Old Feb 14, 2013, 06:24 AM
ikarous is offline
Find More Posts by ikarous
Greece, Athens
Joined Oct 2012
Hello, i have a problem with my 120SR and i would like your help please. This happened after i had one crash few days ago. I am using the stock tx, and the problem appears to be in rudder stick i think. While hovering, i noticed the tail makes very small left and right movements, without using rudder at all. After few minutes, the heli makes turn 180 degrees, like i am using rudder and face it nose in, again, without using rudder..I tried to keep it with my hand down, while i use throttle, to check the tail motor how reacts and it seems like its push the tail to the wright with wright rudder, and stop push to the left, but not instantly..I am confused..any help??
By the way, i check everything on heli and seems like everything is ok..
ikarous is offline Find More Posts by ikarous
Old Feb 14, 2013, 06:51 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Most likely, your problem is in the signal to the tail motor. First check the connections at the motor and at the main board. If they are plugged in fine, then it's probably damage to the wire(s) at the motor--inside. A replacement tail motor will normally solve the whole problem. This is a common problem.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Feb 14, 2013, 03:45 PM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
Also, you might check the motor shaft for any debri that might have been picked up in the crash.. as well as make sure your tail rotor prop is not slipping on the shaft. Run it up while CAREFULLY holding the heli in your hand... not that any of this is an answer to the problem.. but food for thought... I've had debri/hair/stuff get caught up in the tail rotor motors on my smallish coax heli's.. its a pain.. I hope you get to the bottom of it.
DGrant is offline Find More Posts by DGrant
Old Feb 14, 2013, 03:52 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Let me start with the last part there. If I understood you correctly, you were trying to see how the tail motor reacts to the rudder control by holding down the helicopter with you hand, so that it is not free flying. That, unfortunately, invalid the test. I've make that same mistake before.
You see, the whole purpose of the tail rotor is counter rotation. The main rotor asserts a rotational force on the body. The tail motor works to compensate and stabilize. It knows how hard to work by reading the signals and controls from the head holding gyro. But when you hold the helicopter down, the heading is not changing, and the gyro is saying, "I'm still, no need for anti-rotation". That's why everything is skewed once the helicopter is held down. You won't get a true reading or response from the tail this way.
I'm not saying that the tail doesn't have a problem. I'm just saying that benching the helicopter will not tell you much. Sax has offered you advice on the issue and he's most likely correct.
I'm not too concerned about the small movements, both left and right. Our helicopters do that, some more than others. But when it does an 180, I'm curious. Does it do a quick 180, or a slow 180. When it does that, does it always turn in the same direction, or one direction one time, another direction another time? If if always turn in one direction, is it Left?
Heli Pad is offline Find More Posts by Heli Pad
Old Feb 14, 2013, 06:38 PM
rwek is offline
Find More Posts by rwek
St. Louis, Mo.
Joined Jun 2008
I agree with Saxyguy. These kinds of problems are usually the tail motor. I have had to replace the tail motor on mine twice with these types of problems and it always fixed the problem. A cheap and easy fix.
rwek is offline Find More Posts by rwek
Old Feb 14, 2013, 07:26 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Is the tail rotor tight on the motor shaft?
Jake8131 is offline Find More Posts by Jake8131
Old Feb 14, 2013, 08:29 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
definatly sounds like a tail motor connection problem.... when it spins 180, which way does it spin? (nose right or nose left)
dacaur is offline Find More Posts by dacaur
Old Feb 15, 2013, 03:27 AM
ikarous is offline
Greece, Athens
Joined Oct 2012
-DGrant: everything is clear in the motor as i noticed, also the tail motor spins free and the tail prop also..i will check again
I'm not too concerned about the small movements, both left and right. Our helicopters do that, some more than others. But when it does an 180, I'm curious. Does it do a quick 180, or a slow 180. When it does that, does it always turn in the same direction, or one direction one time, another direction another time? If if always turn in one direction, is it Left?[/QUOTE]
it turns a fast 180 degrees, as it hovers nose out, to the left, And doing this only with this direction.
-Jake: yet it is tight, no problem there.
-dacaur: i check the motor connections to the board and to the motor, everything seems fine. I will check again. It spins nose left.
-One more point: one item from the motor seems to be lost, its the *tail motor protective sleeve*, i found it on the ground..but i dont know where to replace it again..maybe this cause the problem?
Old Feb 15, 2013, 09:48 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Don't worry about the protective sleeve just yet. That's not the problem. Look at your tail rotor from the rear. The tail rotor should be perfectly straight (up and down) and not curved in (or out). These tail rotors have a nasty habit of curling inward towards the boom and will look like this from the rear...")" This is actually one of my pre-flight checks, checking the tail rotor. If you find it's out of shape, simply work it back into shape using your thumb and forefinger paying particular attention to the rotor pitch.
The tail rotor can take on this shape right out of the box OR just sitting around for weeks. I know!!!!
Tail rotor straightness and pitch are one of the most over looked problems.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Feb 15, 2013, 10:32 AM
ikarous is offline
Greece, Athens
Joined Oct 2012
Thank you Mike, and thank you ALL for your fast replies
The problem still exists, after all the checks i've done, so tomorrow i am going to get a new tail motor. Fortunately, i found at one of my local shops here, so the replacement its going to be fast..Thank you again!
Old Feb 15, 2013, 10:34 AM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Random question. Has anybody used one of those great Harbor Freight suitcases with the pull-and-pluck foam inserts to make a carrying box for their 120SR? I was thinking about doing that with mine since I prefer carrying those suitcases to the field rather than the heli's own box.
Seems to me that you'd have to mount it sideways and then carefully support the flybar so it wouldn't be bent. I'm going to be finding a solution to this soon as spring is coming!
RoboHeli is offline Find More Posts by RoboHeli
Old Feb 15, 2013, 12:19 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I always put my heli on the dashboard and let it warm up on the way.
Old Feb 15, 2013, 02:27 PM
Wind Spirit is offline
Find More Posts by Wind Spirit
Wind you go around in circles
Wind Spirit's Avatar
United States, FL, Middleburg
Joined Jan 2012
Yes, I have one and it works great. I put my DX6i, my 120SR, chargers, and batteries in it. The one I have has a tool holder in the top that you can leave in or take out. I keep tools and spare parts in that. WS
Wind Spirit is offline Find More Posts by Wind Spirit
Old Feb 15, 2013, 03:25 PM
Joined Jan 2012
PIc.WS
Old Feb 15, 2013, 03:28 PM
Joined Jan 2012
I have no space on the dash, lunch is there warming up.WS
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
