's a GIRL!
Joined Jul 2011
Solved!
The nut came loose somehow from the shaft.
Grrrrr! The nut is STUCK on. I took out the little set screw, and with it all I got were :gasp: metal filings. It's jammed onto the motor shaft.
Now what?
S.T.U.C.K.
Old Nov 04, 2012, 06:09 PM
flyzwell is offline
Find More Posts by flyzwell
flyzwell's Avatar
So Cal
Joined May 2008
Hold the can and turn the prop adapter (nut) and look to see if the shaft has a flat spot on it.
If it does then see if the set screw will still screw in snug without stripping.
If it will then use some loctite on it and don't over tighten.
If the shaft doesn't have a flat spot then I suggest prying it off with something and using a collet type prop adapter.
flyzwell is offline Find More Posts by flyzwell
Old Nov 04, 2012, 06:19 PM
Egads! It's a GIRL!
Joined Jul 2011
The flat spot is gone. The set screw acted like a lathe, and cut a new ring around the shaft. The sucky part is that the "tool" was dull, and was pushing more material than cutting, and the pushed-up ring of prop shaft material created a sort-of lock, keeping the adaptor on the shaft, free-wheeling. Great, I have a new, permanent BEARING on the shaft. Pfffft!
Old Nov 04, 2012, 06:24 PM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
Then your only option is to grind off the aluminum prop adapter, dress the shaft and go with a collet.
Old Nov 04, 2012, 06:28 PM
Egads! It's a GIRL!
Joined Jul 2011
Flyzwell, I did reinstall the set screw, and it seems tight, to my fingers. I don't trust it, though.
Old Nov 04, 2012, 06:31 PM
Egads! It's a GIRL!
Joined Jul 2011
EDIT: What the heck?!? What was here is not what I posted. Oh, well.
Thanks for the help!
I find myself with a problem motor/shaft combo, and I have an idea. There is a building revution in club Radian, changing out the adaptor and blades, making a beer cooler thatcan climb almost vertically. If I'm going to have to replace it all, I might as well upgrade. They say that there's a chance that stock props can shatter without warning. Yuck.
Old Nov 04, 2012, 06:51 PM
Laguna Beach, CA
Joined Jun 2008
Lil,
Maybe you just need a bigger hammer. I can lend you one if you need it.
Old Nov 04, 2012, 06:55 PM
Laguna Beach, CA
Joined Jun 2008
Another mini-Macchi is built and ready to leave my shop for a new home. I really need to build one for myself one of these days.
Old Nov 04, 2012, 07:04 PM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
Now that I'm getting old my 2M planes get small really fast when in the air.
Old Nov 04, 2012, 07:23 PM
Diceman89 is offline
Find More Posts by Diceman89
Ultrabatics enthusiast
Diceman89's Avatar
Joined Aug 2012
+1. Me to
Hey Keith, how much do you charge to make one? Do you make a 24" wingspan one?
Diceman89 is offline Find More Posts by Diceman89
Whoops! Sorry, error, please delete MterBeest Slope 15840 Jun 25, 2010 11:06 AM
Mini-Review Sorry please delete this dup Crushalot Coaxial Helicopters 0 Oct 21, 2009 01:31 AM
Discussion SORRY! Unintened thread - please delete! VTOLicious Coaxial Helicopters 0 Oct 05, 2009 05:18 PM
