This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Mar 02, 2013, 05:29 AM
Bridon is offline
Find More Posts by Bridon
Dorset, England
Joined Aug 2005
Originally Posted by RFJ View Post
Bridon,
Doc Mathews Fly Baby from October 1989 Model Aviation. 300 dpi/greyscale.
Ray
Cheers Ray....I know what I will be doing this afternoon now...
Bridon
Bridon is offline Find More Posts by Bridon
Old Mar 02, 2013, 04:11 PM
Bridon is offline
Dorset, England
Joined Aug 2005
Nice link earlier from Trisquire
https://library.modelaviation.com/ma/1989/10/
Spent a very relaxing few hours trawling this one...any other good links like these around?
Regards
Bridon
Old Mar 03, 2013, 12:25 AM
tri-pacer is offline
Find More Posts by tri-pacer
Napa, CA
Joined May 2007
First published in Aeromodeller February 1949.
Ray
Ray
Do you happen to have a scan of this?
Chuck
tri-pacer is offline Find More Posts by tri-pacer
Old Mar 03, 2013, 03:31 PM
WMD is offline
WMD
Find More Posts by WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Skylane 62
Another request for help.
I have some raw scans here just arrived of the (circa 1960?) Carl Goldberg Skylane 62 plan, posted in thanks to JimScott. That's 2 full sheets plus a bonus third of hand-traced formers. The plan is old and tatty and badly in need of a clean-up, and I don't have the time to do that, also frankly I am not that skilled. I have too much to do already running Outerzone, and there are I think better skilled people than me for this job. Any takers?
About a month ago I did this with the big Sterling Stearman PT17 plan, starting here - http://www.rcgroups.com/forums/showp...ostcount=11217 - with a request for help with cleaning up that plan. That project has gone very quiet now... anyone got news on that?
Steve
WMD is offline Find More Posts by WMD
Old Mar 04, 2013, 01:03 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
"the big Sterling Stearman PT17 plan, starting here - http://www.rcgroups.com/forums/showp...ostcount=11217 - with a request for help with cleaning up that plan. That project has gone very quiet now... anyone got news on that?"
Still working on it. About half done on the printwood.
Thanks to John Karmis for scanning and e-mailing his kit parts. Even sheets 11 and 20!
rick.benjamin is offline Find More Posts by rick.benjamin
Old Mar 04, 2013, 05:12 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I'm not intending on hijacking the thread, but have a question you gents will probably able to answer.
I downloaded the plans of the Wolf glider from Outerzone. I like the wingplan (close to my beloved Bird of Time R.I.P.), and the fuse is relatively simple and nice & square-ish.
The plan is for a 75cm wingspan. I want to enlarge it to 150cm.
I've build from scratch, plans, kits and modded ARF's, so I am no stranger to balsa bashing. But I've never dealt with something like this.
Printing the plan enlarged (tiled on A4 pages) is no problem. And I realise that 1mm ribs do not become 2mm ribs etc. But how about the rib spacing, and the number of ribs needed? Is there some formula for this? Likewise with the fuse. I'm sure the formers (size and number) needs adjusting to allow for a proper strong fuse, but how do I decide?
Any help would be greatly appreciated.
Rene
Up&Away is offline Find More Posts by Up&Away
Old Mar 04, 2013, 06:39 AM
DPlumpe is offline
Find More Posts by DPlumpe
AMA 8711, FCC K4WZA
DPlumpe's Avatar
Salem, SC
Joined Mar 2003
Originally Posted by Up&Away View Post
I downloaded the plans of the Wolf glider from Outerzone. (snip)
Rene
To keep the same wing-cubed loading, strength and flying characteristics, just double everything, *including* the rib thickness. Actually, it'll fly slightly better since the Reynolds nbr will increase slightly. Decrease part thickness only if you think it's overbuilt. Feel free to exercise judgement.
Larger projects can justify more parts, so you might want to increase the number of ribs & formers. Decrease part thickness inversely with the increase in numbers - if you double the ribs, use balsa of 1/2 thickness, if they wouldn't seem too spindly. (If you double the size, 1mm ribs would become 2mm. If you then double the number of double-size ribs, use 1mm)
-Dave Plumpe
DPlumpe is offline Find More Posts by DPlumpe
Old Mar 04, 2013, 07:34 AM
WMD is offline
WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Skylane 62
Doh. Forgot to say, the un-cleaned scans of this plan are over the 3MB limit, so have put a zipfile up in the holding bay at: http://www.outerzone.co.uk/advanced/..._bay/index.asp - anyone who wants to have a go, just grab it from there and download the file called Skylane_62.zip
Old Mar 04, 2013, 02:25 PM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Would it it be possible to put the jpg in a "for restoration" folder instead of converting it to pdf?
Old Mar 04, 2013, 02:59 PM
WMD is offline
WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
This is how they arrived, as 3 pdf files. I've just put them into a zipfile together. You want me extract each one out as a jpg? I can have a go...
Old Mar 04, 2013, 03:13 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Hyphen
I just discovered this huge thread - fantastic bit of nostalgia!
I built and flew a Free Flight model called a "Hyphen" around 50 years ago.
Anyone heard of it? Probably designed circa 1950's.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Mar 04, 2013, 04:16 PM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
There is a set of these plans for $21.95 on e-bay(http://www.ebay.com/itm/Vintage-SKYL...item338025df9b) if your just needing for the plans, and a kit (http://www.ebay.com/itm/Carl-Goldber...item20cfcb7423) for $185.00..
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Mar 04, 2013, 04:30 PM
WMD is offline
WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Good point. Ok, if you buy them, pay the delivery too, then pay to get them scanned at a print shop, then email them over to me as a pdf, I'll happily host them on Outerzone.
I'll stand the website hosting costs. Seems fair.
Old Mar 04, 2013, 06:33 PM
Applehoney is offline
Find More Posts by Applehoney
Ajax, Ontario, Canada
"Hyphen"
Howard Gostelow flew one with Dooling .29 for years
Applehoney is offline Find More Posts by Applehoney
Old Mar 04, 2013, 06:43 PM
Joined Aug 2008
Originally Posted by Applehoney View Post
"Hyphen"
Thanks AppleH!
That's a start. Do you know Gostelow? Or is he registered on the forums here?
I would love to find an old picture of one. I had an ED diesel (later converted to glow plug) in mine. 2.5 cc. or .15 cu. inch (I think?).
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 22 Sep 18, 2016 02:22 PM
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 494 Nov 22, 2015 10:48 PM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
