Old Sep 18, 2011, 03:31 PM
Blackanthem is online now
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
Ding Ding!! We have a winner! 3,5,7 is the combo!!!!! Thanks everyone for your help. I hear you Heli, I have looked hi and low for any kind of instructions for this radio. Nada. By the way, 3,5,7 works for both the 120 and the MCX2.
I think 7 is controlling the throttle?
Blackanthem is online now Find More Posts by Blackanthem
Old Sep 18, 2011, 04:38 PM
Thunder2661 is offline
Find More Posts by Thunder2661
Crashing well so far
Thunder2661's Avatar
United Kingdom, England, North York
Joined Jun 2011
I found this but i don't know if it helps
E-flite HP6DSM 6-Channel 2.4GHz DSM2 Transmitter
Specs:
Full range Spektrumô 2.4GHz DSM2ô technology
Mode II
Flight mode switch
Throttle hold switch
Dual rate switches
Trainer Switch
Adjustable Trims
Adjustable Stick Height
Requires 4 AA batteries (not included)
Airplane Mode Features:
Elevator/Aileron (Elevon) mixing
Rudder/Elevator (Ruddervator/V-Tail) mixing
Adjustable knob (fully proportional) for Chan 5 functions (Flaps, Retracts, etc.)
Helicopter Mode Features:
2 Mixing settings: 120-degree Cyclic Collective Pitch Mixing (CCPM) Or Standard mixing
2 Flight Modes: Normal or Stunt/Idle Up
Stunt Mode Throttle Curve Midpoint Adjustment (SM TCM ADJ) knob
Remote Gryo gain knob
DIP Switch Settings:
Dip Switch 1*
UpóChannel 1/Throttle channel reversed
DownóChannel 1/Throttle channel normal
*For safety, channel 1/throttle channel reversing can only be changed when the transmitter is powered off. All
other dip switch positions/functions can be changed while the transmitter is powered on.
Dip Switch 2
UpóChannel 2/Aileron channel reversed
DownóChannel 2/Aileron channel normal
Dip Switch 3
UpóChannel 3/Elevator channel reversed
DownóChannel 3/Elevator channel normal
Dip Switch 4
UpóChannel 4/Rudder channel reversed
DownóChannel 4/Rudder channel normal
Dip Switch 5
UpóChannel 5/Gear channel reversed
DownóChannel 5/Gear channel normal
Dip Switch 6
UpóChannel 6/Pitch channel reversed
DownóChannel 6/Pitch channel normal
Dip Switch 7
UpóHelicopter Mode (Channel 6 becomes pitch channel)
DownóAirplane Mode (Channel 6 becomes an extra aileron channel)
Dip Switch 8*
Upó120-degree Cyclic Collective Pitch Mixing (CCPM)
DownóStandard mixing
*Only functions when in helicopter mode.
Dip Switch 9*
UpóRudder/Elevator (Ruddervator/V-Tail) mixing
DownóNo mixing
*Only functions when in airplane mode, and no function if switch 10 is in the up position.
Dip Switch 10*
UpóElevator/Aileron (Elevon) mixing
DownóNo mixing
*Only functions when in airplane mode, and no function if switch 9 is in the up position.
Binding Process:
First power up your RX in Bind Mode (install Bind Plug, if applicable). To enter bind mode with the transmitter, pull the trainer (TRAINER) switch toward the front of the transmitter, then, while holding the trainer switch forward, power the transmitter on. Youíve successfully entered bind mode when the transmitter beeps and the red LED located under the door on the bottom left front of the transmitter blinks
rapidly. You can release the trainer switch after the transmitter stops beeping and the transmitter will remain in bind mode until the binding process is complete. Then, once the orange LED on the receiver glows solidly, the receiver is bound to the transmitter. Now you will need to power down the transmitter and receiver. (Remove Bind Plug from RX, if applicable).
This thread may also help
http://www.helifreak.com/showthread.php?t=290416
From what i've read for the 120 to work (as i don't have a HP6DSM)
it looks like there are two types of HP6DSM
1/ HP6DSM
needs dipswitch 4 up and the rest down
2/ HP6DSM BLADESR logo
needs dipswitch 3 and 7 need to be up and the rest down
Thunder2661 is offline Find More Posts by Thunder2661
Old Sep 18, 2011, 05:08 PM
Joined Aug 2011
That is a great find. I posted about the 3,5,7 settings in the radio section. maybe you should add this to what I posted? for easy search? Thanks again all for your great help. You all Rock!
Old Sep 18, 2011, 05:15 PM
danny.act is online now
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
BelgiŽ, Vlaams Gewest, Putte
Joined Jun 2004
HP6DSM
Functions, knobs, etc... described in the Blade SR manual.
Binding procedure at page 22
Download:
http://www.bladehelis.com/Products/S...LH1500#manuals
danny.act is online now Find More Posts by danny.act
Old Sep 18, 2011, 05:18 PM
Joined Jun 2011
lol you beat me to it
you just watch the price of HP6DSM go up now
Old Sep 18, 2011, 06:25 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Woo, I did something right, and I didn't know the first thing about these 120SR and HP6DSM?!?!?! OK, I'll take that. I have the seller of my 120SR to thank.
Heli Pad is offline Find More Posts by Heli Pad
Old Sep 18, 2011, 06:56 PM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Fremont County
Joined Aug 2011
I know I set dip#4 up and all the rest down and it worked for me but here is some info:
http://www.rcgroups.com/forums/showthread.php?t=1159318
Cheers all and happy flying!
BD(Kyle)
BattleDude is offline Find More Posts by BattleDude
Old Sep 18, 2011, 10:49 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
BD(Kyle)
Yeah...what he said!!!!! Me too, Weird
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Sep 19, 2011, 03:52 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
BD(Kyle)
Whoa little doggie. I just had another look at those pics. Check out the top knobs on that TX. My left knob is fully turned CCW and my right knob fully turned CW. Also, it looks like the markings for the settings are different as well.
Old Sep 19, 2011, 04:04 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Originally Posted by danny.act View Post
HP6DSM
Download:
Danny, it looks like that manual is for the SR. If you look at the pic in the manual it's stamped right on the TX "HP6DSM SR." I have heard that these TX's are set up different from the other HP6DSM TX's. No? This whole thing is ready to make my head explode I can't even imagine what it's like setting up a DX6i
Mike.
Old Sep 19, 2011, 04:20 PM
Joined Aug 2011
This is the radio that I bought.
http://www.rcgroups.com/forums/showthread.php?t=1483054
Came from a RTF cp pro 2. Great seller by the way, packed the radio up like a pro.
Old Sep 19, 2011, 05:05 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
[QUOTE=Blackanthem;19362317]This is the radio that I bought.
Came from a RTF cp pro 2. Great seller by the way, packed the radio up like a pro.[/ The only real clear image is the "5.0v" in that pic I'm still trying to figure out "why" the different settings?
OK, on my packing box it reads: HP6DSM 6-Channel, 2.4GHz DSM2: BCPP2 (stock # EFLH1056).
Sorry I screwed up the quote..
Mike.
Old Sep 19, 2011, 05:17 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Mike.
The first time I turned on the dx6i and scrolled through all the "Adjust" and "Setup" screens it was intimidating. But after putting in John Salt's basic settings and successfully flying with them I could relax and start thinking about what it all means. There is also a "Monitor" screen that lets you "bench fly" and see what the control surfaces are doing as you make changes to the various settings; that takes a lot of the mystery out of it. This is the only programmable tx I've ever handled, but I'm getting more comfortable every time I turn it on. In the end you are still dealing with two sticks, one for up and down and round and round, and the other for front to back and side to side.
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Sep 19, 2011, 05:24 PM
Joined Aug 2011
Here is a close up.
Description: HPDSM
Perhaps a clue? This is inside the battery compartment.
Description: Inside battery
Old Sep 19, 2011, 05:32 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Here is a close up.
Attachment 4291254
Craig, did it come with a box with all the numbers as I indicated in my previous post? If not, can you see the knob settings on the pic I provided? Do they look the same as yours. This is bugging the heck out of me as to why yours sets up different than mine. I won't be able to sleep tonight
Mike.
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
