Old Aug 06, 2012, 03:08 PM
Memorial Day. May 27th
Chap1012's Avatar
USA, MA, Malden
Joined Mar 2008
I was laughing,,.. you Guys talking about something caught between the cogs...lol. I was flying my V4, and, after a slight blade strike on some outdoor furniture, my V4 kept making this clicking noise that was driving my crazy...even though she was flying just fine. So, I landed and brought her inside. Inspected. Saw the problem. Went outside to retrieve the missing piece
This was still flying mind you
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Aug 06, 2012, 03:35 PM
Flight Freak
BattleDude's Avatar
United States, WY, Crowheart
Joined Aug 2011
Mike.
You gotta be kiddin me Bro? That thing was still flying? Wo!
BattleDude is offline Find More Posts by BattleDude
Old Aug 06, 2012, 03:39 PM
Chap1012's Avatar
USA, MA, Malden
Joined Mar 2008
lol....I sheeet me pants when I saw that too. Unbelievable
Old Aug 06, 2012, 03:50 PM
Flight Freak
BattleDude's Avatar
Joined Aug 2011
How tight is too tight? I have found that tips passed off to me I try to pass off to you.
Tighten the blade screw tight enough where it will hold both blades horizontal to the floor, nose of heli pointed downward. Now, with a slight "downward jerk" the blades will fold down. That's how I adjust my "blades to blade grips."
This is how I do my 120SR and V4 folding blades.
Mike.
I like my blades just a tad bit looser, so they just start to fall, without the jerk.
Kyle
Old Aug 06, 2012, 04:03 PM
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Originally Posted by North_of_49 View Post
Runnikee,
When it's doing the toilet bowl thing is it always pointing at the same heading... for example, north?
Yeah, my heli always points toward North when it has tbe.
Mike is the one who kept insisting that a cracked main shaft was a major source of tbe. I wasn't convinced until a couple of weeks ago when my heli became unflyable.
I stubbornly tried everything else but finally got around to examining the shaft more closely. Taking the screw driver that came with my heli I VERY gently pushed it into the top of the shaft. Sure enough, I found a hairline crack that appeared to have started at the topmost hole and propagated upward.
I replaced it with a new one and... VOILA! The tbe was worse than ever. Huh?The brand new shaft was cracked! Tried another new shaft - same story!
Finally in desperation I put a tiny drop of ca on the very top of the shaft where it would wick down into the crack. I immediately wiped off any excess glue and let the shaft cure for about 30 minutes before putting the heli back together... VOILA! PROBLEM SOLVED! I've been flying with the repaired shaft ever since with no hint of tbe.
At least one other peep has reported a cracked shaft right out of the package. I think it may happen when the holes are drilled too fast. It's worth checking out!
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Aug 06, 2012, 04:17 PM
Flight Freak
BattleDude's Avatar
Joined Aug 2011
I stubbornly tried everything else but finally got around to examining the shaft more closely. Taking the screw driver that came with my heli I VERY gently pushed it into the top of the shaft. Sure enough, I found a hairline crack that appeared to have started at the topmost hole and propagated unward.
That makes perfect sense to me Pilgrim, as I mentioned earlier, I believe TBE is caused by any wear, damage, or mis-assembly, that causes the flybar to be "out of phase" with the head/rotor assembly.
But I think you need to let HH know about thier problem with a brand new shaft being cracked.
BD/Kyle
Old Aug 06, 2012, 04:27 PM
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
What I'm wondering is... does the nose always point at one particular heading regardless of where the heli is in its trip around the "funnel," which is a symptom of TBE ... or does the nose follow the funnel, which is not.
I think I know the probable answer... but you never know, sometimes people aren't talking about the obvious when describing something
North_of_49 is offline Find More Posts by North_of_49
Old Aug 06, 2012, 04:54 PM
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
Nose always points in the same direction. I'll try the CA solution and see if it helps. Keeping my fingers crossed. Wow, this is the place to go. You guys know a lot!
Runnikee is offline Find More Posts by Runnikee
Old Aug 06, 2012, 05:23 PM
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
I made sure to wipe off the excess ca right away, and I let the shaft cure for at least a half hour. Good luck!
Old Aug 06, 2012, 06:20 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Mike.
Whoa, Mike! That definitely takes the cake. Maybe you ought to consider flying with 75% of ALL your parts because it'll save a LOT of weight!
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Aug 06, 2012, 06:22 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
This is why I put a drop on my shaft for every new one I get. It has saved a lot of trouble. But, you ask, why are you replacing the shafts?? I have built several of these 120s from scratch parts!
Old Aug 06, 2012, 08:19 PM
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Let us know if you ever decide to have a "scratch and dent" sale.
Old Aug 07, 2012, 02:38 AM
United Kingdom, Oxted
Joined Dec 2011
Mike.
That was so bad that I didn't see it at first. I thought something was covering ppart of the wheel. Amazing that it continued to fly.
My clickety clacking was caused by so little in comparison to that, it's crazy. No damage elsewhere either?
iancraig10 is offline Find More Posts by iancraig10
Old Aug 07, 2012, 01:25 PM
Newbie but coming on fast
KYChopper's Avatar
United States, KY, La Grange
Joined Jun 2012
Mike.
No way! How was this even flying?
KYChopper is offline Find More Posts by KYChopper
Old Aug 07, 2012, 01:27 PM
KYChopper's Avatar
Joined Jun 2012
On a different note, the wind gods finally cooperated yesterday and I was able to take my 120 outside for a flight. It seems that it had very little power for FFF; otherwise it acted normally. Could this be a case of a tired old main motor or is this common?
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6526 Jan 12, 2013 12:20 PM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro RTF 2 Jan 07, 2010 09:36 AM
