Old Jun 15, 2012, 09:40 PM
teflon97239 is offline
Find More Posts by teflon97239
teflon97239's Avatar
United States, OR, Portland
Joined Aug 2011
Originally Posted by RaymondM View Post
Getting out of the 120 sr thing selling it for want of a quad . Thanks for all the advice. It's in the classifieds if anybody is interested in a 120 with upgrades for a good price. If I ever return with another 120 this forum is on my great info list. Again, thanks for all the info and good advice!
Raymond, I felt the same way but decided to get the quad first, then sell the 120SR later if I still wanted to.
As a very natural bridge between a living room coax and the Crash-o-Matic, a Blade mQX uses the same radio and batteries, but actually stays in flight as long as I want it to.
Compare a nervous 13-second hover (followed by a crazed right-hand plunge into the nearest pavement) with several luxurious minutes of flying, experimenting and learning - even in a breeze.
I've actually learned a LOT about flying helos in the past few weeks. It's all about intepreting visual cues, and building automatic instincts and thumb reactions. Something I'm capable of learning in consecutive whole minutes, not a few scant moments between repairs.
Now, suddenly the 120SR is a lot more manageble, a refreshing change. Maybe try both birds and see what happens.
teflon97239 is offline Find More Posts by teflon97239
Old Jun 15, 2012, 10:08 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Originally Posted by meep View Post
<SNIP>
i think any mod that can help the battery tray would be worth it. <SNIP>
Many of us have this. I think he could have restocked.
http://astroid-designs.myshopify.com...-battery-mount
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Jun 16, 2012, 02:20 AM
micro2000 is offline
Find More Posts by micro2000
S107G MSR MSRX 120SR Nano QX
United Kingdom, Coventry
Joined Jan 2012
It might be a daft question, but is there a right and wrong way to put on the 328 tail blades, as I know the stock blades had an X to face the motor.............
micro2000 is offline Find More Posts by micro2000
Old Jun 16, 2012, 04:33 AM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
There is only one way,,,,look at the curvature of the blade.
Jake8131 is offline Find More Posts by Jake8131
Old Jun 16, 2012, 04:44 AM
Joined Jan 2012
Thanks jake, do you mean set it so the convex side is nearest the motor ?
Old Jun 16, 2012, 05:44 AM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
The "X" on the stock rotor faces the motor. You can compare the pitch of the two rotors to see which way the 328 should face. EDIT: You could write "L" on the side facing the motor for future reference.
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Jun 16, 2012, 07:13 AM
peeve1973 is offline
Find More Posts by peeve1973
Helis and Planes
Canada, ON, Owen Sound
Joined Mar 2012
Apparently the 120 can be looped. But only with mods.
E-flite Blade 120SR - stunt flight (3 min 6 sec)
I know I am not going to try.
peeve1973 is offline Find More Posts by peeve1973
Old Jun 16, 2012, 11:03 AM
PCaola is offline
Find More Posts by PCaola
Joined Apr 2012
120SR Flybar
Has anyone used the Rakon CF flybar? Most importantly, is it lighter than the stock flybar? I've read that lighting the flybar helps cut down pendulum and sway effect. I may order a spare stock flybar to cut down but I was wondering if the CF one was lighter?
Thanks.
Paul
PCaola is offline Find More Posts by PCaola
Old Jun 16, 2012, 12:16 PM
fatcat1 is offline
Find More Posts by fatcat1
United States, IN, Mooresville
Joined Feb 2008
I have a DX8 on the way is there any links or info on a good mix setting for the SR120?
Also mine with the cheap stock tx wants to always creep backward. I have the elevator trimmed to the max and it still wants to do this. In short I think I might need to adjust the linkage to solve this problem. any thoughts?
fatcat1 is offline Find More Posts by fatcat1
Old Jun 16, 2012, 12:22 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Correct
... center your trim again then get it a good as possible mechanically first.
North_of_49 is offline Find More Posts by North_of_49
Old Jun 16, 2012, 01:24 PM
fatcat1 is offline
Joined Feb 2008
Thanks north! I have centered the trim on the tx now if the wind will die down a bit I can test it outside and see how the bird flys with the adjusted linkage
Old Jun 16, 2012, 01:30 PM
fatcat1 is offline
Joined Feb 2008
This is my first FP heli and it is a hoot to fly I am looking to upgrade it a bit. what are the practical upgrades for this heli vs. the for looks only upgrades? I see alot of people upgrading to the Extreme Motor that I think will be one of the first upgrades I get.
Old Jun 16, 2012, 01:38 PM
Coptafeel is offline
Find More Posts by Coptafeel
Coptafeel's Avatar
Joined Mar 2011
This is my first FP heli and it is a hoot to fly I am looking to upgrade it a bit. what are the practical upgrades for this heli vs. the for looks only upgrades?.
RKH or Micro-Heli swash
Astroid Designs or RKH battery mount
Coptafeel is offline Find More Posts by Coptafeel
Old Jun 16, 2012, 04:34 PM
nickypoo is offline
Find More Posts by nickypoo
R.I.P. GMRC
nickypoo's Avatar
United States, CA, Glendora
Joined Nov 2011
anyone familiar with slot cars around the 4.5 inch size? i believe they are 1/32nd scale but correct me if im wrong
anyways they have many sizes of brushed motors that would bolt right up by the looks of it
anyone tried anything besides the stock and xtreme motor?
nickypoo is offline Find More Posts by nickypoo
Old Jun 16, 2012, 04:43 PM
nickypoo is offline
R.I.P. GMRC
nickypoo's Avatar
Joined Nov 2011
im being lazy and not looking up motors with similar specs to compare but maybe somone smarter than me out there could find something with the right KV ect that might be a good new option
http://www.professormotor.com/product-p/jk7.htm
http://www.ncphobbies.com/parma-1/24...s/par502motor/
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
