Old Jan 08, 2013, 03:16 PM
dferrey is offline
Find More Posts by dferrey
United States, CO, Longmont
Joined Jan 2013
Weird, it says that video is block in my country. CO and WI are still in the same country right?
dferrey is offline Find More Posts by dferrey
Old Jan 08, 2013, 03:19 PM
Rich Knapp is offline
Find More Posts by Rich Knapp
LYNX/OXY Team Manager
Rich Knapp's Avatar
United States, WI, Appleton
Joined Jul 2012
lol Ya, some dumb Y/T update were I had to click a approve button. Should be able to see it now.
EDIT: I'll make one with no music and replace the one in the post.
Rich Knapp is offline Find More Posts by Rich Knapp
Site Sponsor
Old Jan 08, 2013, 04:40 PM
Rich Knapp's Avatar
Joined Jul 2012
No music. Thanks to You Tube.
Sky Dancing inside post workout. (7 min 55 sec)
Site Sponsor
Latest blog entry: Our Family heli's.
Saxguy1000 is online now
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I'm determined to become an RC Heli's Pilot if it kills me, wrecks my house/garage, takes away 4 or 5 of my cats lives and bleeds my 401k. Ok, maybe that's a bit of an exaggeration.
You don't have to apologize... We've all bled our 401k. Pretty much, we're all homeless on this forum.
I started with a v911 (and will continue) and today purchased a Blade 120 SR RTF. Brought it home, did a bit of trimming and broke the flybar. Sigh.
I'll head back to hobbytown to get a new flybar later but I'd like to get others thoughts on other parts I should be prepared to replace. I was thinking of picking up some "Turnigy nano-tech 600mah 35C Batteries Lipo"
Turnigy's are good. I also have gotten a year's worth of good flights out of Tigers brand--and they are real cheap. For parts, I'd get one or more of every part that goes to the main rotor assembly and the main shaft. Also, a spare set of skids or two.
Saxguy1000 is online now Find More Posts by Saxguy1000
Old Jan 08, 2013, 04:59 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I have to admit, I haven't seen all the problems with the SR 120--yet. I landed hard in a softball field a couple months ago, right into the sand infield. My heli (#3) has not worked since because it--what I thought--was full of sand. Today, I got the alcohol out to scrub down the board and the servos which were not working. I had hit the servos with several different sprays to try to get the gunk out, but nothing was working. So, I completely tore it all down and used Q-tips and cleaned it up as good as my guns after the range. My servos still wouldn't work, so I took them off the board and started to clean them. To my surprise, the one servo wasn't operating (first guess) because I found a rock stuck in it (see photo). Turns out, it wasn't sand, it was a piece of foam! So, it made me wonder how long that had been in there. I slapped the servos back on and tried it again.
Name: servo cleaning.jpg
Description: Foam stuck in the servo.
The servos still didn't work. They kept binding. I then had to squint really hard and start to try figure out why. Turns out: the gears on the screws both had one or two of the spaces between teeth with something stuck between them. I think this was actually sand wedged in between. I cleaned it out, and sure enough, the servos work now.
There is a rough TBE going on, so I've got more work to do (I'll follow my own method on my blog.) What amazed me the most is not just the above but what I thought next...
How many guys have given up this hobby because of seemingly impossible problems with their heli? The key to staying in the hobby is pure persistence. You have to be absolutely sure that you will find the problem and make the thing work again. Patience is worth a premium price. Every heli can have a new life no matter how bad it's messed up!
Old Jan 08, 2013, 05:49 PM
dferrey is offline
Joined Jan 2013
Thanks, I ordered 4 of them. I also got and installed the replacement flybar. My goal is to figure out the trim and flying thing before I break to much. The learn curve for this old guy is steep.
Old Jan 08, 2013, 07:48 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Been there! I had something wedged in the gears on my 120 that I couldn't even see... not the screw part, it was in the main gear that meshes with the pinion on the servo motor. I could tell it was there because the gear would stick in that spot.... I had a hobbyknife handy so used that try to clear it out.... Heard a tiny "click" as whatever it was hit the floor and all was good again..... must have been a tiny white rock.... crazy.
dacaur is offline Find More Posts by dacaur
Old Jan 08, 2013, 08:14 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Originally Posted by dacaur View Post
3.6v resting voltage means you are at basically 0% capacity.... so 3.55 is bad... 3.78 is about 30%, which jives with the rated capacity and what you charged the others....
I have found this to be pretty accurate.
4.20v = 100%
4.03v = 76%
3.86v = 52%
3.83v = 42%
3.79v = 30%
3.70v = 11%
3.6v = 0%
I plotted mAh vs post-flight voltage for about 45 flights on each of my four Hyperion 550mAh batteries. They are extremely consistent. Here is the equation derived from all those flights:
Note: "X2" is "X squared"
X = post-flight voltage; Y = mAh "put back"
Y = (-1822.8X2) + (12346X) - 20326
By plugging in your post flight voltage you should be able to predict roughly how much "juice" you are able to put back.
I would appreciate hearing how accurately the equation predicts your battery's performance.
Edit: added parentheses.
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Jan 08, 2013, 08:18 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Y = -1822.8X2 + 12346X - 20326
Is that "negative"1822.8 "times" x2 plus 12346 "times" x "minus" 20326?
Old Jan 08, 2013, 08:35 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Yes - I added parens to clarify. When I ran the equation for all my flights I had an average difference of 3 mAh from actual; range was max +34, min -31.
Old Jan 08, 2013, 08:46 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Yes - I added parens to clarify. When I ran the equation for all my flights I had an average difference of 3 mAh from actual.
I plugged that into my Excel chart, but with a voltage of 3.85, my result for mAh is 13170.54? Is my Excel input off?
Old Jan 08, 2013, 08:52 PM
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Must be - what was your actual mAh put back? The equation shows 188.
Old Jan 08, 2013, 08:55 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I was just trying to get the formula straight. Now that I know the answer, I'll work backwards and fix the math. I suppose I could just do the math, but then I'd ruin my reputation for being bassackwards.
1Pilgrim is offline
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Gotta go - wife wants the pc. Happy wife, happy life!
Old Jan 08, 2013, 09:01 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
same...
Developed a clicking sound immediately after a hard brush with the ground. Took it inside but couldn't see anything at first but eventually saw a microscopic piece of something deep between 2 spur gear teeth which I then picked out with a dental pick... or so I thought. Put it back in the air and still heard the click. Second try got rid of it Was a good learning experience, I knew immediately what to look for when it happened on my Losi buggy... sure enough... same thing. Doesn't take much.
North_of_49 is offline Find More Posts by North_of_49
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
