Old Dec 31, 2011, 05:02 PM
What tree?
Rampage's Avatar
Yucca Valley, California
Joined Aug 2005
Originally Posted by Helohead View Post
Rampage,
I talk’n out my butt here cause I don’t have access to a DX7s but I’ve looked at the pic’s of the switches and read the mixing section of the manual and none of it makes any sense to me.
I don’t understand why anyone would want the same mix on two different switch settings! That alone makes me think it’s an error in the software: “S-12” should be “S-1”, see if the mixing on the monitor screen works correctly if you disregard that extra “2”.
I would call Spektrum and ask about this…
Randy
I was kinda' thinking the same thing, but position 2 (S-2) defintiely seems to over-ride S-12, so I don't think S12 and S-2 are actually combining. I don't know tho. Hard to tell. I'm wondering if it is just a glitch in the firmware. When I'm in the menu, if I have the switch in position 2 and I'm in S-12's menu, it displace the switch as being on, which is kind of strange.
Anyone else want to chime in on this one?
Rampage is offline Find More Posts by Rampage
Old Dec 31, 2011, 05:18 PM
mQX-130X-300X-450X
Blackanthem's Avatar
United States, TX, Decatur
Joined Aug 2011
Originally Posted by Chap1012 View Post
"Tunnel of L-O-V-E."
Do you not see the rusty chains of torture?!
lol!
Blackanthem is offline Find More Posts by Blackanthem
Old Dec 31, 2011, 05:22 PM
mQX-130X-300X-450X
Joined Aug 2011
No clue Rampage, I am running Mr. Salts settings with my DX6i.
Old Dec 31, 2011, 07:57 PM
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
@Black, I don't think that was our deal. The Mission was not to find dogs.
Your Mission (should you choose to accept it) is to fly your 120SR FFF through the TOD, turn around, climb, and fly nose-in over the TOD back into the backyard and land.
As usual, if your 120SR be caught (in the trees) or killed in action, Mike and I, and the rest of us will disavow all knowledge of your actions... This message will self-destruct in 5 seconds.
Heli Pad is offline Find More Posts by Heli Pad
Old Dec 31, 2011, 08:05 PM
What tree?
Rampage's Avatar
Joined Aug 2005
Had 3 flights on mine today, getting more comfortable every time. Keeping her in the air for the entire pack is no problem now. Still working on coordinating the turns and getting out of the airplane "Airspeed is life" frame of mind. A few things I've noticed that I'm not sure if they're unique to the 120 SR or all helis in general:
1) A slight right tilt even in a hover. Holds it's position but is still canted slightly.
2) The need to drastically lower the head speed when moving forward quickly, otherwise she climbs like a rocket. Head speeds I use for maintaining a hover seem to be much too high for forward flight.
3) Same as above, but when flying forward into a slight breeze.
I'm guessing 2 and 3 have something to do with the "disk" creating more lift as the heli's moving forward, so you reduce the head speed to keep it from climbing?
Still learning a lot here and loving every moment of it.
Old Dec 31, 2011, 09:31 PM
MJF
Waiting on HHAEFI
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
Happy New Years Ya'll
MJF is offline Find More Posts by MJF
Old Dec 31, 2011, 09:51 PM
100k parts vibrating in unison
Helohead's Avatar
United States, MO, St Charles
Joined Aug 2011
Rampage,
Good observational skills and your guess is correct.
Item 1: When properly trimmed out the tilt is normal; it’s required to compensate for the tail rotor thrust. If trimmed with the swash plate “Level” the tail rotor would blow the heli sideways.
Item 2 & 3: Is called Translational Lift.
http://www.rchelicopterfun.com/translational-lift.html
You’re soon going to encounter Dissymmetry of Lift. http://en.wikipedia.org/wiki/Dissymmetry_of_lift
Have Fun & Happy New Year Everyone!
Randy
Helohead is offline Find More Posts by Helohead
Old Dec 31, 2011, 11:19 PM
What tree?
Rampage's Avatar
Joined Aug 2005
Dissymmetry of Lift is what causes the 120 SR to roll slightly in FFF, right?
Old Dec 31, 2011, 11:53 PM
Helohead's Avatar
Joined Aug 2011
Yes, a heli with a CW rotating head will roll to the right in FFF until you get to helis with a higher head speed then the effect goes away.
With the 120SR we use a mix to compensate.
Old Jan 01, 2012, 01:53 AM
Digital Don's Avatar
United States, IL, Manteno
Joined Dec 2006
I posted this a while ago regarding the mix I use for my 120 SRs.
The mix shown below helps keep the nose straight and level when starting forward flight with both my 120 SRs using my DX6i.
I forgot how well it actually works until I flew a buddy's new 120 SR to help him tirm it out. His transmitter didn't have the mix programmed in and it was definitely more difficult to get his 120 flying forward smoothly.
I can't take credit for the mix - found it online - and I did have to adjust the values to work best for my particular helicopters. So, consider the values below as a starting point. Also, be sure that the "R" value is MINUS.
Don
Digital Don is online now Find More Posts by Digital Don
Old Jan 01, 2012, 07:49 AM
MJF
Waiting on HHAEFI
MJF's Avatar
Joined Jul 2010
Don
I think I shall try this mix as well
Old Jan 01, 2012, 12:05 PM
Joined Jan 2012
Bought my father, whom is a helicopter pilot, the SR 120 for Christmas. I also purchased an extra set of blades (main and tail) and 2 extra batteries. I read John Salt's e-Guide on the SR 120, and plan on building the battery mod he described. Also, I plan on purchasing the DX6i within the next couple of weeks.
Neither of us have really any RC heli experience, he had purchased a RC heli at a mall once, think it was $80, about 3x the size of the SR 120, and it was crap. So basically, we are new to this.
Anyway, on Christmas day, we took it outside for a test flight. It was around 50-degrees, slight breeze (~3mph). Obviously, we crashed it multiple times, even on asphalt, and I got it stuck in a tree once.
The only issues we had were:
1) After one crash, the heli wouldn't take off, it kept nose-diving after getting about 1" off the ground. We first thought it was a weak battery, so we put a fully charged battery in it, with the same results. Finally, after inspecting it, I noticed one of the linkages had popped off, and after replacing it, it started flying again.
2) After a different crash, into the trunk of a tree, one of the skids broke. After reading some sites on the internet, it seems the skids are one of the number 1 things that will break. Unfortunately, Hobby Town in my father's town had closed down, so I'll have to pick a couple of extra ones up at my local HT. No biggie, the heli still flies just fine with a broken skid.
Once he really gets the hang of it, and after getting the DX6i, I really want to put a scale UH-60 Blackhawk body on it, as that is what he flew in the Army. He now flies a Huey and a 407, so those bodies are a consideration also.
Will probably get one of those keychain cameras also, try to make some good vids.
Anyway, thanks for the great forum, will check back on this thread daily!
taz291819 is offline Find More Posts by taz291819
Old Jan 01, 2012, 12:12 PM
Helohead's Avatar
Joined Aug 2011
Don
Beware of strange mixes found on the internet!
They may appear to work.
But one day when you’re trying more advanced maneuvers, you may find yourself in the Spiral of Death.
The answer is for sale which is why we don’t divulge it here.
http://www.rchelicopterfun.com/blade-msr-tips.html
Randy
Old Jan 01, 2012, 12:26 PM
Helohead's Avatar
Joined Aug 2011
Originally Posted by taz291819 View Post
Bought my father, whom is a helicopter pilot, the SR 120 for Christmas. I also purchased an extra set of blades (main and tail) and 2 extra batteries. I read John Salt's e-Guide on the SR 120, and plan on building the battery mod he described. Also, I plan on purchasing the DX6i within the next couple of weeks....
Sounds like you’re off to a good start, welcome to the obsession.
Randy
Old Jan 01, 2012, 12:53 PM
mQX-130X-300X-450X
Joined Aug 2011
Tested a new Camera platform this morning. I need to adjust my angle, but otherwise I am happy with it. Very little jello effect and the camera is upside down. A lot easier to get at the buttons and see what the camera is doing with this set up.
010112aa.wmv (5 min 46 sec)
Edit:
After I ran a stabilization filter.
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6526 Jan 12, 2013 12:20 PM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro RTF 2 Jan 07, 2010 09:36 AM
