This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Dec 13, 2012, 10:35 AM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
Here is one, the Pusher Pursuit. The rudders move only outward, held to the center with a spring (torsion) and pulled outward with a cord from the servo.
California Condor is online now Find More Posts by California Condor
Old Dec 13, 2012, 11:39 AM
davidterrell80 is online now
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
On my Cartoon C-119 (a twin boom) I chose to drive one rudder and fixed the other in a neutral position. It flies quite well.
davidterrell80 is online now Find More Posts by davidterrell80
Latest blog entry: Ace Wing Cores
Old Dec 13, 2012, 01:29 PM
Tomahawk is offline
Find More Posts by Tomahawk
Tomahawk's Avatar
Southern Ontario, Canada
Joined Nov 2001
Originally Posted by Sundancer View Post
There are lots of ways, look at Tomahawks build thread for his Plecan Falcon for one. However, the neatest and simplest solution I have seen you will find in detail on Page 8 of this publication: http://www.antiquemodeler.org/sam_ne...sets/dt162.pdf
It's definitely the one I would use.
Wish I had seen that one before I started working on the tail of my Falcon. Unfortunately with mine and this setup, it will work but not quite there as you still end up with different throws between the rudders. One rudder will have more throw than the other in one direction and in the opposite direction the other rudder will have more throw. The plane is still controllable but an issue to be aware of.
If you are planning on using the method George refered to for a large plane. I would recommend a better way to secure the pivit tubes than just glue.
Chris
Tomahawk is offline Find More Posts by Tomahawk
Old Dec 13, 2012, 01:52 PM
Tomahawk is offline
Tomahawk's Avatar
Joined Nov 2001
I looked at that drawing a little closer. Twin rudders are a pain. I noticed that you have to use a Y setup on the pushrod to drive the elevator halves as the bellcrank is in the way if you wanted to use a simple bent wire to connect the two halves.
If your plane is big enough I recommend two small servos to drive the rudders separately.
Chris
Old Dec 13, 2012, 09:26 PM
Captain Dunsel is online now
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
Sorry, but I don't have a picture to explain this.
I did a twin S400 HP Harrow, with all four (two on top and two on the bottom) rudders working. I did it with a pull-pull, using Spiderwire fishing line. I ran the line along the LE of the horizontal stabs, to small ply horns on the outsides of the rudders. From there, I ran the line under the HS, through a tube that ran through the fuse and back again. At the servo, I used EZ connectors and bits of bent music wire for fine-tuning the connection.
It really worked pretty well. I routinely did stall turns, spins, and so forth with the Harrow, without any problems. I finally sold the model last year, just to make room for something new.
CD
Captain Dunsel is online now Find More Posts by Captain Dunsel
Old Dec 13, 2012, 09:46 PM
NOISY MUSE is offline
Find More Posts by NOISY MUSE
USA, Mt, Billings
Joined Mar 2009
Originally Posted by giuseppi View Post
That's the most elegant way to do it that I've seen. The elevator hinges serving as push rod guides...ingenious.
g
CD
I took a closer look at the illustrations this morning...this scheme works well (I'm sure) if the model is fairly small and you're using small diameter (very flexible) wire for the elevator hinge/rudder driver. A larger model with commensurately larger diameter wire for this job will not work, or at best will work poorly and only if you've got a whale of a servo.
Why? As the bell crank is deflected one way or the other the "eye" that the wire is attached to comes off-line from the hinge tube. This requires the wire to bend as it pushes into the hinge tube. If the wire is sufficiently limber this probably works pretty darn well, but since (and this is from memory based on square sections, please correct me if I'm off here) the stiffness of the material increases as a cube of the diameter then relatively small increases in wire gauge create very large increases in stiffness (resistance to that bending).
I'd thought of a similar scheme but not running it through the hinge wire. I'll have to experiment around a bit. That IS a neat sounding solution though!
NOISY MUSE is offline Find More Posts by NOISY MUSE
Old Dec 13, 2012, 09:48 PM
foamdave is online now
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
California Condor:
Are there plans available for the Pusher Pursuit? It's a cutie!
Dave-
foamdave is online now Find More Posts by foamdave
Old Dec 13, 2012, 09:58 PM
USA, Mt, Billings
Joined Mar 2009
Chris
There is NO question that dual rudders are a PITA! The project I'm on is a 60" span Ercoupe from Dare Designs. Being a Pat Tritle design it has a great deal of effort put into keeping it light light light. My concern is that Pat maybe went a bit too far this way, though, by driving the steering nose wheel with the elevator servo. That sounds like a recipe for disaster in a cross-wind takeoff, and we get to do PLENTY of that at our flying field.
The real Ercoupes didn't come with rudders (sold as a "spin-proof" plane), relying instead on ailerons and a fair bit o' dihedral turning duties. Many have been converted to working rudders which (I believe) are coupled to the ailerons and actuated with the steering wheel (no rudder pedals).
While the plane is fairly large I don't think I want to try to balance out two servos (or even one servo) back at the very tail of the plane where their weight has max leverage against whatever is employed to balance them out toward the front. My idea had been to install a fourth below the motor that drives the steerable nose wheel and the rudders. By installing it as far forward as reasonably possible I maximize what leverage it has against the weight of the rudder actuating mechanism(s). That's my thought anyway.
Sounds like it worked a treat, I'm just willing to try almost ANYTHING that keeps me from having to hang servo horns on the outside faces of the rudders. Purely an aesthetic decision on my part.
Old Dec 13, 2012, 10:20 PM
Old Timer
Joined Apr 2001
Originally Posted by foamdave View Post
California Condor:
Dave-
It was published in Air Trails. January 1943. It's an Old Timer because in those days the magazine came before the month of it's date.
Old Dec 14, 2012, 06:13 PM
P_J_Glor is online now
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Originally Posted by planeman View Post
Here is an unusual one, the Jones S-125, a 20" span scale rubber model from Flying Aces magazine. The plans were cut up and placed on multiple pages of the magazine. I assembled them and copied and flipped the half top view with half a stabilizer to make a full top view and a complete stabilizer. I also added the photo.
Planeman
Beautiful assembly job on this plan! You would never know that it was pasted up from separate pages.
Pete G.
P_J_Glor is online now Find More Posts by P_J_Glor
Old Dec 14, 2012, 07:18 PM
tri-pacer is offline
Find More Posts by tri-pacer
Napa, CA
Joined May 2007
Here's a Twin Lizzy rudder setup. The push-rod acts as the stab hinge. If I can find it, I have a good article on twin rudder setup.
By the way, this is someone else's fine craftsmanship, not mine!
Ok, found the article. I've used this: Works great on small stuff.
tri-pacer is offline Find More Posts by tri-pacer
Old Dec 14, 2012, 09:44 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
Neat installation, but I'm surprised it works. The arc of the bellcrank would bend the wire every time you turned. Why wouldn't it bind in the hinges?
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Dec 14, 2012, 10:41 PM
giuseppi is online now
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Jim
It looks like there isn't enough deflection to cause any arcing or binding. I'd like to see some video of the completed model showing both surfaces being manipulated simultaneously. Maybe then it would be more convincing?
g
giuseppi is online now Find More Posts by giuseppi
Old Dec 15, 2012, 02:22 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Looks to me like it would work quite well.
Because the wire is supported it could be quite thin, say 1/32", and still provide solid control.
Wire that thin can bend enough to prevent binding.
The weak link is the bellcrank, they are a potential source of slop in controls.
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 15, 2012, 04:11 AM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
To overcome any binding as the end of the pushrod in the bellcrank describes an arc whilst the rudder pushrods are captive on the elevator hinge line...
(as seen in picture 2)
...simply file the hole in the bellcrank - to make it a short slot that is the width of the pushrod... only a little - towards the tail - will do.
The slop will be minimal - and with both rudders working, the control will be effective.
Keven.
keven64 is offline Find More Posts by keven64
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 19 Jan 06, 2016 04:25 PM
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 494 Nov 22, 2015 10:48 PM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
