Old Jun 25, 2010, 02:11 AM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
new MK Octo frame
Finished a new Octo frame design for use with MK components. Same weight as stock MK frame but more rigid and easier to replace/repair components
Carbon fiber & aluminum used throughout.
Test flights next week.
Photoship One is offline Find More Posts by Photoship One
Old Jun 25, 2010, 02:21 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
very nice. just out of curiosity, how is it controlled? as a quad? w/ tx mixing?
bob4432 is offline Find More Posts by bob4432
Old Jun 25, 2010, 02:49 AM
by Alary Design
Joined May 2002
it is controlled with Mikrokopter Octo software loaded onto the Flight Control board.
Old Jun 25, 2010, 03:10 AM
ddmt is online now
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
Very nice DJ, now is it possible to make it foldable?
ddmt is online now Find More Posts by ddmt
Old Jun 25, 2010, 07:08 AM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
looks great AZ .....looking forward to sky time ....
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Jun 25, 2010, 07:16 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Very Interesting, very interesting indeed.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jun 25, 2010, 12:46 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Yes I second the foldable design.
And if you can make replacement parts easily obtainable (Like T-Rex helicopter tailbooms) then this will sell like hotcakes!
Steph280 is offline Find More Posts by Steph280
Old Jun 25, 2010, 02:41 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
AZ, I see some stock Gaui 425 or X5 parts there.. did you shorten the stock tail booms, or...? Hard to determine scale from the photos...
BobRCnut is offline Find More Posts by BobRCnut
Old Jun 25, 2010, 06:00 PM
by Alary Design
Joined May 2002
Bob, you are correct. They are X5/550 booms and clamps. I simply cut two 550 booms exactly in half (11.25")
Replacement parts for this frame are ridiculously cheap. The booms come out to about $3.50 each and the motor plates are G10 at about $10 each.
Test flew just now. Man this thing is so much more rigid than the factory MK Octo frame. Flies GREAT!!!
Old Jun 25, 2010, 07:10 PM
BobRCnut is offline
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Thanks, AZ... the reason I asked is because I want something a bit larger than 330X size, and I was looking at both the 550 booms and the X5 boom clamps earlier this week, thinking along those exact same lines. Unfortunately, all the boom clamps disappeared from stock (now I know where they went... grin). I can use the stock FRP 425/550 clamps, although they're a bit narrow for the motor mount end. I have a sizable supply of high-quality 3mm light plywood I can use for the center plates (C/F is great but hard to work with). Thanks for sharing the R & D work so far. I'm just getting into the multi-rotor game and learning all I can.
Old Jun 25, 2010, 09:47 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
@ AZ,
Nice frame!
@Bob,
This might help you a bit: Quadrocopter and Tricopter Mega Link Index
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Jun 26, 2010, 11:33 AM
outsider787 is offline
Find More Posts by outsider787
outsider787's Avatar
Canada, ON, Toronto
Joined Dec 2007
What clamps are you guys talking about?
Anyone have a link?
outsider787 is offline Find More Posts by outsider787
Old Jun 26, 2010, 12:10 PM
BobRCnut is offline
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
AZ and Jim, thanks for the helpful info. I've read most of the info from the Mega Index, and I still have a number of questions, so let me give you some background first:
My scratch-built quad (1st attempt) is done and ready for the electronics setup. It's basically a 330X knockoff built from Depron, Lite Ply, and C/F rods. I got started on all this because I wanted to see if my Aurora 9 was capable of handling the required quad pitch/roll/yaw control with no need for onboard mixing. That part is done and working. The quad setup is:
4-Hyperion Z2205-46 motors, 4 Gaui 210 gyros, and 4 Hyperion Atlas ESCs. So far, I've tested each motor/ESC/gyro set individually, and they work as hoped, with some minor
quirks. The TX mixing does what it's supposed to according to the servo monitor screen. Power setup is a 2S-2200 pack supplying power to the system through the ESC's BECs (all 4 ESCs supply power.. the Aurora's telemetry function shows 6.0 V. at the Rx)
Yaw control is via torque reaction, no gyro there yet. All mixing functions were tested by firing it up with all 4 motors/ESCs but no gyros.
First, some basic gyro setup questions.
1. Can I get away with using a single Rx channel output to control the gain on all 4 gyros? After all the TX mixing required, I don't have enough channels left to use an independent gain channel for each gyro.
2. I'm guessing that each gyro's "Limit" setting should be set to max, to avoid restricting the RPM range... correct?
3. Should gyro output be set to 'digital servo' rather than analog when driving ESCs?
Now, here's the quirk: When I power up (with only one gyro/ESC/motor connected), the receiver initializes (no linkup delay at all), the gyro initializes, and then the ESC signals three beeps, but will not activate the motor until I move the throttle stick up and down slightly. Once that's done, the ESC tells me it's now armed, and the motor RPM follows the throttle, elevator, aileron, or rudder stick movements as hoped.
According to the ESC documentation, three beeps says, "I am in programming mode", but the Atlas ESCs are programmed via IR controller (same as Scorpion), and the only transmitter-programmable setting is throttle endpoints. I can set throttle endpoints OK (either with our without the gyro in the circuit).
Any thoughts? Suggestions?
Old Jun 26, 2010, 07:52 PM
kirk222 is offline
Find More Posts by kirk222
Virginia Mountains
Joined Mar 2010
Looks nice. How does it do with a heavy yaw?
Kirk
kirk222 is offline Find More Posts by kirk222
Old Jun 26, 2010, 08:27 PM
BobRCnut is offline
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Anyone have a link?
Here ya go... http://www.allerc.com/product_info.php?products_id=5528
For Sale New Mikrokopter MK NaviCtrl V1.1 and MK3Mag Beauregard Aircraft - Electric - Helis (FS/W) 4 Aug 03, 2010 06:54 AM
Sold New Alfa 60/15 MK.2 OCLightning Aircraft - Electric - Jets (FS/W) 0 Dec 12, 2009 02:03 AM
Sold MIA G10 4#3 frame built/new, v2 servos, MIA canopies, HP05 new ForceFedDSM Aircraft - Electric - Helis (FS/W) 5 Sep 24, 2009 09:32 PM
New Product T-REX 600N side frame broken? New 2mm side frame set is here HeliDirect Electric Heli Talk 8 Jun 22, 2007 07:20 PM
Another New frame for trex(gerry frame) will p3 Mini Helis 12 May 25, 2005 07:43 AM
