Old Aug 02, 2012, 09:37 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Originally Posted by installerblizz View Post
Just to clarify - when you guys say you have cut your blades 10mm, you do mean that you cut 10mm off each blade, for a total rotor diameter reduction of 20mm?
Yes. But you might want to start with 5mm per blade and work your way up. Balancing and tracking the blades is important too.
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Aug 02, 2012, 11:00 PM
installerblizz is offline
Find More Posts by installerblizz
This is a hobby. READ UP!!!!!!
installerblizz's Avatar
United States, FL, Bradenton
Joined Jun 2012
Thanks! I actually trimmed 10mm off each about a week ago. I have since balanced them, the flybar, and tail rotor. The ability to fight wind is like night and day. Before I was hesitant to fly when there was any wind but now 15 mph winds are manageable. It's a challenge, but it only serves to build my skills. I did miss the loss in lift at first, but I installed the Xtreme motor today and now have a Hyperion 25C battery and the lift seems back about what it was before the blade trimming. I did develop some mild tail wag (1/4 inch back and forth every second or so), but trimming 7mm (total) off of the tail rotor eliminated it completely, after balancing of course. This is exactly what I wanted out of a heli. I came from a V911 and wind was its nemesis.
installerblizz is offline Find More Posts by installerblizz
Old Aug 02, 2012, 11:11 PM
rwek is offline
Find More Posts by rwek
St. Louis, Mo.
Joined Jun 2008
See post #14516. Also, does the drift occur on takeoff or does it persist or start up again after you achieve stable hover?
More so after it reaches a stable hover. Has some drift right off the bat getting off the ground, but mostly after that.
Nice vid in the house. Hovering like you did is my goal.
rwek is offline Find More Posts by rwek
Old Aug 03, 2012, 08:19 AM
iancraig10 is offline
Find More Posts by iancraig10
United Kingdom, Oxted
Joined Dec 2011
What really surprises me with the 120sr is how small the tolerances are. Mine has been wobbling very slightly and the tail was quivering in flight. I could see nothing wrong whatsoever.
Today, I tried different tensions on the blade grips and I found that there was a 'sweet spot' but the quiver was still (just) there. Tightening and loosening the grips made the blades track a little better.
Then I replaced the flybar. The new one could spin in a table mat and the old one wouldn't. So little difference, it couldn't be seen. (No oval shape in the middle of the old one)
I fitted the new one anyway and the heli now hovers smoothly!! We're talking gnat's differences here so those tolerances are pretty critical to get it to fly smoothly to say the least.
iancraig10 is offline Find More Posts by iancraig10
Old Aug 03, 2012, 09:13 AM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
+1 And it's a moving target - the helicopter is such a dynamic machine that it seems SOMETHING is always going awry. After more than a year flying just two types of helis (two MCX2's and one 120 SR), chasing that elusive "sweet spot" is what keeps me interested.
btw what does "spin in a table mat" mean?
Old Aug 03, 2012, 09:53 AM
Joined Dec 2011
Sorry - me and words - spin ON a tablemat. 'O' and 'I' are so close to each other on the keyboard. Solly me.
The old one was slightly curved for some reason. More on one half than the other and it was barely noticeable. The only reason I saw it was the fact that I spun the new one on a tablemat and it spun freely. The old one didn't which pointed out that it wasn't actually flat.
Also, the blade grips were not at the same tension so one of the blades was rising slightly higher than the other, resulting in a slight imbalance.
The thing is, these adjustments are so minute each time but they do make a big difference to the hover in particular.
I put it all back together with its new flybar this afternoon and gave it a spray with a silicone lubricant.
I feel as though I have a new heli; especially now I have the Extreme canopy on as well!!
Old Aug 03, 2012, 02:18 PM
ssobol is offline
Find More Posts by ssobol
Joined Aug 2007
Just to be clear...
Drifting can be cured either by adjusting the mechanical linkage or by dialing in some trim with the tx.
The tendency to roll to the right in forward flight is not caused by the heli "lean"-ing; it's caused by asymmetrical lift. The rotors turn clockwise when viewed from above; in forward flight the blade on the left side of the heli is moving through the air faster than the blade on the right. Faster blade = more lift. More lift on left = roll to the right. Mixing aileron (roll) in proportion to stabilizer (pitch) counters the extra lift so the heli flies straight ahead (or at least follows its nose) in fff.
Remember, hovering into the wind is the same thing as flying forward. Depending on the amount of wind you will end up with some asymmetric lift from the relative airspeeds of the blades on different sides of the rotor. If you adjust the aileron mixing based on stick position you may not get enough aileron compensation in this situation.
ssobol is offline Find More Posts by ssobol
Old Aug 03, 2012, 06:06 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Excellent point. I had the best results adjusting the mixes (AILE > ELEV & RUDD > THRO) in the gym last winter.
Of course I have to use completely different settings (a different tx model actually) when flying in confined spaces.
Old Aug 03, 2012, 09:41 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Blade grip tension
How tight is too tight? I have found that tips passed off to me I try to pass off to you.
Tighten the blade screw tight enough where it will hold both blades horizontal to the floor, nose of heli pointed downward. Now, with a slight "downward jerk" the blades will fold down. That's how I adjust my "blades to blade grips."
This is how I do my 120SR and V4 folding blades.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Aug 04, 2012, 06:44 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Do you mind posting the settings?
Thetis is offline Find More Posts by Thetis
Old Aug 04, 2012, 10:13 AM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
If you haven't already done so I highly recommend that you download Mr. Salt's "e-guide for the MSR and 120 SR". It includes a lot of tips and tricks for these two helis, including settings for the dx7 and dx6i. You can download it as a pdf file (the only way to get it) for about $9 at
www.rchelicopterfun.com
Old Aug 04, 2012, 10:29 AM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Thanks, heading there
Old Aug 04, 2012, 04:47 PM
Blackanthem is offline
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
I tell ya. for as many "Mr Salt" books we have sold here, we should be getting a commission
Blackanthem is offline Find More Posts by Blackanthem
Old Aug 04, 2012, 06:13 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
I'm just glad to see so many people having a good experience with the 120. Mr. Salt kept me from dropping the hobby altogether! Well, him and Mike of course...
Old Aug 04, 2012, 10:37 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
John Salt answered my emails when I didn't know anything what I was doing. I owe him, too, for eliminating my frustrations.
Saxguy1000 is offline Find More Posts by Saxguy1000
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
