Old Sep 19, 2011, 05:46 PM
Blackanthem is online now
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
Exactly the same settings I have. Nope, did not get a box as I imagine it came in the same box as the RTF CP pro 2. Remember,.. I could use switch #4 up. I had to throw switch #7 up, engage the throttle and then throw #7 down. It's a Chinese puzzle lol!
Blackanthem is online now Find More Posts by Blackanthem
Old Sep 19, 2011, 06:33 PM
Joined Aug 2011
Thought I would share something. I have a MCX2, and the batteries come with a little rubber cap. I "stuck" slid 4 of them on the 120 skids. No slip skids.
Old Sep 19, 2011, 07:20 PM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Crowheart
Joined Aug 2011
Hi Guys,
I had the same trouble with the HP6DSM, not being able to find much info for it. The brand new ones dont even come with any documentation in the box. Thats bizarre, I thought.
But I read thru this Blade SR manual and there is some helpful stuff. One has to keep in mind that the TX that comes with the SR is supposed to be SR specific and not to be used on any other aircraft(so they say, anyway). I actually called HH and they said dont try to use the HP6DSM with the 120SR. But they made no mention of the two different TX's.
Anyway there is some dip switch info in the SR manual, surely dip switch settings would not change between the two different TX's would they?
The posts I read say the SR TX is a "dumbed down" version of the standard HP6DSM.
Does a person have to re-bind after changing dip switches or not?
This is good reading anyway:
http://www.horizonhobby.com/ProdInfo...onalManual.pdf
Kyle
BattleDude is offline Find More Posts by BattleDude
Old Sep 19, 2011, 07:35 PM
Joined Aug 2011
I really cant answer anything other than, No I did not have to re bind when changing the dip switches. So far I like the radio, the 120 appears to respond a lot better.
Old Sep 20, 2011, 08:49 AM
A Rdnek is online now
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
You may not "have" to rebind, but you probably should.
According the HH service.
Ron
A Rdnek is online now Find More Posts by A Rdnek
Old Sep 20, 2011, 09:15 AM
Joined Aug 2011
After I found the correct settings, I did do a re bind.
Old Sep 20, 2011, 10:12 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Ron
I am desperately tying to wrap my brain around why my TX; the exact same model I have as BlackAnthem has different settings; [this] just for starters. Now I'm confused about this binding thing. BalckAnthem, exactly what do you have to do before flying? The reason I ask is because I find the posts that I quoted a tad confusing. Futhermore, I don't understand why HH can't give an explanation as to "WHY" these TX's have different setting BUT, are the same model. I'm beginning to think both HH and Efight has their head where the sun don't shine. This makes absolutely no sense
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Sep 20, 2011, 10:41 AM
Joined Aug 2011
Well,.... I plugged in the 120, waited for the flashing red LED, pulled the trainer switch on the TX towards me, held the trainer switch while turning on the TX. Waited for the red LED on the 120 to turn solid. A word of caution!!! If you do not have throttle control at this point. DO NOT flick the throttle hold switch back and forth. Woooshhhhhhhhh!!!! Away the 120 will go. Just saying.
Old Sep 21, 2011, 06:31 AM
Joined Aug 2011
Time to re build
The 120 has the shakes. My research leads me to believe that I have a cracked main shaft. So, while I am going to replace that with a Microheli Aluminum Main Shaft. Any other recommendations on upgrades? Microheli CNC Swashplate?? I figure while I have it torn down, might as well do it right.
Old Sep 21, 2011, 05:17 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I am liking my MH swashplate and the anti-rotation collar. I also am really enjoying the new Xtreme Ball Bearing Upgraded Main Motor. I am looking now for an alternative to the tail motor, but haven't decided what to try. I have the MH main shaft and it works fine, too.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Sep 21, 2011, 06:52 PM
Joined Aug 2011
Nice. I have been looking at the Xtreme Motor, you see an improvement with it?
Old Sep 21, 2011, 07:26 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Yes, I was saying earlier in the thread that I have a bit more power over the stock. The only thing is that the tail motor is barely keeping up at times and I don't know if it's just wearing down, or if it's because I need a stronger one. Either way, the motor is nice. It's sound is smoother and gives you the impression it's not running as hard.
Old Sep 21, 2011, 07:46 PM
Joined Aug 2011
The tail motor not keeping up... does not / would not surprise me. I think I am going to pick one up, and check it out. Very cool.
Old Sep 22, 2011, 03:58 PM
DropTank is offline
Find More Posts by DropTank
Is it Friday yet?
DropTank's Avatar
United States, NC, Raleigh
Joined Jun 2008
Just back from the LHS and brought home a 120 SR. It's little windy so it looks like i'll have to wait to try it out.
DropTank is offline Find More Posts by DropTank
Old Sep 22, 2011, 04:20 PM
danny.act is offline
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
BelgiŽ, Vlaams Gewest, Putte
Joined Jun 2004
Originally Posted by Chap1012 View Post
Danny, it looks like that manual is for the SR. If you look at the pic in the manual it's stamped right on the TX "HP6DSM SR." I have heard that these TX's are set up different from the other HP6DSM TX's. No? This whole thing is ready to make my head explode I can't even imagine what it's like setting up a DX6i
Mike.
Mike,
Sorry for the late reply,
Then You must have the pure "HP6DSM" wich came with the Blade CP Pro2:
HP6DSM manual,
Binding procedure is on page 59(You don't need the bind plug for the SR120) of this manual:
http://www.heliproz.com/images/BladeCPPro2Manual.pdf
On front of the CP Pro HPSDSM transmitter, at lower right , it says just "HP6DSM" without the addition of the "SR" indication.
regards,
Danny.
danny.act is offline Find More Posts by danny.act
Last edited by danny.act; Sep 22, 2011 at 04:34 PM. Reason: Binding procedure info
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
