Old Feb 17, 2013, 11:46 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
When I say "Your AIL and ELE shouldn't drift" I don't mean they might not need trimming, but once it's set it's set... either mechanically or electronically, and it shouldn' drift, that is... need adjusting during a flight, once they are set for a still hover... a depleting battery over the course of a flight will have no affect on their settings... when you trim them either mechanically or even electronically through the Tx you are mechanically setting their position using the pushrods from the servos to the swash, and the position is fixed once you stop adjusting it. It shouldn't need adjusting again unless something physically changes in your setup... maybe after dismantling and re-assembling something or replacing parts?
The rudder action is a different story... it has no mechanically fixed neutral setting... its trim is completely controlled electronically by regulating the speed of the tail motor/rotor. As the battery depletes over the course of a run, its trim (which is completely electronic) will usually need to be adjusted to compensate... because its fixed electronic setting is no longer in sync with the motor as the motor becomes underpowered.. actually, it's the relationship of the main motor to tail motor power that gets out of sync. My mSR does this as well. You would think the gyros would prevent this but anyone who owns these knows they don't .. I remember dacaur even bringing that part up.
North_of_49 is offline Find More Posts by North_of_49
Old Feb 18, 2013, 12:07 AM
Joined Dec 2011
EDIT
I believe the thing about electronic trimming in an as3x system is that if you added enough it, it would be considered by the system as actual user input.
dacaur would know more about that.
Old Feb 18, 2013, 12:10 AM
JChoosier is offline
Find More Posts by JChoosier
J.C.
JChoosier's Avatar
United States, IN, Goshen
Joined Feb 2013
OK I follow what you're saying now. Mechanical stays where you put it and is unaffected by battery voltage, whereas elecronic (tail rotor) will vary. I'm still new to SR, and despite the hundreds of posts I've read here, I still have an awful lot to learn
I think my biggest problem is a bad case of nerves every time I take off. Yhanks for your help.
JChoosier is offline Find More Posts by JChoosier
Old Feb 18, 2013, 12:16 AM
Joined Dec 2011
Yup.
I edited my post to hopefully make it more clear, check it out again ... #17371
No problem.
J.C.
JChoosier's Avatar
Joined Feb 2013
Originally Posted by North_of_49 View Post
EDIT
Yes, that was the impression I got too. In other words, the more you try to trim it, the more it would attempt to counter your trim inputs in order to stabilize the heli.
Old Feb 18, 2013, 12:17 AM
Joined Dec 2011
Yes, I think so. dacaur can confirm.
Old Feb 18, 2013, 12:28 AM
Joined Dec 2011
edited post #17371 again
... gotta run to wally world before it closes
Old Feb 18, 2013, 01:23 AM
Joined Dec 2011
Actually, I think it might be the opposite... that the gyro would release its hold.
Old Feb 18, 2013, 01:25 AM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
Well.. I scored an mSRx.. got a great deal I think. Should be here next week.. about the time we're expecting rain... which doesn't matter.. hah... It should be several steps above the little coax heli's I've been flying indoors.. I'm expecting something like my 120SR(which I've not flown indoors..that will be a ways down the road)..... it might even be a bit more spirited.. should be cool. Anyone got a real life comparison to share?
Still reading up on these things.. having fun all along the way.. and I did get to fly today.. and I should get a few or more flights in tomorrow.. lifes good.
DGrant is offline Find More Posts by DGrant
Old Feb 18, 2013, 01:54 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Hopefully I'm doing this right. Thank you sir (and others) for the speedy reply. I have been under the impression that the only heli's that didn't need trimming were the ones that had a 3 or 6 axis gyro, like the AS3X, Beast x, etc. I understand what you said, but then why do FBL helis explicitly say not to use any trim? I'm just using the MCPX as an example, but it implies that a FB heli needs trimming? I'm kinda lost.
Its not that the 120sr doesn't need trimming, but it should really only be a one time thing on aileron and elevator. Basically, you should trim it on the initial flight for a stable hover, and if it ever requires more trim (for aileron and elevator) its a good sign that something is wrong....
As for the FBL helis, you don't use trim because they have heading hold gyros on the aileron and elevator (tail too), so whatever orientation the heli is in when the gyros activate (when you turn on the throttle) that's "center", and any time you move them (with the sticks), that becomes the new "center"....
Basically, when you move the trim on your radio, you radio sends that like a stick movement. The heli cannot tell the difference between a trim adjustment and a stick movement. So if you were to trim it in the air, the heli just sees a tiny stick movement.
The problem is that the radio is constantly sending this tiny stick movement, You might not even notice a click or two.... but you are basically constantly telling the heli "go this way" even when you aren't touching the stick.... more than 4 or 5 clicks is really noticeable.
Witha FBL heli, if you throttle up a bit and hold it in your hand, then add a few clicks of trim, you can watch the swash move slowly in that direction, you can correct it with the sticks, then it will just slowly move back the same direction.... That's why you don't use any trim on a FBL bird.... any trimming on a heading hold gyro must be done mechanically.
dacaur is offline Find More Posts by dacaur
Old Feb 18, 2013, 08:46 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I might add that you do the mechanical trimming of aileron and elevator by adjusting the two pushrods. After hard landings--often called CRASHES--the pushrods end up bent or otherwise affected. I've written much in this topic--that this is often the way to solve many flight problems. However, pushrods have nothing to do with tail motor or yaw problems. Just tossing this in to clarify the difference.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Feb 18, 2013, 08:50 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
If you'd like to calm those nerves on take off, here a little trick from a member (1Pilgrim).
Use your manual under the left skid. I use a short piece of wood lath (from the old walls) which is about 3/8" thick. On lift off she'll pop straight up with no right stick input
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Feb 18, 2013, 09:52 AM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
With the AS3X (and I'm sure the BeastX and others), you're not controlling the servos directly. The AS3X is doing that. It interprets your stick motions as suggestions as to where you want to go and then it figures out the best way to move the servos to make it do that. With the MSRX in particular, if you move your aile/elev off center with trim, it's interpreting that as a direction where you want to fly.
With FB helis you're directly controlling the servos with your sticks. That lets you place the aile/elv servos exactly where you want them with the transmitter trim. Of course, the consensus is that it's better to mechanically trim the heli by adjusting the lengths of the pushrods first.
RoboHeli is offline Find More Posts by RoboHeli
Old Feb 18, 2013, 01:00 PM
venicebill is offline
Find More Posts by venicebill
venicebill's Avatar
United States, FL, North Port
Joined Jun 2012
No flying today..33 degree in swfl and wind ..the msr is out of commission with a broken paddle on order with no backup for indoor flying so ordered another msr wish they had a bnf instead of having to buy the rtf Happy Flying
venicebill is offline Find More Posts by venicebill
Old Feb 18, 2013, 01:19 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
After a while of ordering parts, you could have enough parts to build a brand new one--bnf! That's what I've done. That's how I also end up building heli's that are 1/2 one and 1/2 another--but they work!
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
