Espritmodel.com Heli Air
Old Mar 02, 2012, 10:16 AM
T-Rex 500 and 550; Wk V120DO2S
helinewbie617's Avatar
United States, FL, Clearwater
Joined Jun 2009
Absolutely... microheli and Rakonheli are a couple of upgrade mod comapnies that make parts for our 120SR's. Valuerc and boomtownhobbies are a couple of great websites to buy them from (among others not on the top of my head).
helinewbie617 is offline Find More Posts by helinewbie617
Old Mar 02, 2012, 10:28 AM
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by Saxguy1000 View Post
snip
--I can't find one one for purchase the entire planet !!
http://www.ebay.com/itm/Xtreme-Blade...item1e6bd06354
more than 10 available at the time of this posting
... if you guys really recommend it I think I'll pull the trigger. Will it suck the battery faster?
North_of_49 is offline Find More Posts by North_of_49
Old Mar 02, 2012, 10:48 AM
Joined Jun 2009
Nah... I get at least 4:30 - 5 minutes each flight. I am more than happy with this flgith time, especially since I have 4 550mAh 25C batteries.
Joined Feb 2012
Thnx. I will check them out.
Aviator168 is offline Find More Posts by Aviator168
Old Mar 02, 2012, 10:49 AM
Joined Jun 2009
My pleasure.
Old Mar 02, 2012, 11:15 AM
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
I can tell you that I love mine... I really wring my 120SR out and I can nose-dive her down to cm's off the ground without hitting the ground thanks to my Xtreme SR120 motor. Such a fun heli... just waiting for the day when I can buy that expensive RKH flybar... then she will be able to hover with much less TBE if any.
I stand corrected, one never has enough power!! Ive only got a few flights on my sr but what the hey.... Xtreme motor it is!
jrjr is offline Find More Posts by jrjr
Old Mar 02, 2012, 11:20 AM
Joined Dec 2011
That brings up something I've been meaning to ask. Since I broke a control ball on my first flight I haven't yet put an entire pack through my 120sr.... once I get back in the air, how long should I set a timer using stock battery and motor? ... I'd like to know the max you can push it just before hitting LVC... I'd then probably back the time off a bit but I'd like to know how much of a safety net I'll have before landing after timer going off but not hitting LVC. I could figure it out myself by running it to LVC just once but don't want to do that if I can help it...
... I normally don't worry too much about my cheap lipos... like John Salt, I consider them cheap and disposeable, but my E-flite 500 is brand new and cost me 12 bucks and I'd like to charge and discharge this one properly, preferring not to hit LVC even once to find out where I should be setting my timer... at least while it's new and strong (once it eventually weakens, and they all do regardless of brand and proper maintenance, I don't really care as much about hitting LVC).
Old Mar 02, 2012, 01:13 PM
United States, OH, New Vienna
Joined Mar 2011
What seems to be the best skids to use for RKH upgrades? I have everything but the cf skids. I just built it, and had a pair of Walkera 5#10 skids that I used. They seem to work well, not too big or too heavy. Just thought I'd get some input. Thanks
og1974 is offline Find More Posts by og1974
Old Mar 02, 2012, 01:28 PM
Joined Feb 2012
My 120 sounds terrible. It flies well but it just sounds like there are a lot of vibrations. Anyone know what's going on?
Old Mar 02, 2012, 01:36 PM
Gravity impaired
jrjr's Avatar
Joined Nov 2004
That looks sweet! Have the flight characteristics changed much?
The skids look lighter than a T Rex 250
Old Mar 02, 2012, 02:00 PM
Joined Mar 2011
I just flew it in the kitchen for now, flies very nice. Very balanced, a lot more more responsive. Can't wait to take her outside. The skids are about half the size of Walkera v200 skids, the tubes are about 1/8" diameter, very light. I guess Trex 250 skids are probably about the same size as the v200 ones, not sure though. The 5#10heli skids are about the same size as stock 120 skids. I'll report back when I get the chance to really fly her. Thanks for the compliment.
Old Mar 02, 2012, 02:52 PM
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Ya know, I was looking at my 120SR next to my cx2 and comparing the blades. The 120's blades are nearly identical in size and form to the CX2's lowers. Has anyone tried to use something like....
THESE?
Old Mar 02, 2012, 03:15 PM
Joined Dec 2011
Can someone please tell me the diameter of the T-Rex 250 skids pipes? Also, are the pipes for the 450 or 500 thicker than the 250's or are they maybe the same? I'm going to order the Xtreme motor and might add the pipes and some other stuff to make the shipping expense worthwhile.
Thanks.
Old Mar 02, 2012, 05:47 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
You just made a really good friend with this info!!!! No, this motor puts out more and I saw no loss of time in the air--not saying there isn't more battery used, but it's at least negligible.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Mar 02, 2012, 05:58 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
If you use the search function above and look for "80% rule" you will see the links to this information. You won't get a set time, but you can check how much mah you are using and figure out how far you can go before using 80%.
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6526 Jan 12, 2013 12:20 PM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro RTF 2 Jan 07, 2010 09:36 AM
