This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Sep 25, 2012, 12:18 AM
GeorgeG97322 is offline
Find More Posts by GeorgeG97322
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
How about Karlstrum drawings of the Ryan...
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old Sep 25, 2012, 04:23 AM
DukeRoger is offline
Find More Posts by DukeRoger
Joined May 2012
Originally Posted by jonquinn View Post
does Wicherek translate into something in english?
thanks for posting the nice polish aircraft drawings and plans.
wicher is whirlwind and well wicherek is a small whirlwind soft form
DukeRoger is offline Find More Posts by DukeRoger
Old Sep 25, 2012, 06:09 AM
WMD is online now
WMD
Find More Posts by WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Frog Firefly
This one just arrived in this week, as 16 x A4 scans which I had to stitch together carefully, so there may well be errors hidden in the wing rib spacing etc... Frog Firefly sports biplane. 36in wingspan. Sadly there is no printwood with it, no instructions. But a beautiful plan, I do think. The kit originally came with a moulded balsa fuselage in two parts, so it's going to be a challenge to try and build this from just the plan. Lots of formers and planking, I guess.
Don't suppose anyone out there has printwood for this? Or a photo of a completed model?
WMD is online now Find More Posts by WMD
Old Sep 25, 2012, 06:44 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
You are so right Steve, a lovely plan - I have an original - well, a photocopy - but as you say no wood patterns. I never built the Firefly but I did build a Fox which had the same moulded balsa fuselage, this was lovely but the inadequate wing mounting pylon let the model down. This one would certainly be a challenging build, looking at the fuselage lines, I think that it would be possible to reproduce the moulded shell structure if you went to the trouble of making a mandrel, two layers of soaking wet 1/16" balsa and yards of elastic bandage would do the trick then, removed when dry and glued up back on the mandrel with a layer of tissue in between. The finished model would be such an attractive shape it would be worth the trouble.
I love FROG models.
Sundancer is offline Find More Posts by Sundancer
Old Sep 25, 2012, 09:23 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
If you go to 6.00 minutes into this video, you can see a Firefly in flight and landing.
It's not detailed, but better than nothing, I suppose.
There's usually a few to be seen at Cocklebarrow. A guy called Mike Womersley has a twice-sized one.
Cocklebarrow Farm, RC model flying. (9 min 25 sec)
bogbeagle is online now Find More Posts by bogbeagle
Old Sep 25, 2012, 11:03 AM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
George
Could you put them up in Adobe pdf's? Nice drawings. Thanks
1967250s is offline Find More Posts by 1967250s
Old Sep 25, 2012, 11:41 AM
scaleviews.com is offline
Find More Posts by scaleviews.com
scaleviews.com's Avatar
United States, IL, Edinburg
Joined Dec 2010
Spirit of St. Louis - Karlstrum Drawings
Hi George,
The Karlstrum planviews of the Spirit of St. Louis are just what I've been looking for. I'll be using the Karlstrum planviews as the basis for drawing my own plans for a detailed scale model of this aircraft.
I just found and ordered a vintage copy of the March 1959 Model Airplane News. So hopefully I will soon have source material for scanning and generating some higher resolution PDFs of the Karlstrum drawings suitable for printing at various scales.
George, thanks very much for putting me on to these planviews. If someone else doesn't beat me to it, I'll make higher resolution PDFs of the Karlstrum Spirit of St. Louis drawings available to others with an interest once I've completed the work.
Bob Keller
scaleviews.com is offline Find More Posts by scaleviews.com
Old Sep 25, 2012, 03:02 PM
PeterH is online now
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
RWD-5 plans read-only
Still can't save this drawing to my thumb drive. There is no check box on my 'properties' for the file that allows me to suppress a read-only characteristic. I click on save as/pdf, pick the drive, and get the read-only message. When I go into the properties, no check box. I suspect that the person who can manipulate the read-only option is the document's owner, not someone copying it. Other ideas will be welcomed.
Thanks, folks.
PeterH is online now Find More Posts by PeterH
Old Sep 25, 2012, 03:25 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Thanks, folks.
It saves fine for me. Try saving it to HD. Maybe re-format your TD?
g
giuseppi is offline Find More Posts by giuseppi
Old Sep 25, 2012, 05:04 PM
Joined May 2012
Bu-131 Jungmann and others
Hello Again
Today I have for you two projects: first is model done by Wieslaw Schier which represents german training plane from 1935 Bu-131 Jungmann. Funny part about it is that in 1950s everything german was straight to the point forbidden. From that reason this nice plane had to be presented as C-104. I'm attaching original drawings from 1955 and available now original manufacturing drawings of real plane from 1935.
Model scale 1:10
Model length 670mm
Wing span 740mm
Designer: Wieslaw Schier
Published 1955
As others I'm adding drawings of lovely A2 class sailplane from 1954 called OM-42 designed by Mieczyslaw Opalinski
PS: tomorow I will scan DKD1 drawings I found in my archive
Old Sep 25, 2012, 10:28 PM
Power Upward
Joined Jun 2007
PDF of Ryan NYP for those who requested it...
George
Old Sep 26, 2012, 07:21 AM
mikempp is offline
Find More Posts by mikempp
United States, FL, The Villages
Joined Nov 2008
[QUOTE=bogbeagle;22828979]If you go to 6.00 minutes into this video, you can see a Firefly in flight and landing.
Does look like it flys nice!
mikempp is offline Find More Posts by mikempp
Old Sep 26, 2012, 07:44 AM
Joined Mar 2007
They do fly pretty well ... to be fair, that video clip does not do it justice.
How could they fail to fly well? ... lots of wing, lots of tailplane. What's not to like?
Old Sep 26, 2012, 05:21 PM
1967250s is offline
1967250s's Avatar
Joined Sep 2008
George
Huge Thanks!!!1
Old Sep 26, 2012, 05:55 PM
Joined May 2012
DKD1 as requested
I hope to be forgiven that plans are not ancient.
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 19 Jan 06, 2016 05:25 PM
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 494 Nov 22, 2015 11:48 PM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 10:30 AM
