This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Jan 13, 2013, 06:06 PM
mav913 is online now
Find More Posts by mav913
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
Originally Posted by Old_Pilot View Post
pmackenzie.......
right....I'm referring to the Jetco Thermic C.....I downloaded the plans earlier
and discovered that there were no airfoil or printwood plans.....but that's OK..
I'll pick an airfoil, put it in cad, and proportion it to fit the taper and profile of the wing. I'll upload them if anyone is interested.
O_P
I would greatly appreciate the upload kind Sir.
Thanks John
mav913 is online now Find More Posts by mav913
Old Jan 13, 2013, 07:11 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
I built the kit in about 1962 and the airfoil was no more than the arc of a circle with trailing edge stock for both leading and trailing edges. Seriously, the high point was half way back. Even as a boy it looked crude to me.
On the other hand, in such a small scale a shallow arc isn't a bad choice.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Jan 13, 2013, 08:57 PM
Old_Pilot is offline
Find More Posts by Old_Pilot
Ad eos qui nesciunt crepitus
Old_Pilot's Avatar
United States, TN, Memphis
Joined Dec 2012
Thermic C airfoils and dimensions
As requested....airfoil is base on the proportions of a Square Soar airfoil
adjusted to fit the LE and TE of the Thermic (3/16x1/2)
Old_Pilot is offline Find More Posts by Old_Pilot
Old Jan 13, 2013, 10:03 PM
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
Thank you very much Sir.
John
Old Jan 14, 2013, 12:56 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Models on the Fly, or is that Fly on the Model?
For a bit of comic relief, here are plans and an article on fly powered planes. Inspired by shenanigans at the 1939 Nats, according to the text. Includes shocking accusation against Korda!?! ;-) Plans shown are 3 to 5 inches, text mentions 2 1/2 inches. (Depends on size of fly.) It appears this set of plans may actually have been used, because there is tracing and cutting on the leading edge of plan 2.
lincoln is offline Find More Posts by lincoln
Old Jan 14, 2013, 07:27 AM
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
Now if we could only get a brick on it........
LOL
John
Old Jan 14, 2013, 07:44 AM
keeferm is offline
Find More Posts by keeferm
Joined Jan 2007
Nicely done, Old_Pilot!
keeferm is offline Find More Posts by keeferm
Old Jan 14, 2013, 10:48 AM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
I built many of those fly powered models back on the ranch after I received that issue of MAN. My mother thought it was cruel to the flies! I found the small model could be controlled by the fly, ending up on a window every time. Also the smaller flies seemed to have a better "power to weight" ratio.
California Condor is online now Find More Posts by California Condor
Old Jan 14, 2013, 10:56 AM
Old_Pilot's Avatar
Joined Dec 2012
Fly Power
Now tell me you buuilt a multi-engine version too......LOL
Old Jan 14, 2013, 11:37 AM
bocsiz is offline
Find More Posts by bocsiz
Joined Dec 2011
"For a bit of comic relief"
Absolute first idea!!! LOL
bocsiz is offline Find More Posts by bocsiz
Old Jan 14, 2013, 11:50 AM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
I recall an article in Model Builder, too. So many years ago, probably in the seventies????/
1967250s is offline Find More Posts by 1967250s
Old Jan 14, 2013, 01:28 PM
Ka-6BR is offline
Find More Posts by Ka-6BR
Colorado Springs, CO
Joined Mar 2008
pmackenzie.......
O_P
Try this one. Not much of an airfoil, but this is what Jasco gave you for ribs.
Ka-6BR is offline Find More Posts by Ka-6BR
Old Jan 14, 2013, 03:35 PM
Old_Pilot's Avatar
Joined Dec 2012
Jasco vs Jetco Thermic C
I looked at the Jasco C wing and tried to figure out how to adapt the airfoil to the
Jetco C leading edges and taper, and just couldn't come up with a good way. The Jetco C airfoil has a flat bottom and squared ends for the LE and TE. Also, the Jetco wing tapers from the root airfoil all the way to the wingtip.....The Jasco wing has parallel LE and TE with elliptical tips. The Jetco tip is "square".
So I ended up with a basic 1/3-2/3 foil.
But thanks for trying to help. I know I need all that I can get !
Calm winds
O_P
Old Jan 14, 2013, 08:02 PM
packardpursuit is offline
Find More Posts by packardpursuit
Joined Jan 2009
I would think that a simple full size center rib template rotated downward (pivot point at upper rear of LE stock) to ever shorter rib locations, would automatically taper themselves as long as the top camber determined rib length where it met front of trailing edge stock. Add constant TE thinkness there it cr, cut a new bottom straight line. Sounds more complex than it is. MANY tapered wings have been using this method or variation of it.
I like the Thermic C's. Both of them, but for crying out loud, it ain't exactly rocket science, is it?
packardpursuit is offline Find More Posts by packardpursuit
Old Jan 14, 2013, 08:25 PM
lincoln is offline
Joined Dec 2001
Something here about airfoils meant for that technique:
http://www.hippocketaeronautics.com/...p?image_id=250
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 19 Jan 06, 2016 04:25 PM
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 494 Nov 22, 2015 10:48 PM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
