Old Feb 09, 2012, 08:59 AM
have wood
atmosteve's Avatar
Australia, QLD, Fraser Island
Joined Nov 2007
Look like poofs, but a great song
The Cult - She Sells Sanctuary (music video) HD (4 min 20 sec)
atmosteve is offline Find More Posts by atmosteve
Old Feb 09, 2012, 06:13 PM
Theoretical Modeler..
plane_tech's Avatar
United States, FL
Joined Oct 2007
Originally Posted by TheNightowl View Post
I just haven't been hacking any balsa since I came down here to Texas, and I'm having withdrawals or something.
Someone get him some balsa STAT!!!
(But ya know, that Avanti would be the same way... Looks like it might be a good PSS subject. What if the canard is used as a pitcheron?)
That would be a good question. A PSS plane would be interesting to see. I have seen someone do a powered model of it, and besides the gear, it was pretty close. The only thing I would question would be the wing area. The tip chord is kinda small. On the full size the tip is only 2.03feet.
If you want to work on some scaling numbers...
Span (overall) 46.04 ft. (14033 mm)
Length (overall) 47.27 ft. (14408 mm)
Height (overall) 13.05 ft. (3980 mm)
Forward Wing:
Span (excluding tip fairings) 11.01 ft. (3356 mm)
Root Chord (FWS 0) 2.58 ft. (786 mm)
Tip Chord (FWS 1647) 1.80 ft. (550 mm)
Dihedral -5°
Main Wing:
Inboard Wing Root Chord (WS 0) 5.99 ft. (1826 mm)
Inboard Wing Tip Chord (WS 1825) 5.03 ft. (1533 mm)
Outboard Wing Root Chord (WS 1825) 4.34 ft. (1322 mm)
Outboard Wing Tip Chord (WS 6925) 2.03 ft. (618 mm)
Dihedral +2°00'
Leading Edge Sweep Angle 1°11’24"
Outboard Sweep Angle (15% chord line) 0°
Horizontal Tail:
Span (excluding tip fairings) 13.97 ft. (4259 mm)
Root Chord (BL 0) 3.76 ft. (1145 mm)
Tip Chord (BL 2100) 2.25 ft. (687 mm)
Dihedral -5°
Sweep Angle(25% chord line) +29.8°
Vertical Tail:
Span 7.70 ft. ( 2346 mm)
Root Chord (FS 814) 8.22 ft. (2507 mm)
Tip Chord (FS 3160) 5.01 ft. (1526 mm)
Sweep Angle (25% chord line) 40°
Areas:
Wing (Total) 172.212 sq.ft (just for comparison, a full size Cessna 172 has 174 sq. ft, with a span of 36 feet)
Forward Wing (Exposed) 13.99 sq.ft
plane_tech is online now Find More Posts by plane_tech
Old Feb 09, 2012, 08:57 PM
Torn 'twixt buildin' and flyin
TheNightowl's Avatar
United States, TX, Austin
Joined Oct 2007
Well, I'm not sure I understand your concern, Tech. Wing area is kind of a non-problem, from my point of view. Even if the wing area is small in comparison to the fuselage area, that may make it develop less lift than a plane with a smaller fuselage with an equal wing area, because of the greater drag/smaller lift of the larger fuselage. But even a model of the space shuttle will glide. Sort of. Give the Avanti controls and give it enough airspeed (get it into fast enough winds), and it will have gliding capability. Just a faster sink rate than something more "floaty." And, of course, we modelers almost never replicate the actual airfoils on full-scale aircraft, as they just don't translate well to the much, much smaller areas and lower Reynolds' numbers. But I've seen practially "flat-plate airfoils" on models of quite a few modern jets with VERY short wing spans used. So even there, they depend more on (relative air) speed than pretty much anything else for energy to stay aloft.
Probably won't thermal worth
Oh, I didn't say it, because it goes without saying, but of course, the less relative wing area you have, the lighter you want to try to make the plane, which is another closely correlative factor to sink rate.
TheNightowl is offline Find More Posts by TheNightowl
Old Feb 09, 2012, 09:00 PM
Joined Oct 2007
(Must.... resist.... urge.... to ... think up... new..... project...... Must..... re......sist!)
Old Feb 09, 2012, 09:08 PM
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
You have lost all will power, you will design the perfect slope glide that can thermal like an Oily II, and can break all existing DS records!
Do not RESIST, let your Inner Designer Reign, Do Not Resist, you will be Absorbed!
Capt. Crunch is offline Find More Posts by Capt. Crunch
Old Feb 09, 2012, 09:14 PM
Joined Oct 2007
Luckily for me, Capt., DSing has NEVER really been of interest to me.
(I did write a Science Fiction story a long time ago about discovering an airfoil that had a negative sink rate. ANY forward movement at all generated lift. The hard part was getting the darned things down.)
Old Feb 09, 2012, 10:28 PM
You can't stop the signal. . .
Mr. Universe's Avatar
Corralitos, CA
Joined Dec 2007
Yeah, that might be slightly problematic. . .
Mr. Universe is offline Find More Posts by Mr. Universe
Old Feb 09, 2012, 10:38 PM
Joined Oct 2007
But it could solve so many other problems!
Old Feb 09, 2012, 11:53 PM
Egads! It's a GIRL!
Lil Stinkpot's Avatar
United States, CA, San Jose
Joined Jul 2011
Spoilers, duh!
Lil Stinkpot is offline Find More Posts by Lil Stinkpot
Old Feb 09, 2012, 11:54 PM
Joined Oct 2007
lol.. back when I wrote that, I knew very little about airplanes except that airfoils developed lift, lifted more with increased speed, and had never HEARD of spoilers... I was probably all of 12 years old.
I honestly wondered back then if there WASN'T a "negative sink" airfoil.
Old Feb 09, 2012, 11:55 PM
registered weapon
IHAVAWDY's Avatar
United States, Mt
Joined Mar 2008
a transmission w/ reverse option?
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Feb 10, 2012, 12:00 AM
Joined Oct 2007
Curiously, my "solution" was almost a form of spoilers! They had pop-up fans on the wings, that popped up and blew toward the front, to slow the plane down to a stop!
Old Feb 10, 2012, 01:13 AM
The original Flyin Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
And while you guys battle it out theoretocally, I am sitting in my car at the field waiting for my flying buddy to do a glide test and then maiden my Nike2...
Up&Away is offline Find More Posts by Up&Away
Old Feb 10, 2012, 01:30 AM
have wood
atmosteve's Avatar
Joined Nov 2007
So, how'd it go?
Getting real close to flying again now, after more than one and a half years! just need to put a new LiPo in the Tx and off we go to yonder coastal slope down the road, yippee!
Old Feb 10, 2012, 03:15 AM
Joined Oct 2007
Sunday afternoon... Salmon croquettes on a bed of creamed peas and carrots, with parsley mashed potatoes, and a side garden salad. Hope she likes it!
Whoops! Sorry, error, please delete MterBeest Slope 15840 Jun 25, 2010 10:06 AM
Mini-Review Sorry please delete this dup Crushalot Coaxial Helicopters 0 Oct 21, 2009 12:31 AM
Discussion SORRY! Unintened thread - please delete! VTOLicious Coaxial Helicopters 0 Oct 05, 2009 04:18 PM
