Big news: My Champ flew home!!! It only took 3 days, but it found it's way back down the tree. Kind of like when your cat climbs one and pretends it is stuck. It's in great shape except for a few creases in the foam that I taped and back to normal. Thanks for all the tips, guys, because now I have a fishing line and weights ready for the next time!!!
Also, I realize now that I have to design a rescue course for my SR120. I'm going to create a heli with a line and practice picking things up. I'm really wondering if I could do a heli rescue, but I'm going to have to build courage.
Saxguy:
Another method of plane tree retrieval is a paintball gun and shoot it down. I am having trouble with the DX8 file that you sent me. The tail rotor does not turn, only the main rotor turns. If I reverse the rudder in the radio only the tail rotor spins. It works fine on my sons DX6, so it must be something in my DX8. Any ideas? Thanks for your help!!!! Gary |
Man, it's not the file causing that. You can check, though, by binding to another model number. Without the settings, just bind to either aero or heli--either way--and it'll work just like the stock tx (only better.) If then your tail rotor works, it's would be the file. Reload the file if that is it.
However, I'm sure it's not your DX8. It's the motor. Check where your tail motor plugs into the board and the connection at the motor. If that is good, try another motor--they go out a lot and they aren't too expensive. |
Don |
![]() Sax, a PM? We all want to learn. No secrets here![]() ![]() Mike. |
I am glad you got your champ back. I bound it to my sons DX6 and the heli worked fine. I will try your suggestions, I can always manually put the settings in another model, there are many options. I was hoping you or someone would have a brilliant idea and I change one setting and be done. Thanks Gary |
In fact you could deliver logs to your yard for winter firewood. ![]()
| Thread Tools | |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro Helis | 6526 | Jan 12, 2013 12:20 PM |
| Discussion Update Blade CP or buy E-Flite Blade SR or 400? | markhwing | Electric Heli Talk | 10 | Aug 06, 2012 03:16 PM |
| Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others | everydayflyer | Batteries and Chargers | 45 | Apr 08, 2010 04:55 AM |
| For Sale Did you just buy a new E-Flite Blade SR? | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Feb 28, 2010 12:01 AM |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro RTF | 2 | Jan 07, 2010 09:36 AM |
