This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Dec 12, 2012, 09:03 PM
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
Aeronca52 use this link which is via Google translation
http://translate.google.co.nz/transl...p.html&act=url
Mark
zl3vml is offline Find More Posts by zl3vml
Old Dec 12, 2012, 09:39 PM
USA, Mt, Billings
Joined Mar 2009
Does anyone have a plan that shows a plane with a single fuselage but twin vertical stabs with working rudders? This would be a plane like an Ercoupe or a Miles M.28 Mercury...hell, even something not scale but showing dual rudder actuation. Whether ot or OT, need some help here.
NOTE: a P-38 or other twin-boom fuselage doesn't help here, the key is single "boom" back but twin rudders.
Many thanks in advance for any help! Got a stalled project here that I'd REALLY like to get going.
Scottrik
NOISY MUSE is offline Find More Posts by NOISY MUSE
Old Dec 12, 2012, 10:03 PM
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
Scottrik
Check out this thread:
http://www.rcgroups.com/forums/showthread.php?t=1759579
MetroGTi is offline Find More Posts by MetroGTi
Old Dec 12, 2012, 10:09 PM
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
Here is an unusual one, the Jones S-125, a 20" span scale rubber model from Flying Aces magazine. The plans were cut up and placed on multiple pages of the magazine. I assembled them and copied and flipped the half top view with half a stabilizer to make a full top view and a complete stabilizer. I also added the photo.
Planeman
planeman is offline Find More Posts by planeman
Old Dec 12, 2012, 10:29 PM
UMs & parkflyers... for now.
davidterrell80's Avatar
United States, VA, Herndon
Joined Apr 2012
To access the back issues on edimodel.it ... From the toolbar, choose download, then documentazione.
I opened the PDF files in Adobe Acrobat, and used the OCR function (set to Italian) to extract the text from the scanned images and re-save them. Then, I can copy/paste sections of text into the Google Translate function.
davidterrell80 is offline Find More Posts by davidterrell80
Old Dec 12, 2012, 10:37 PM
USA, Mt, Billings
Joined Mar 2009
Originally Posted by MetroGTi View Post
Thanks much, Metro. That is kind of how I'd envisioned this but I was REALLY hoping not to hang big ol' horns off the outside of the rudders. May be doomed to that though.
Anybody else know how this can be done?
Old Dec 12, 2012, 11:53 PM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
I've been thinking about this issue on a Vintage conversion. What I may try might work on a lightweight, but possibly not on anything else that has any sort of control forces. Until I find a better idea, my plan is to have a single servo in the centre of the stab, and have both rudders sprung to move outward (in my case, this will be a simple rubber band from fin to a hook on the outboard side of the rudder), Then the single servo output arm will be attached to the inboard of both rudders by carbon fibre rod. Hence when the rudders move, the forces should be balanced, as one rudder is working against the spring (rubber band) tension, and one with. For a less visible system, it may be possible to adapt this system to bury the servo & pushrod in the stab, and use leaf springs for the spring loading? Just idle thoughts....
Colonel Blink is offline Find More Posts by Colonel Blink
Old Dec 13, 2012, 12:07 AM
Joined Oct 2011
Noisy Muse,
Dual rudder single fuselage
The Schlepp 3605 in this thread:
http://www.rcgroups.com/forums/showthread.php?t=1292378
Geoff
DHfan is offline Find More Posts by DHfan
Old Dec 13, 2012, 02:45 AM
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Scottrik
There are lots of ways, look at Tomahawks build thread for his Plecan Falcon for one. However, the neatest and simplest solution I have seen you will find in detail on Page 8 of this publication: http://www.antiquemodeler.org/sam_ne...sets/dt162.pdf
It's definitely the one I would use.
Sundancer is offline Find More Posts by Sundancer
Old Dec 13, 2012, 02:55 AM
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
George, the link didn't work for me, could you kindly check please...
Brian
brokenenglish is offline Find More Posts by brokenenglish
Old Dec 13, 2012, 03:10 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Brian
Try it now Brian. Don't know why it didn't work before, it is exactly the same???
Old Dec 13, 2012, 07:25 AM
USA, Mt, Billings
Joined Mar 2009
Originally Posted by DHfan View Post
Noisy Muse,
Geoff
Many thanks, but does not appear to have functioning rudders. That's the problem I'm facing wth the kit I'm building. Truly, thanks though.
Scottrik
USA, Mt, Billings
Joined Mar 2009
THAT looks like it may be a winner. I'll take a closer look at it!
Old Dec 13, 2012, 09:29 AM
Joined Sep 2011
Scottrik
NO plan, but here is a photo. You can see a bowdens to both rudders in elevator. Just insert smaller diameter wire in it, because origilal vire will rub.
janyx is offline Find More Posts by janyx
Old Dec 13, 2012, 10:25 AM
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
That's the most elegant way to do it that I've seen. The elevator hinges serving as push rod guides...ingenious.
g
giuseppi is offline Find More Posts by giuseppi
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 284 Jun 14, 2013 09:48 AM
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 18 Nov 09, 2012 07:56 AM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
