This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Jan 26, 2013, 03:54 AM
WMD is online now
WMD
Find More Posts by WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Originally Posted by perttime View Post
It isn't one of the Sterling PT-17 plans that are up on HPA?
Nope. It's the 64.5 in wingspan Sterling Stearman PT-17 from here : http://www.outerzone.co.uk/plan_details.asp?ID=3704 The big one. The one Edubarca found.
Sterling kit number FS-20
WMD is online now Find More Posts by WMD
Old Jan 26, 2013, 04:50 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Ahhh... I see: You already had the construction plan but the new file has the parts...
perttime is offline Find More Posts by perttime
Old Jan 26, 2013, 06:08 AM
Old_Pilot is offline
Find More Posts by Old_Pilot
Ad eos qui nesciunt crepitus
Old_Pilot's Avatar
United States, TN, Memphis
Joined Dec 2012
Kestrel
All,
Has anyone ever built the Kestrel by Dave Robelen ?......she's a 73" glider.
If so, do you have any tips, tricks, or traps regarding construction. I couldn't find any building instructions anywhere. Does anyone know if they exist ?
The plans are terrific, but without some verbage, I'd be wandering around behind the little animals so to speak.
O_P
Old_Pilot is offline Find More Posts by Old_Pilot
Latest blog entry: SS10X - 90mm flat jet
Old Jan 26, 2013, 06:18 AM
Old_Pilot's Avatar
Joined Dec 2012
Kestrel II
I should have mentioned that she was in MAN, Sept 1968, which I don't have
Old Jan 26, 2013, 06:38 AM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
M m m must have print wood....
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Jan 26, 2013, 07:38 AM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
Mam'selle
Thanks for posting the construction article. Much obliged.
PeterH is offline Find More Posts by PeterH
Old Jan 26, 2013, 07:44 AM
thechannelmast is offline
Find More Posts by thechannelmast
thechannelmast's Avatar
martinsville indiana
Joined Dec 2007
how to fix ziggy lines
i have read every thing nobody talk about how to fix ziggy line in plans when you resize them here is a sample im trying to fix thanks for any help
thechannelmast is offline Find More Posts by thechannelmast
Old Jan 26, 2013, 07:54 AM
Edubarca is offline
Find More Posts by Edubarca
Edubarca
Edubarca's Avatar
Colombia, South America
Joined Oct 2009
Originally Posted by Gary Mortimer View Post
+1 1967250s CAD drawings seem sterile in comparison.
CAD is cold, sterile, and has no human feelings or warmth, I still prefer hand drawings. I just dislike CADS drawings. They are good for architect or engineering plans but not for model airplanes.
Edubarca is offline Find More Posts by Edubarca
Old Jan 26, 2013, 08:32 AM
rchopper56 is offline
Find More Posts by rchopper56
rchopper56's Avatar
Newport News, Va
Joined Sep 2004
Mam'selle
I took the time this morning to OCR Sundancer's post. This should be easier to read.
Geen
rchopper56 is offline Find More Posts by rchopper56
Old Jan 26, 2013, 08:41 AM
eliworm is online now
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
I agree but the laser doesn't like hand drawings. So they can serve a purpose even in model airplanes.
eliworm is online now Find More Posts by eliworm
Old Jan 26, 2013, 09:25 AM
hoffboy is offline
Find More Posts by hoffboy
Matt Haugh
hoffboy's Avatar
Olympia, WA
Joined Feb 2008
I believe those are pixels my friend, which indicates a super low res scan. Need more data, which means a higher resolution scan.
hoffboy is offline Find More Posts by hoffboy
Old Jan 26, 2013, 10:15 AM
starcad is online now
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
United States, AZ, Tucson
Joined Sep 2000
If your scanning use a higher resolution at the bare minimum 300 dpi with 400 to 600dpi for best results. Anything more you're just adding information to the file you don't need. Don't scan in color instead scan in gray scale then import into Photo Shop ( or GUMP ) and adjust your contrast and brightness. Straighten the image and then posterize. Using your paint brush clean up what ever needs to be cleaned in the image. Finally, enlarge to your desired scale and convert to Black and White. ( Not necessarily in that order )
That's about it in a nutshell. There are several tutorials on how to do it in this thread and also on theouterzone. It take practice to get a good drawing from a scan and depending on the drawing it can take anywhere from several minutes to several days to clean to a useful design.
Don't expect your results to look like PlaneMan's the first several tries as it again takes practice through trial and error on your settings and how you manipulate the scans.
starcad is online now Find More Posts by starcad
Old Jan 26, 2013, 10:43 AM
AMA 667982 KG7NKY
starcad's Avatar
Joined Sep 2000
Kinda depends on how you look and intrepid the drawing. After scanning all those magazine plans several months ago, while cleaning the scan you could see where the person that drew the original for the magazine had "tapped" there pencil or smudged a line. After removing the "junk" these drawings POPPED. Same thing happens in CAD with a sterile background resulting in less interference to the eyes resulting (IMHO) a more accurate model.
The other big plus, I have over 4000 designs and if they were all hard copy I would literally be tossed to the street by my wife, no place to store that much paper. 4000 drawings is just a tic on my 4gig net drive and if I need a hard copy my Calcamp takes about fifteen minutes for the largest I've ever plotted.
CAD is also ideal for laser cutting as cutting by hand is almost out of the formula anymore. Nothing like having laser cut leading and trailing edges cut for that elliptical wing or spars cut that just drop in to align the ribs where hand cut would just not cut the mustard.
So, all in all, both have there place in design as I wouldn't want to go to a work site and not be able to see all the drawings laid out on a on a table for reference, however I like to be able to turn on and off layers to get a better picture of the entire project.
Old Jan 26, 2013, 11:22 AM
Ralph B is offline
Find More Posts by Ralph B
Ralph B's Avatar
Brandon Mississippi/Independence Kentucky
Joined Oct 2000
Here is a copy of the construction article from the September 1968 issue of M.A.N.
Ralph B
Ralph B is offline Find More Posts by Ralph B
Old Jan 26, 2013, 01:54 PM
Old_Pilot's Avatar
Joined Dec 2012
Kestrel Text
Ralph B
Thank you so much
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 22 Sep 18, 2016 02:22 PM
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 494 Nov 22, 2015 10:48 PM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
