Well, the heli seems to have violent swings as the heli pitches up and back sometimes then continues to wander around this axis, it seems no amount of correction on my part can bring it to stabilize and i'm lucky to land it without crashing. |
United Kingdom, Coventry
Joined Jan 2012
Would this transmitter be worth buying as an upgrade to me stock 120SR TX ?
http://www.ebay.co.uk/itm/Spectrum-D...item2a1ec7fd71 |
Canada, ON, Owen Sound
Joined Mar 2012
United States, CA
Joined Jan 2012
If your heli has a lot of flight time on it you should check the fly bar center hole fo out of round. Insert a drill bit the size of the hole . There should be even light around the drill bit. If the hole appears elongated, replace fly bar. It doesn't take much wear to cause problems.
1. Blades chipped, out of balance or not tracking properly; 2. Flybar out of balance or not tracking properly; 3. Links missing, disconnected, or loose or binding in anti-rotation guides; 4. Binding main gear 5. Cracked main shaft. |
TBE is only caused by worn links, worn swash balls, blade grips...a cracked shaft will only cause wobble. |
Well, I don't think it is a case of TBE as I can hover it inside without wind nicely and it is hands off stable (for a few seconds anyway) . I took the 120sr out again today, to put it to a test, and it did circles L/R and some ff, I'm pretty sure the wind was a contributing factor the other day that and the pilot error of over correcting. I see better what to expect from this heli as in knowing it's flight characteristics, it covers a lot of space in a very short time and I know it is very sensitive to just a breeze this and factor in the over correction and you have an unwilling participant in a wild ride to say the least.
I am used to the flybar of the Solo Pro 260a and it's flight characteristics I am developing some mad skills with it and I think I am thinking that this might be on the same plane as the 260a in regards to flight characteristics inherent to a 45 degree flybar, but then each heli has it's own unique characteristics inherent to that heli. What i'm trying to say is that I'm a newbie to the 120 sr and I must learn it's ways or it's time to take up lawn darts. Thanks to all that gave their time and input to help me it is much appreciated. |
| Thread Tools | |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro Helis | 6526 | Jan 12, 2013 12:20 PM |
| Discussion Update Blade CP or buy E-Flite Blade SR or 400? | markhwing | Electric Heli Talk | 10 | Aug 06, 2012 03:16 PM |
| Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others | everydayflyer | Batteries and Chargers | 45 | Apr 08, 2010 04:55 AM |
| For Sale Did you just buy a new E-Flite Blade SR? | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Feb 28, 2010 12:01 AM |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro RTF | 2 | Jan 07, 2010 09:36 AM |
