Old Jun 24, 2010, 04:09 PM
rbachmann is offline
Find More Posts by rbachmann
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Help!
Flash Updater V2.2 for Graupner XD6
Jim.
Today i tried to update my Graupner XD-6 Transmitter and my three XR-6 Receivers from V3.7.to V3.8 (Updater V2.2).
All flash processes worked fine, no error message.
After flashing the transmitter shows correctly V3.8 but all receivers show still V3.7.
Any advice?
Roland
rbachmann is offline Find More Posts by rbachmann
Old Jun 24, 2010, 06:27 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Did you remove the old software before installing V2.2?
Bob
bruff is online now Find More Posts by bruff
Old Jun 25, 2010, 01:29 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Sounds like you are using the older updater by mistake.
JimDrew is offline Find More Posts by JimDrew
Old Jun 25, 2010, 02:26 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
No, i didnīt remove any software.
I installed the lastest xdp version and then ran the "updater v2.2.exe" file.
Was that wrong? I also found that after running the updater file the headline still shows version 2.1.
Roland
Old Jun 25, 2010, 03:24 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
If it says, v2.1 then that is what you are running (not v2.2).
Old Jun 25, 2010, 05:09 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
I downloaded the "updater v2.2.exe" file directly from your homepage and immediately ran the exe-file.
The headline of the updater still shows V2.1.
Very mysterious.
Concerning "bruff"s post: do i have to remove any software before installing the new xdp version?
Anyway, if it really was the 2.1 version it should also update to v3.8. But this doesnīt work. What can i do?
Old Jun 25, 2010, 11:10 AM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I did it just to make sure all the old version was removed. Not sure you have to.
Bob
Old Jun 25, 2010, 01:41 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
http://www.xtremepowersystems.net/xdp/updater22.exe
It should show the version as v2.21
Old Jun 26, 2010, 06:19 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
... uups, sorry Jim, you are absolutely right.
I misread the headline and skipped the "2" behind the dot.
Meanwhile Graupner told me that version 2.2. ist not suitable for the XR-6 3-channel receiver.
Can you confirm that? That would explain the whole thing.
Roland
Old Jun 26, 2010, 06:21 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Bob
Thx, good advice. I will try that and reinstall the software for future updates.
Roland
Old Jun 26, 2010, 01:07 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Does your receiver have a RED/GREEN/BLUE LED or does it have just the RED/GREEN LED?
Old Jun 26, 2010, 02:09 PM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Red/green/blue ...
Originally Posted by jimdrew View Post
does your receiver have a red/green/blue led or does it have just the red/green led?
Old Jun 27, 2010, 05:09 AM
ktmraupe is offline
Find More Posts by ktmraupe
Hanover, Germany
Joined Oct 2009
Jim,
i have problems with the Flash Updater V2.2, too. I canīt update my Satellite. Every time i try i get an error.
To put in programming mode i do this:
press and hold the programming button while turning on the power. There will be a brief pause and then the LED will light up orange. Release the programming button and receiver should then ready to connect.
Connecting to the XDP software is no problem.
By the way. What is the difference between the updater 2.1 and 2.2?
regards
Martin
ktmraupe is offline Find More Posts by ktmraupe
Old Jun 27, 2010, 04:14 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Not sure why there is an issue with the satellite receiver, but there has not been an update in a very long time, and there likely will not be any updates for the original hardware we have produced.
Old Jun 28, 2010, 08:27 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
... and what about the 3-channel receiver with red/green/blue led? Is ver. 3.8 suitable or not?
Discussion Anyone converted Hitec Flash 5 to 2.4ghz? inferno6688 Radios 23 Mar 24, 2011 02:09 AM
Sold Hitec Flash 4 Tx with 2 Rxs and 2 servos dbrickma Aircraft - General - Radio Equipment (FS/W) 4 Jan 29, 2010 10:31 AM
Alert V3.6 Tx firmware via updater JimDrew Xtreme Power Systems 4 Nov 17, 2009 12:24 PM
Discussion corona 2.4 module for futaba installed on graupner mx-12 ebonomi Radios 0 Sep 21, 2009 03:25 PM
Hitec Flash 5X, 2 HS-55, graupner speed 300, 6-cell 1000 mah, GWS rxr, and misc FS J-S Aircraft - Electric - Airplanes (FS/W) 4 Apr 18, 2004 03:44 AM
