Old Jan 17, 2012, 05:43 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Originally Posted by makg View Post
Has anyone tried this motor? Any real increase in performance?
I just installed the Xtreme motor - only have about 20 minutes on it. The first 10 minutes were stock; the heli really "jumped" and it was hard to hold altitude 'til I got used to the extra power.
For the other flights the heli was loaded down with a #16 camera, heavy rubber band, a penny and the custom "see through" canopy. It still flew strong, no problem with the extra weight, and it was very stable and predictable in the air. I give the motor a "10".
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Jan 17, 2012, 05:47 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Yes. Buy it.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 17, 2012, 06:10 PM
makg is offline
Find More Posts by makg
ISP Supervisor
makg's Avatar
United States, AK, Fairbanks
Joined Jan 2006
Thanks guys! I just purchased a 120 SR from a RCG member, so I will definitely keep it in mind.
makg is offline Find More Posts by makg
Old Jan 17, 2012, 06:13 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by orectolobus View Post
I recently added a tail brace mod to my machine.
Rather than buy some parts for another heli I fabricated mine from
some available stuff. I used some .035 CF rod, electrical connectors
and some heat shrink tubing. It really stiffened the tail boom up and
the helicopter seemed a little more stable... maybe I was just more relaxed.
I used an electrical connector on the boom as well. I was trying to keep the
aft weight down for CG purposes. I spread the wire receptor apart with a needle
nose and expoxied the ends the CF rods in the connector. Filed the blade part
of the connector down to the width of the CF tailboom.... wrapped with thread
and put some black electrical tape over. It's all easy to remove.
Another day... another mod...
Another cool mod! Now I need the Klingon stealth body with secret squirrel spy camera--and the DIY tail stabilizer. You guys are busting through with great stuff!
Old Jan 17, 2012, 07:48 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
New & improved stealth canopy...
...taking advantage of the wide angle lens on the #16 cam. You can just see the left side of the canopy fluttering in the breeze...
http://www.youtube.com/watch?v=2xnlugggTs0
Old Jan 17, 2012, 08:24 PM
Blackanthem is offline
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
Looked so good with the skids, I decided to give her a new canopy and tail fin.
Description:
Blackanthem is offline Find More Posts by Blackanthem
Old Jan 17, 2012, 09:06 PM
Wind Spirit is offline
Find More Posts by Wind Spirit
Wind you go around in circles
Wind Spirit's Avatar
United States, FL, Middleburg
Joined Jan 2012
Originally Posted by 1Pilgrim View Post
Do a search for the #16 HD keychain cam. There's a thread devoted to it
Found it, Thanks WS.
Wind Spirit is offline Find More Posts by Wind Spirit
Old Jan 18, 2012, 12:29 AM
Dodge DeBoulet is offline
Find More Posts by Dodge DeBoulet
Dodge DeBoulet's Avatar
Joined Dec 2011
Link still works for me...Weird. Try this
That one works, thanks. And I already have one of those
Dodge DeBoulet is offline Find More Posts by Dodge DeBoulet
Old Jan 18, 2012, 08:04 AM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
I recently added a tail brace mod to my machine...
Nice clean mod! My heli's gonna get a set.
VArchT is offline Find More Posts by VArchT
Old Jan 18, 2012, 08:56 AM
Joined Jan 2012
I guess it's to late because I installed them, but do you use the same stock screws to attach RKH metal upgrades? Still use the carbon main shaft. Holes were not big enough in the Rkh Parts and used the screws to tap it biger. Thanks WS
Old Jan 18, 2012, 09:01 AM
Joined Jan 2012
Hi, Very Nice mod, I think I will try the same, Only use RHK tail boom clamp and attach the elect. connnectors to it. Thanks for posting your idea. WS
Old Jan 18, 2012, 09:25 AM
orectolobus is offline
Find More Posts by orectolobus
TerryM
orectolobus's Avatar
United States, AR, Heber Springs
Joined Sep 2001
You can also use a Dubro U-shaped landing gear strap....
I used one of these first but eliminated the two strews and strap to help with CG.
A few options all for the same purpose... stiffen the tail boom.
orectolobus is offline Find More Posts by orectolobus
Old Jan 18, 2012, 02:51 PM
Helohead is offline
Find More Posts by Helohead
100k parts vibrating in unison
Helohead's Avatar
United States, MO, St Charles
Joined Aug 2011
Solid CF Main Rotor Shaft
Well I decided to make my own Solid CF Main Rotor Shaft, and I learned a lot in the process. I had to blue-print the stock and aftermarket parts and as I assumed, I found what I believe is a problem with the Microheli Aluminum Main Shaft, the holes are too big!
Ever notice when you assemble a Microheli CNC Anti-Rotation Collar (MHE120SR002A) with the Aluminum Main Shaft (MHE120SR066) the Anti-Rotation Collar has rotational play in it? Then we wonder where the TBE came from!
The holes in the Blade/HH Carbon Fiber Main Shaft (BLH3107) are 0.055” Dia. Corresponding to a #54 drill. Based on the screws used this is correct for 50% thread engagement which is correct for materials which may be easily split like CF.
It looks like Microheli blue printed Blade/HH’s part exactly without correcting for hole size with the different material. In soft metal like aluminum you use 75% thread engagement which corresponds to a smaller hole, 0.052” Dia. #55 drill.
It is possible that Microheli tried the smaller hole and found it too hard to install the screw; I don’t know I haven’t tried it myself, but the screw should go in fine.
So what does all this crap really mean? To eliminate TBE, stick with the Blade/HH Carbon Fiber Main Shaft (BLH3107)!
As for my own Solid CF Main Rotor Shaft, No TBE! And it should last the life of the helo although it was a pain in the butt to manufacture.
Randy
Helohead is offline Find More Posts by Helohead
Old Jan 18, 2012, 04:12 PM
airshot is offline
Find More Posts by airshot
Joined Jul 2007
alum shaft
I also ran into some problems with the alum shafts, they are .0015 - .002 smaller in dia than the CF shaft. After installing the alum shaft I kept breaking the plastics parts attatched to it. Many broke without any type of crashing. That is when I looked more carefully into the fit of the plastic pcs to the alum shaft. If you are upgrading all your parts to alum then you might be OK, but mixing the alum shafts with the plastic parts will cause the plastic to break more readily due to the extra play. Also more slop in the bearings as they are designed for a larger dia shaft. I went back to the CF shaft and have not broken any plastic parts even after crashing. If you find your CF shaft splits/cracks, it can be repaired.... drop some CA glue into the hollow center then carefully spread open the crack to allow the CA to enter. Close the crack, mabey even add some more CA glue and let it dry overnite. Lightly sand the OD till the plastic just fits (snuggly) re-drill the holes for the screws and your ready to go. My repaired shafts fly perfectly.
Good Flyin
Airshot
airshot is offline Find More Posts by airshot
Old Jan 18, 2012, 04:31 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Originally Posted by Kurt View Post
Nice flying and the video is pretty good quality!
Have you posted pics up of the canopy and cam mount?
I see you're in Sheboygan - man I've got to get up there soon to Il Ritrovo, I LOVE their pizza and it's the only place I know of to get guanciale (Italian cured pork cheeks)
Hope you were out flying today, we may not see 40F again for a few months!!!
cheers
Kurt
Milwaukee
Hey Kurt, check your pm's
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
