Old Jan 09, 2013, 09:19 AM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I'll send you the Excel sheet! See your pm.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 09, 2013, 10:50 AM
DaveNH is offline
Find More Posts by DaveNH
DaveNH's Avatar
United States, NH
Joined Nov 2012
Originally Posted by 1Pilgrim View Post
I would appreciate hearing how accurately the equation predicts your battery's performance.
Assuming my charger readings (Thunder AC6) are accurate, the formula and what it reports are pretty far off. (#1, and # 2&3 are 2 different batteries)
Might be the charger, even it's reading don't seem consistent, it shows the battery at 3.78v remaining took more than the one that was at 3.76v, I would thing it would take less?
1. 3.78v, sheet predicted 296.98mAh, charger indicated it supplied 380mAh
2. 3.76v, sheet predicted 324.94mAh, charger indicated it supplied 370mAh
3. 3.74v, sheet predicted 351.44mAh, charger indicated it supplied 423mAh
DaveNH is offline Find More Posts by DaveNH
Old Jan 09, 2013, 11:14 AM
dferrey is offline
Find More Posts by dferrey
United States, CO, Longmont
Joined Jan 2013
I broke a ball of the swashplate when trying to remove link, the tail rotor and fin aren't looking so hot either, sheesh.
Can anyone recommend a good source for spare 120 SR parts?
dferrey is offline Find More Posts by dferrey
Old Jan 09, 2013, 11:39 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
The cheapest with shipping price you can get on eBay. HopMeUp out of NC is usually the cheapest for me, but I live in a neighboring state.
Old Jan 09, 2013, 11:43 AM
dferrey is offline
Joined Jan 2013
Thanks, funny, I've just been looking at HopMeUp and yeah, the prices look very good.
Old Jan 09, 2013, 11:54 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
The problem may be that it's hard to tell how full it is even after it registers 4.2. As I'm charging, the battery will go up to 4.2 quickly, but the mah are continually loaded long after it reached the voltage max. It also would vary depending on how long the battery sat before using and the temperature outside. Interesting, though.
Old Jan 09, 2013, 12:05 PM
DaveNH is offline
DaveNH's Avatar
United States, NH
Joined Nov 2012
We might be trying to put a specific number on something that is just to much of a variable.
Old Jan 09, 2013, 01:34 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Granted, but comparing actual to predicted on 435 flights I only found a half dozen "outliers" i.e. predicted values that were more than 5% off. I could account for at least a couple of the outliers; there were times when I interrupted the charging cycle (lower mAh "put back") or charged at a slow rate for the entire charging cycle (higher mAh "put back").
I also had batteries that were well managed, i.e. almost never discharged too far, allowed to cool to ambient before charging and never recharged too fast.
I agree that this whole exercise may be purely academic anyway. The closer a battery is to fully charged or fully discharged the less accurate the predicted "put back" will be, but why bother to charge if the battery is near full and why wait to charge until the battery is near empty? Just use a timer and bypass the algebra.
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Jan 09, 2013, 01:48 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
80% Rule=Fun. It doesn't get any easier
This will be my last post on the subject....*YAY*
Chap1012 is offline Find More Posts by Chap1012
Old Jan 09, 2013, 01:54 PM
DaveNH is offline
DaveNH's Avatar
United States, NH
Joined Nov 2012
My mathematically challenged brain thinks this is the best idea yet
But I do like to somewhat understand the technology I'm working with, and how to prolong its life and not treat it poorly, and with lipos, treating them badly usually doesn't end well.
Old Jan 09, 2013, 02:11 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
"YAY" indeed!
Rule #2 Never leave well enough alone!
Rule #3 Why use one syllable/word/sentence/paragraph when three will do?
Rule #4 If it ain't broke, break it!
Old Jan 09, 2013, 04:29 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Break it... Yes--my credo.
Old Jan 09, 2013, 04:46 PM
dferrey is offline
Joined Jan 2013
If by credo you mean the results of my "skillful" flying technique, then, yeah, that's my credo as well .
Old Jan 09, 2013, 06:20 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
The problem with your formula 1Pilgrim, is that its plotted based on your batteries and your heli, at your altitude. Different helicopters (some will draw more amps, asome less, depending on how new the motor is and other variables like lubrication, etc), at different altitudes are going to have different amp draws, (it takes more power to fly at higher altitudes) so the formula is going to be off for anyone but you. I guess someone at the same altitude might get close, but again, a worn motor or warped rotor could easily throw it off. When you batteries degrade a little more, or you replace your motor, or go on vation to a different altitude, your formula will not be as close any longer....
Thats the problem with creating a formula based on a set of data, because if the data changes, the formula no longer works.
Math hurts my brain anyway, I'll just set a timer and let my charger decide how much power to put in my batteries...
dacaur is offline Find More Posts by dacaur
Old Jan 09, 2013, 08:26 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
As I said, this is really an academic exercise; like Mike said I time my flights and just go fly. I did make a point of mentioning the type and condition of my batteries and the management principles I follow. I also asked for feedback from other pilots so I can find out the extent to which the variables you mention affect the formula. It gives me something to do on these long winter nights!
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
