United Kingdom, Oxted
Joined Dec 2011
A quick question about the canopy grommets:
Is there an easy way of getting them fixed onto the canopy or is it purely a juggling activity until it pops in? I find the little devils very fiddly to get into place without dropping/losing them!!! |
BD |
@Pilgrim I attempted to fix a main CF shaft to no avail using Gorilla Glue. I let it set for about 48 hours and it quickly split with an easy stress test. I wonder if a different type of CA would hold better? But, then again, you'd only have to break it down again if it didn't hold. Anyway, glad you got it sorted out...way to go
![]() Mike. |
Joined Dec 2011
Thanks BD and Jake. There was me thinking there's some really smart way to get the grommets in .......
I even tried collapsing it and poking it in and then trying to turn it. One of them decided to flip off so I thought, 'it's got to be easier than this!!'. |
CA stands for cyanoacrylate, a completely different kind of adhesive. I'm actually not sure whether ca bonds that well to cf - I've read that epoxy is the adhesive of choice for cf - but I was looking for something that would flow into the crack in my main shaft and then cure without expanding or shrinking. I won't know how well it works until I can fly outside which unfortunately won't be today.
The cracks in all my shafts seemed to be parallel to the hole where the rotor hub screw goes through, i.e. the cracks may propagate from the hole upward rather than from the top down.
If we have a pretty good idea where the crack starts, I wonder whether there is a way to prevent the shaft from cracking rather than trying to fix the crack after the fact. |
[QUOTE=1Pilgrim;
If we have a pretty good idea where the crack starts, I wonder whether there is a way to prevent the shaft from cracking rather than trying to fix the crack after the fact.[/QUOTE] You could use a syringe and fill the hollow CF rod with epoxy and then clean out the screw/bolt holes. It would make it alot stronger and help to prevent cracks.WS
| Thread Tools | |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro Helis | 6526 | Jan 12, 2013 12:20 PM |
| Discussion Update Blade CP or buy E-Flite Blade SR or 400? | markhwing | Electric Heli Talk | 10 | Aug 06, 2012 03:16 PM |
| Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others | everydayflyer | Batteries and Chargers | 45 | Apr 08, 2010 04:55 AM |
| For Sale Did you just buy a new E-Flite Blade SR? | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Feb 28, 2010 12:01 AM |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro RTF | 2 | Jan 07, 2010 09:36 AM |
