Old Jun 18, 2012, 06:23 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by ssobol View Post
The card Cobra was originally designed for the Piccolo helicopter. It is closer in size to the Blade SR than the 120SR.
However, the guy who modified it for the 120SR said he reduced it to 77% (I THINK, check the posts).
Since the card Cobra is just printed on paper and uses foam board you can scale the size of the parts very easily when you print it out. Since you have to modify the tail boom anyway I don't think that the scaling has to be particularly accurate.
Yes, you can scale these. I haven't done it, but if you want the most inexpensive solution and don't need the AH-1 to attack with live machine guns, grenade launchers, autocannon, and rockets... this would do
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jun 18, 2012, 06:53 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Noted this post on Helifreak that gives the plans for a battery tray. Keep scrolling down to post #812 through #818 to get the story and plans.
See: if you read RCGroups.com--you get a digest of all those "other" forums.
Old Jun 18, 2012, 08:11 PM
Wind Spirit is offline
Find More Posts by Wind Spirit
Wind you go around in circles
Wind Spirit's Avatar
United States, FL, Middleburg
Joined Jan 2012
Originally Posted by Coptafeel View Post
This carries the Raiden 1300 very nicely
http://astroid-designs.myshopify.com...-battery-mount
and don't use cheap fuzzy 'velcro', spend a bit more and pop for the good stuff
Hey, I just got my astroid-designs batt. mount today. How do you have your 1300 mounted to it? Are you using stock landing gear? I have Xtreme gear with my own mounts for it. The astroid mount angles up, not levell to frame, also very small for the 11300 batt. to be mounted to. Can you post a pic.? Thanks, WS
Wind Spirit is offline Find More Posts by Wind Spirit
Old Jun 18, 2012, 08:40 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
WS, click on "Instructions." Pretty sure this is for a stock set up. With your skid set up (i wish i had in my hand) you might be able to go with a regular velcro batt "credit card" mod.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Jun 18, 2012, 09:17 PM
Joined Jan 2012
Mike.
Hey Mike, I dont think I have seen the credit card mod. What I did that worked very well is I cut a piece of milk jug just big enough to cover the four mounting bolts on my skids, used a leather punch and matched the holes and put a strip of velcro down the center. The milk jug piece is lightweight and very strong and sits about 1/8" below the main shaft. I would still like to see how his is setup. When I have more time I will take a pic. of mine and post it. Thanks WS PS. I installed the astroid mount as per instructions.
Old Jun 19, 2012, 03:06 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
WS, yes the "credit card" velcro mod is very similar to what you do. That is very strange that the astroid mod won't go. I wonder if the holes are off or something. You need any measurements...that might help? Can you post a pic so we can see what it looks like?
Hey Guys, I just got done replacing my main shaft (CF) which is not my first one. For some reason I can't recall the up and down play that should be between the collar and bearing. Mine seems like a bit much. I would guess about .40mm. I wish these collars were more like Skytec (like their lower rotor too), then I would definitely fly the Xtreme shafts.
BTW, my shaft was split at the top and bottom. I knew this immediately when I grasped the gear and twisted the top rotor...holy crap Batman, lets do the twist I took a ride to Helidirect and scored the last CF shaft Friday
Mike.
Old Jun 19, 2012, 03:11 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I was looking at a spare shaft yesterday and noticed that it came with a micro split at the head. I applied thin CA and it filled the crack as well as filled the hollow end making it much stronger. I might have to sand it a bit to fit it right, but that's ok. I'm confident it's going to hold longer.
Old Jun 19, 2012, 04:01 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Dude, excellent idea! I'm gonna put mine in the micro vise, open up the split with a screw driver and apply some CA into the split with a toothpick. Release, and a quick wipe with a damp paper napkin.
Sax, you Da Man
Mike.
Old Jun 19, 2012, 04:03 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
This is why you pay me to be on this forum, Boss! (I'm paid with compliments.)
Old Jun 19, 2012, 04:21 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
But only "one" compliment "per person" a week. Were'er on a budget here Mister
Mike.
Old Jun 19, 2012, 04:24 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Mike.
I see. Obama administration is cutting back on compliments, too.
Old Jun 19, 2012, 05:03 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Obummer doesn't even know the meaning of "budget" other than the car rental place
Old Jun 19, 2012, 05:24 PM
Joined Jan 2012
Pic's
Here are some pic's of the astriod and WS mount.
Old Jun 19, 2012, 05:31 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
New E-Flite Variable Rate Charger
Had to get a new Variable Rate Charger (like these). Only this must be an updated one...does not say Celectra on it, and uses either 6v or 12v DC.
Check it out!
Jake8131 is offline Find More Posts by Jake8131
Old Jun 19, 2012, 05:34 PM
Joined Jan 2012
Pic's
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
